FX – CopyShield 1.2
XF 2.0 / 2.1 / 2.2 / 2.3 FX – CopyShield 1.2
FX – CopyShield 1.2
Titre du sujet Titre du sujet FX – CopyShield 1.2
Réponses Réponses 8
Affichages Affichages 212
Introduction :
FX – CopyShield is a lightweight XenForo add-on that helps prevent unauthorized copying of post content. It is the ideal solution for forums that share knowledge, documents, or other exclusive content that requires protection.
Key Features :
  • Disable right-click, text selection, copy, and drag
  • Block keyboard shortcuts: Ctrl+C, Ctrl+U, F12, PrintScreen, and more
  • Show a minimal toast notification instead of intrusive alerts
  • Option to apply protection to the first article only or all articles
  • Lightweight, fast, and performance-friendly
Easy Integration :
  • Install the add-on via AdminCP
  • Change the addon's options
  • Check permission on Usergroup
Technical Information :
  • Add-on Name: FX - CopyShield
  • Version: 1.0
  • Compatible with: XenForo 2.1+, 2.2+, 2.3+
  • Developer: FX
Version 1.1 :
README.md
  1. XFRM (XenForo Resource Manager) Support:
    • Extended copy protection to XFRM resource description pages, resource updates, and review content.
    • Added dedicated permission under Resource Manager permissions: FX - CopyShield: Lock resource content.
  2. Form Input Bypass Fix (Regression Prevention):
    • Added smart element detection (isInputElement) for <input>, <textarea>, Froala Editor (.fr-element, .js-editor), and [contenteditable="true"].
    • Users can type, select (Ctrl+A), copy (Ctrl+C), cut (Ctrl+X), and paste (Ctrl+V) freely inside input fields without triggering protection blocks.
  3. New Admin CP Options:
    • Lock first post only: Choose whether to lock only opening posts or all posts in threads.
    • Enable protection for XFRM (Resource Manager): Toggle copy protection specifically for XFRM pages.
    • Block Developer Tools & View Source shortcuts: Toggle blocking of developer inspection keys (F12, Ctrl+Shift+I/J/C, Ctrl+U, PrintScreen, Ctrl+S, Ctrl+P).
  4. Glassmorphic Toast Alert & Print Shield:
    • Modern floating toast notification with smooth 2.2s auto-fade animation.
    • @media print rules automatically hide protected content when printing web pages.
Télécharger V1.1 :
Version 1.1.1 : Fix copy protection to XFRM resource error in 1.1
Version 1.1.2 Big update :
Add more choices and options:
All settings are centrally managed under AdminCP > Options > FX - CopyShield:
OptionKeyDefaultDescription
Locked user groupsfx_copyshield_locked_groupsNoneSelect user groups subject to protection rules.
Exempt staff membersfx_copyshield_exempt_staffEnabledAdministrators and moderators bypass all restrictions.
Lock first post onlyfx_copyshield_allEnabledWhen enabled, only the thread starter post is locked. When disabled, all posts are locked.
Lock on XFRMfx_copyshield_xfrmEnabledProtects XenForo Resource Manager descriptions and updates.
Lock on XFMGfx_copyshield_xfmgEnabledProtects XenForo Media Gallery images, videos, and comments.
Block right-clickfx_copyshield_block_rightclickEnabledDisables context menu on protected content and media.
Block text selection & dragfx_copyshield_block_selectEnabledDisables text highlighting, selection, and media dragging.
Block copyfx_copyshield_block_copyEnabledIntercepts copy events on protected content.
Block copy/save shortcutsfx_copyshield_block_shortcutsEnabledBlocks Ctrl+A, Ctrl+C, Ctrl+X, Ctrl+S, Ctrl+U, Ctrl+P.
Block DevTools shortcutsfx_copyshield_block_devtoolsEnabledBlocks F12, Ctrl+Shift+I, Ctrl+Shift+J, Ctrl+Shift+C.
Block print / Save as PDFfx_copyshield_block_printEnabledConceals the page when printing or generating PDFs.
Allow copying code blocksfx_copyshield_allow_codeEnabledPreserves copying for
 and [ICODE] elements.[/td]
[/TR]
[TR]
[td][B]Show warning toast[/B][/td][td]fx_copyshield_show_toast[/td][td]Enabled[/td][td]Shows an unobtrusive toast notification on restricted actions.[/td]
[/TR]
[/TABLE]
Télécharger V1.2 :
XF 2.0 / 2.1 / 2.2 / 2.3  s9e Media Sites 2.19.3
