Core AddOn which from now on, (nearly) all my AddOns will require.
Besides Icon handling and Assset Upload some other minor thing that I share between my AddOns.
Mostly this is related to Font Awesome handling. See Edit Option Group as Demo.
Also see pictures whats inside.
New Resource Icon like this resource has, means, it needs this Core Addon.
Version 1.1.0 :
Some more shared functions added to the core. (indexale trait and template macros).
No need to upgrade, if no AddOn requires the upgrade of the core. The next upcoming index will need this version.
Version 1.1.1 Release Candidate Now includes : Messages Template for Admin.
Télécharger V1.1.1 Release Candidate :
Version 1.2.0 Release Candidate 1 :
- My Core AddOn now as first with 2.3 compatibility, and requires also XF 2.3
- Don't update until all my AddOns that you use, have the XF 2.3 compatible version.
- Replaces XF Core FontAwesome Input fields with my Preview Version.
Télécharger V1.2.0 Release Candidate 1 :
Version 1.2.0 Release Candidate 3 :
- Small bug fixes
- additional new phrases
- You only need to update, if a depending AddOn requires this.
Télécharger V1.2.0 Release Candidate 3 :
Version 1.2.0 :
Télécharger V1.4.2 :
Version Release 1.4.3 (ID 1040370)
Version 1.1.0 :
- Small bug fixes
Version 1.2.0 :
- Some new phrases a little bug fixed whith indexes
- new Minor Version for all upcoming releases
- copyright handler
- renaming from [cv6] to [DD]
- Deactivate yout forum in the Settins.
- Update Core AddOn
- Update any other AddOn
- Check if all runs as expected
- if Yes, turn on Forum again.
Version 1.4.0 (ID 1040070)
- FontAwesome Icon Auto-Completion: Introduced interactive component
XF.cv6IconAutoComplete(triggers starting atfa- + 2 characters) featuring SVG mask previews inheriting the current text color (currentColor) and smoothXF.Animatetransitions. - Icon Helper Service: Added
cv6\Core\Helper\Iconservice for indexing and registry caching (cv6IconList). - Public & Admin Controllers: Added auto-complete controllers hosted on the
cv6-coreroute. - Option Verifier: Updated
verifyValidIconMandatoryandverifyValidIconOptionalmethods to leverage nativeXF\Repository\IconRepositoryconstants. - Options Integration: Added support for
autocomplete=1insideedit_format_paramsfor ACP options.
- Automatic Brand Variant Activation: Selecting a brand icon (e.g.,
fa-facebook,fa-github) automatically switches the layout dropdown to the Brand style (fab). - Style Restoration (Memory Function): The previously active non-brand style (
fas, fal, far) is remembered and automatically restored when selecting the next non-brand icon.
- Format Class Option Validation: Option verifiers in
cv6\Core\Option\Checknow validate additional CSS classes against the permitted options configured in thecv6Coregroup (cv6CoreFaStyle, cv6CoreFaRotation, cv6CoreFaAnimation). Clear error messages are thrown if disallowed classes are detected. - Filtered Autocomplete Suggestions:
cv6\Core\Helper\Icon::searchIcons()now filters icon suggestions based on the allowed styles defined in the settings. For instance, if the Brand style (fab) is disabled, brand icons will no longer appear in suggestions.
- Template Modernization: Refactored admin templates (cv6_assetupload.html, cv6_fa_icon.html, cv6_style_fa_icon.html) to use native <xf:js> tags resolving directly from the add-on resources.
- Setup Sync Helper: Added a new helper method syncGroupPhrases to SetupTrait.php to simplify and automate phrase synchronization from group tables during installations or upgrades.
