[DD] Letter Index 1.2.5
XF 2.2 / 2.3 [DD] Letter Index 1.2.5
Titre du sujet Titre du sujet [DD] Letter Index 1.2.5
Réponses Réponses 13
Affichages Affichages 659
Additional requirements : [cv6] Core
This AddOn adds a lettered TabIndex to selected forums.
This can be turned on and off on a per forum base and for categories of the resource manager.
You can style the tabs, if the default is not fitting to your style.
And you cann de/activate special tabs and the display if empty tabs should be showed differently.
If you enable the empty tab option, one additional query is added. But usual this query should not slow down your site. But if you have a huge forum and there are no empty tabs, you can save this time.
Version 1.0.1 : Updated the addon code to work with xf 2.3
Version 1.1.0 Release Candidate 2 :
XF 2.3 Version only
Forum and Category Settings are now divided into two options.
Enable indexing
Display Index
Added a Index Widget.
The indexing needs to be enabled that the widget is shown.
Télécharger V1.1.0 Release Candidate 2 :
Version 1.1.0 Release Candidate 3 :
- Fixed Bug with TMDB AddOn (and probably other).
- Requires the updated Version of my Core AddOn.
Télécharger V1.1.0 Release Candidate 3 :
  • rename to [DD]
  • Fixed Bug with TMDB AddOn
Update Core before you update any other of my addons.
  1. Deactivate yout forum in the Settins.
  2. Update Core AddOn
  3. Update any other AddOn
  4. Check if all runs as expected
  5. if Yes, turn on Forum again.
Version 1.2.2 - XF 2.3.8+
- Works now with XenFro 2.3.8+
Télécharger V1.2.2 :
Version 1.2.5 Changelog​
  • Listener: Added missing column existence guard in addonPostInstall for xf_rm_category.
  • Forum Entity: Parameterized fetchLetterCounter() SQL query with prepared statement parameter (node_id = ?).
  • Setup: Removed unused stub methods.
    [']Wording changed to letter to avoid confusion with a another AddOn,.
Télécharger V1.2.5 :
