D.C Style - Attachment view
Note
As the previous versions of this add-on still have some errors and have some unrelated functions, we decided to remaster it. From now on, our "Thumbnail" add-on will only cover the thumbnail functions. The "Cover" add-on will be released soon.
Introduce
Allow users to edit thumbnail images for their threads.
Version 1.0.0 Remastered :
After installing, go to AdminCP -> Tools -> Rebuild caches -> Rebuild thread thumbnails to fetch default thumbnails for all threads. This helps increase performance.
Version 1.0.1 :
Fixed error when rebuilding thread thumbnails.
Fixed no thumbnail link error.
Optimized external images getting function.
Version 1.0.1 Patch Level 1 : Fixed thumbnail function error.
Version 1.0.1 Patch Level 2 : Fixed error when deleting threads.
Télécharger V1.0.1 Patch Level 2 :
Version 1.0.2 :
Fixed error not rebuild threads that already have a thumbnail.
Added option to enable/disable external images.
Added option to enable/disable media thumbnail images.
Added thumbnail to posts/threads on the search result (can be enabled/disabled in options).
Optimized performance.
Version 1.0.2 Patch Level 1 : Fixed error when rebuilding (with temporarily deleted threads).
Version 1.0.2 Patch Level 2 : Fixed error while rebuilding threads.
Télécharger V1.0.2 Patch Level 2 :
Version 1.0.2 Patch Level 3 :
Fixed error not getting images in thread correctly.
Fixed some display errors.
Télécharger V1.0.2 Patch Level 3 :
Version 1.0.2 Patch Level 4 :
Minor bugs fixed.
Requires [D.C Style - Attachment View]
Télécharger V1.0.2 Patch Level 4 :
Version 1.0.2 Patch Level 5 :
Add the possibility to set maximum image dimensions for custom-uploaded thumbnails.
Add the possibility to set whether a thread is "video-thread" (Auto-detect by default). If a thread is set to be video-thread, its thumbnail will have an additional play icon.
Minor bugs fixed and improved performance.
Télécharger V1.0.2 Patch Level 5 :
Version 1.0.2 Patch Level 6 : Fix minor HTML errors when displaying thumbnail.
Télécharger V1.0.2 Patch Level 6 :
Version 1.0.2 Patch Level 7 : Optimized some CSS.
Télécharger V1.0.2 Patch Level 7 :
Télécharger V1.0.2 Patch Level 8:
Télécharger V1.0.2 Patch Level 9 :
Version 1.0.4 :
- Add compatibility to XF 2.3
Télécharger V1.0.4 :
Version 1.1.4 Patch Level 1 :
Version 1.0.5 :
- Add posibility to use user avatar when thread has no thumbnail if possible (Refer to the case of @El Porcharo here: D.C Style - Thumbnail)
- Add posibility to set the thumbnail width & height for thread list and widgets separately (Refer to the case of @Capturimage here: D.C Style - Thumbnail)
Note:
In order to the feature "Use user avatar when thread has no thumbnail" to working properly, please rebuild thread thumbnails by visit AdminCP -> Tools -> Rebuild caches -> "Rebuild thread thumbnails" (check the box "Rebuild threads already have thumbnail") and rebuild.
Version 1.0.5 Patch Level 1 :
Version 1.0.5 Patch Level 2 :
- Added possibility to enable/disable Gravatar when using user avatar to display if thread has no avatar (Refer to the case of @ekool here: D.C Style - Thumbnail)
- Added possiblity to select "All forums" without having to update forum list manually if there were new forums (Refer to the case of @ekool here: D.C Style - Thumbnail)
Version 1.0.5 Patch Level 3 :
- Added posibility to make thumbnail auto rebuilt after thread first post changes (Refer to the case of @Capturimage here: D.C Style - Thumbnail)
Télécharger V1.0.5 Patch Level 3 :
Version 1.0.5 Patch Level 4 :
Version 1.0.5 Patch Level 5 : Fixed error "syntax error, unexpected '->' (T_OBJECT_OPERATOR)"
Télécharger V1.0.5 Patch Level 5 :
Version 1.0.5 Patch Level 6 : Fixed errror undefined array keys when install / upgrade
Télécharger V1.0.5 Patch Level 6 :
Version 1.0.6 :
Note: This version requires XF 2.3+
Version 1.0.6 Patch Lecvel 1: Remove the dependency of add-on
Télécharger V1.0.6 Patch Level 1 :
Version 1.0.6 Patch Lecvel 2: Fix error table "xf_dcThumbnail_thumbnail" doesn't exist when install the add-on
Télécharger V1.0.6 Patch Level 2 :
Version 1.0.7 :
Version 1.1.0 :
Note
Note : Please uninstall our previous "Thumbnail" add-on before installing this remastered version.
Introduce
- Customize thumbnail for each thread. Supports attachment images, external images, and thumbnail from videos on Youtube, Vimeo, and Dailymotion (updating…).
- Allow custom upload thumbnail image.
- Add
og:imagetag for Facebook sharing. - Supports permission for each member group.
- Unzip
- Upload all contents in upload folder to public_html folder
- Go to AdminCP -> Add-ons -> Install
- Go to AdminCP -> Options -> Thumbnail for configurations.
- Go to AdminCP -> Tools -> Rebuild caches -> Rebuild thread thumbnails to fetch default thumbnails for all threads. This helps increase performance.
- Go to AdminCP -> Groups & Permissions -> Group -> D.C Style - Thumbnail for permission configurations.
Version 1.0.1 :
Version 1.0.2 :
Minor bugs fixed.
Version 1.0.2 Patch Level 8
- Fixed bug threads didn't automatically apply thumbnails in some cases.
Version 1.0.2 Patch Level 9
- Fixed error: "thread_id" values must be unique
Version 1.0.4 :
- Add null safety check for "isContainingMediaBbCode" function in Thumbnail repository (Refer to the case of @Otto here: D.C Style - Thumbnail)
Version 1.0.5 :
Note:
- Fixed crash when upgrading to the new version (Refer to the cases of @Capturimage & @fiebrelectora here: D.C Style - Thumbnail and D.C Style - Thumbnail)
- Fixed bug opening thumbnail URL instead of thread URL (Refer to the case of @Capturimage here: D.C Style - Thumbnail)
- Fixed error with thumbnail template macros in tag view page (Refer to the case of @fiebrelectora here: D.C Style - Thumbnail)
- Fixed error when editing thumbnail in threads (Refer to the case of @fiebrelectora here: D.C Style - Thumbnail)
- Fixed error missing thumbnail for redirect threads
- Fixed the thumbnail height issue (Refer to @Capturimage here: D.C Style - Thumbnail)
Version 1.0.6 :
- Update new feature: Auto optimize external images when selecting them as thumbnail
- Update new feature: By default, display thumbnail version of attached images instead of full-sized
- Update new thumbnail selector UI
D.C Style - Attachment ViewTélécharger V1.0.6 Patch Level 1 :
Version 1.0.7 :
- Generate thread thumbnails from configured custom BBCode tags, including TMDB and IMDb tags.
- Optionally fetch movie and TV posters through TMDB when a tag does not render an image. IMDb IDs are resolved through TMDB.
- Posters take priority during automatic selection, while manual thumbnail choices remain protected.
- Added rebuild missing posters command for older threads from the ACP.
Version 1.1.0 :
- Adds configurable source priority and automatically generated cards.
- Adds possibility to prefer real images, author avatars or your own card design.
- Adds possibility for cards to show a thread title, author, publication date/time, forum, board name and custom text.
