Additional requirements : Php 8.1 to php 8.5
Replaces the default editor with Tip Tap.
Features:
Version 1.4.36 :
1. Inline code — toggleCode
2. Horizontal rule — setHorizontalRule
3. Task list (checkbox / to-do list) — toggleTaskList
4. Clear formatting — removes marks + block formatting from the selection
5. Indent / outdent — nest/unnest list items
6. Fullscreen — expand the editor to fill the screen (Esc to exit)
7. Word / character count — live counter at the right of the toolbar
FIX: Dual Bbcode turned into one with the Rich Text Editor.
Version 1.4.37 : Unfortunately the previous fix didn't work out
Version 1.4.38 : Didn't upload correct files
Télécharger V1.4.38 :
Version 1.4.42 woops : Didn't upload correct files
Version 1.4.43 : Bug fixes and Feature Additions :
Features:
- Grammar Checker(set in the admin panel)
- Spell Checker(set in the admin panel)
- Speech to Text(set in the admin panel)
- Gif search(set in the admin panel)
- Emoji Picker
- Dark Light Mode
- Color Highlighter
- Ability to change the editor to the top in the admin panel
- RTL Support
Version 1.4.36 :
- Fixed deletion issues
- Fixed ident issues
- Fixed keyboard issue
- Added custom colors
- Added spoilers
- Added the ability to use your own gifs
