[FX] Quick Post brings a fast, modern social-media-style thread creation experience to your forum. Designed to streamline thread posting, boost member engagement, and provide clear category routing between regular members and forum staff.
Navigate to AdminCP > Options > [FX] Quick Post to configure:
# Or rebuild add-on data:
php cmd.php xf-addon:rebuild FX/QuickPost
src/addons/FX/QuickPost/
├── Option/
│ └── Node.php # Dropdown category renderer for AdminCP options
├── Widget/
│ └── PostCardBar.php # Widget handler for Quick Post bar
├── XF/
│ ├── Pub/Controller/
│ │ └── ForumController.php # Controller extension loading nodeTree & validating forbox
│ └── Service/Thread/
│ └── CreatorService.php # Service extension routing node_id on thread save
├── _data/
│ ├── class_extensions.xml # Controller & Service class extensions
│ ├── options.xml # 8 configurable options
│ ├── option_groups.xml # fx_quickpost option group
│ ├── phrases.xml # Bilingual phrase entries
│ ├── templates.xml # Templates (fx_choose_box, fx_post_card_bar & LESS)
│ ├── template_modifications.xml # Modifications for PAGE_CONTAINER, forum_view, forum_overview_wrapper
│ └── widget_definitions.xml # Widget definition for fx_post_card_bar
├── addon.json # Add-on identification manifest
├── hashes.json # SHA256 file integrity verification
└── logo.png # Add-on logo
Key Features
1. Social-Style Post Card Bar Widget
- Displays an intuitive thread creation bar inspired by modern social feeds (such as Facebook's News Feed), featuring user avatar and quick-input prompt to encourage thread creation.
- Provides Widget Definition ID: fx_post_card_bar, which can be placed anywhere on your forum (forum_list, thread list, sidebar, or custom positions).
- Full Light and Dark Mode compatibility. Automatically hidden for guests or when no default forum node is configured.
2. Smart Category Selector
- Embeds a sleek category dropdown right above the editor form (forum_post_thread).
- Allows members to switch to their desired destination node directly while writing without having to navigate back through forum trees.
- Role-based node access control:
- Regular Members (Group 2): Limited to standard public posting categories.
- Management & Staff (Group > 2 / Staff): Granted access to administrative and restricted internal nodes.
- Strict server-side verification at both Controller and Service levels (CreatorService), preventing unauthorized thread submissions into non-permitted nodes.
3. Popup Overlay Form Option
The fx_post_overlay option provides flexible submission behavior:- Enabled: Launches the thread creation form in a lightweight, responsive popup modal overlay.
- Disabled: Redirects directly to the dedicated full-page thread creation URL of the selected forum node.
4. Header Opposite Navigation Icon
- The fx_post_nav_opposite setting inserts a quick post action icon (<xf:fa icon="fa-edit" />) directly before .p-nav-opposite (next to user avatar and notifications).
- Seamlessly matches XenForo’s native iconic navigation style and supports native tooltips.
5. Main Navigation Link
- The fx_post_nav_link option adds a dedicated "Post Thread" item to the main navigation menu (.p-nav-list).
- Automatically syncs across desktop navigation bars and mobile off-canvas sliding menus.
6. Replace Default "Post thread…" Button on Forum List
- The fx_post_replace_forum_list_button option redirects the default "Post thread…" button in the forum list (forum_overview_wrapper) directly to Quick Post’s configured default node.
7. Hide Thread Creation Buttons in Forum View
- The fx_post_hide_forum_view option hides thread creation buttons within specific forum views (forum_view), channeling all posting activity through the unified Quick Post flow.
Configuration Options (AdminCP)
Navigate to AdminCP > Options > [FX] Quick Post to configure:| Option (Option ID) | Data Type | Default | Description |
| fx_post_box_default | Forum Node (Select) | Unset | Default destination node when users click the Quick Post bar, nav icon, or quick thread button. |
| fx_post_box | Forum Node List (Multi-select) | Empty | Allowed categories available for regular members (Group 2) during post creation. |
| fx_post_box_manager | Forum Node List (Multi-select) | Empty | Extended categories reserved specifically for staff and management groups (Group > 2 / Staff). |
| fx_post_overlay | Boolean (On/Off) | On | Opens the thread creation form in a popup modal overlay instead of a full page reload. |
| fx_post_nav_opposite | Boolean (On/Off) | Off | Inserts a quick post icon at the front of .p-nav-opposite in the header bar. |
| fx_post_nav_link | Boolean (On/Off) | Off | Adds a quick post link into the main navigation bar (.p-nav-list). |
| fx_post_replace_forum_list_button | Boolean (On/Off) | On | Replaces the default "Post thread…" button on the forum list with the Quick Post link. |
| fx_post_hide_forum_view | Boolean (On/Off) | Off | Hides all thread creation buttons on individual forum view pages (forum_view). |
Installation & Upgrade
Install via AdminCP:
- Upload the FX/QuickPost directory to src/addons/FX/QuickPost/.
- Go to AdminCP > Add-ons, locate [FX] Quick Post and click Install.
- Go to AdminCP > Options > [FX] Quick Post to select your fx_post_box_default and allowed forum categories.
- (Optional) Go to AdminCP > Appearance > Widgets, add the Post Card Bar widget to the Forum list: Above nodes position to show the posting bar on your forum index.
Install / Rebuild via Command Line (CLI):
php cmd.php xf-addon:install FX/QuickPost# Or rebuild add-on data:
Add-on Directory Structure
src/addons/FX/QuickPost/├── Option/
├── Widget/
├── XF/
├── _data/
License & Credits
- Brand: FX Add-on Suite
- Compatibility: XenForo 2.2.0 or higher (XenForo 2.3.x recommended)
- Source: Exclusively developed for XenForo systems.
