[XenCustomize] Core Library 1.0.1
XF 2.2 / 2.3 [XenCustomize] Core Library 1.0.1
  • ⚠️ Section Premium. RĂ©server aux Membres Premium ⚠️
Titre du sujet Titre du sujet [XenCustomize] Core Library 1.0.1
Affichages Affichages 4
📦 XenCustomize Core Library​
Shared framework for compatible XenCustomize premium add-ons
✨ What It Is​
XenCustomize Core Library is a small shared dependency used by compatible XenCustomize premium add-ons.
It helps keep supported add-ons lighter, more consistent, and easier to maintain, while giving customers a smoother setup experience across multiple XenCustomize products.
đź§© Why This Add-on Exists​
Instead of repeating the same shared code inside every premium add-on, XenCustomize Core Library provides one common foundation that compatible add-ons can use.
This helps with:
  • cleaner add-on architecture
  • more consistent updates and fixes
  • smaller and easier-to-maintain compatible add-ons
  • a more predictable experience for customers using multiple XenCustomize products
ℹ️ Important Notes​
  • This is not a standalone feature add-on
  • It is a shared dependency for compatible XenCustomize premium add-ons
  • Using App for Cloudflare? If XenForo reports that XenCustomize Core Library is missing or does not meet the required version even though it is already installed and up to date, temporarily disable the third-party App for Cloudflare add-on and try installing the XenCustomize add-on again. Its caching may prevent XenForo from immediately recognizing the installed Core Library version
đź§© Compatible Add-ons​
The following XenCustomize premium products require this library to be installed:
