[XenHub] Animated Footer A modern and lightweight XenForo add-on that allows you to add beautiful and
Animation type, color, speed, intensity, and mobile behavior can be easily controlled from AdminCP. The add-on uses CSS-based animation, so it maintains a performance-friendly and responsive design.
Key Features
- Animated Gradient — footer background-এ smooth moving gradient effect।
- Aurora Glow — soft aurora-style glowing animation।
- Moving Waves — animated wave effect দিয়ে modern footer design।
- Light Sweep Effect — Subtle light sweep animation over the footer.
- Custom Primary Color — You can set your own main animation color.
- Custom Secondary Color — secondary gradient/effect color control।
- Animation Speed Control — Slow, medium or fast animation speed can be adjusted.
- Intensity Control — You can control how strong or soft the animation effect will be.
- Multiple Animation Styles — Different footer effects can be selected from AdminCP.
- Mobile Control — Animation can be enabled/disabled on mobile devices.
- Fully Responsive — displays beautifully on desktop, tablet, and mobile.
- Light & Dark Style Support — Compatible with light and dark XenForo themes.
- Reduced Motion Support — user-এর system accessibility preference respect করে।
- CSS-Based Animation — unnecessary heavy JavaScript dependency নেই।
- Lightweight Performance — forum loading speed-এর উপর minimal impact।
- No Core File Edits — No need to modify XenForo core files.
- Easy AdminCP Configuration — All settings can be managed from the Admin Control Panel.
- Theme Friendly — Easily integrates with various custom XenForo styles.
- Clean Footer Integration — Works with existing footer links and layouts.
- Modern Visual Experience — General f
