[XenHub] Header Particles is a lightweight, modern and fully customizable header animation add-on for XenForo 2.3. It displays beautiful animated particles in the header, navigation and sub-navigation areas of your forum, which move from the bottom to the top, following different random paths.
ACP allows you to easily control the color, shape, size, density, speed, opacity, glow, twinkle, movement, and display area of particles. No external libraries are required, so the add-on is lightweight and performance-friendly.
Key Features
Continuous Particle Animation — Particles will continue to rise from the bottom up.
Random Movement Path — Each particle can follow a different random/zig-zag path
Primary & Secondary Color — Two different particle colors can be used
Two-Color Mode — two types of color effects at once
Multiple Particle Shapes- Square
- Circle
- Diamond
- Triangle
- Star
- Random Mix
Glow Effect — Add glow around particles
Twinkle / Brightness Effect — particles চলার সময় subtle brightness animation
Particle Size Control — The size of the particle can be determined
Random Size Variation — You can make all the particles random size instead of keeping them the same size.
Speed Control — animation speed can be made fast or slow as needed
Random Speed Variation — The speed of each particle may be slightly different
Horizontal Drift — particle can move left and right
Vertical Movement Control — upward movement distance can be controlled
Particle Density Control — show more or less particles
Opacity Control — particle transparency can be controlled
Header Area Support — effects can be displayed in the main header
Navigation Support — navigation area-তে particle animation
Sub-Navigation Support — section links/sub-navigation area support
Mobile Support — option to turn animation on/off on mobile devices
Reduced Motion Support — user-এর reduced-motion preference respect করে
ACP Settings — All configurations can be done from the XenForo Admin Control Panel
Lightweight Vanilla JavaScript — no third-party animation library required
Performance Friendly — runs animations without disrupting the forum's normal functionality
