- SparkPost account
- PHP v8.1
Adds a SparkPost mail transport option to have all mails sent via your SparkPost account.
This is the XF v2.3 compatible version of SparkPost Mail Transport for XF 2.2 and has been completely rewritten to support Symfony Mail that is used in XF v2.3
This addon has full bounced email and unsubscribed email handling support using the SparkPost Events API - no mailbox required.
Compatibility
Version 3.x of this addon will only work on XenForo 2.3.x - do not try to install it on an earlier version.
You may upgrade between addon versions once you have upgraded your forum version.
Setup
If you haven't already done so, you will need to configure a sending domain for your forum in your SparkPost account. It is highly recommended that you also set up a default bounce domain.
You will then need to create an API key with the following permissions:
Configuration
As per the screenshot above - you may configure some transport options when configuring SparkPost.
There is an additional configuration page under the SparkPost Mail option heading:
You can test the functionality of the addon using the built in XenForo email test system - go to the admin UI > Tools > Test outbound email
Note the email transport class should be \Hampel\Symfony\Mailer\SparkPost\Transport\SparkPostApiTransport - if it isn't, then you haven't installed or activated the addon correctly.
There is also a second test facility which allows you to specify whether to send transaction or non-transactional emails. Go to the admin UI > Tools > Test SparkPost
Turn on the checkbox to send transactional email - turn it off to send non-transactional.
In all cases, you should examine the headers of the emails you receive to verify that it was indeed sent via SparkPost and to validate the presence/absence of the List-Unsubscribe header (the header should be present for non-transactional emails and absent for transactional emails).
Transactional vs Non-transactional Emails
Transactional emails are automated emails sent by a system to communicate with a customer or site user about information relevant to their account or usage of your site. They are typically specific to an individual user and are generally important to the user for the ongoing use of your site.
Examples of transactional emails are:
Examples of non-transactional emails are:
By default, SparkPost marks all emails sent through their API as "non-transactional". This addon changes that behaviour and sets all forum emails to transactional except for:
Bounce and Unsubscribe Handling
The automated bounce and unsubscribe handling in the addon will check for all of the standard hard and soft bounce calls that might be received as a result of sending emails. These bounced messages are intercepted by SparkPost and we can then execute a query to determine what action we need to take as a result.
You do NOT need to configure a "Bounced email address" (unless you don't have a default bounce domain set up) or "Unsubscribe email address" in your email options. Nor do you need to enable the "Automated email handler" or "Enable automated email handler" options - SparkPost does not forward bounced emails or unsubscribe notifications via email - we query their API to determine bounce / unsubscribe information.
Unsubscribe handling is a little more sophisticated than the standard XenForo system - since we differentiate between transactional and non-transactional emails and handle them differently.
Note that if we receive a hard bounce for transactional emails - the users account will be disabled to prevent further emails being sent.
Suppression lists
When SparkPost receives a hard bounce from a sent email or a List-Unsubscribe request, it will place that email address onto a suppression list which means that you can no longer send email to that user. This is in place to protect your sending reputation - since continuing to send email to an invalid or unsubscribed address is a spam indicator which could see you blocked from some mail providers.
The thing to be aware of is that if a users forum account has been disabled due to bounced emails, they will most likely have been added to the SparkPost suppression list as well. If you re-enable their account without changing email addresses, then they may not receive any emails from your site because sending to them is blocked by SparkPost.
If you are sure the email is now valid, you can remove them from the SparkPost suppression list - in the SparkPost admin console - SparkPost.
Just remember that there are two separate lists - one for transactional emails and one for non-transactional emails.
Télécharger V3.0.0 :
Version 3.0.1 bugfix - missing dependencies :
- Some composer dependencies were missing from the 3.0.0 release, causing issues with bounced email handling on some platforms that didn't already have those dependencies installed via other addons. This release fixes the issue.
Télécharger V3.0.1 :
Version 3.0.2 bugfix :
- v3.0.2 addresses a bug in an underlying SparkPost package which resulted in the from header not containing the forum title.
Télécharger V3.0.2 :
Version 3.0.3 bugfix - fix a bug in exception handling in AbstractHttpTransport :
- bugfix - fix a bug in exception handling in AbstractHttpTransport
Télécharger V3.0.3 :
Version 3.0.4 minor bugfix - assert admin permission on tools :
- Minor bugfix to explicitly enforce admin permissions on admincp tools.
Télécharger V3.0.4 :
Version 3.1.1 Updates :
Télécharger V3.1.1 :
asked for the logger, and Monolog's email handler builds a mailer to construct its channel, so the
two called each other until the stack was exhausted. The logger is now resolved on first use
- SparkPost account
- PHP v8.1
Compatibility
| XenForo 2.1 | SparkPost Mail Transport v1.x |
| XenForo 2.2 | SparkPost Mail Transport v2.x |
| XenForo 2.3 | SparkPost Mail Transport v3.x (this addon) |
Setup
- Events Search: Read-only
- Transmissions: Read/Write
Configuration
- Click Tracking turns on click tracking on all links in emails sent
- Open Tracking adds a tracking image to all emails sent to track opens
- Test Mode will append '.sink.sparkpostmail.com' to all recipient email addresses so we can test communication with SparkPost without actually sending any emails to the recipients.
- Message Events Batch Size allows you to configure how many events the system will attempt to retrieve in each batch. In general you shouldn't need to adjust this from the default.
- account creation and activation emails
- password resets and two-factor authentication
- security and account alerts
- notifications resulting from subscriptions or alert options the user has chosen
- purchase receipts and shipping notifications
- legal and important site notices
- newsletters
- sales offers
- new product updates
- email designed to increase user engagement and onboarding, etc
- Emails sent via the admin UI - Communication > Email users
- Welcome emails
- non-transactional emails have the List-Unsubscribe header added (overrides the header added by XenForo) for one-click unsubscribe requests in some email clients. Transactional emails do not contain this header.
- there are separate suppression lists for transactional and non-transactional emails. If someone unsubscribes from non-transactional emails, you can still send them important transactional emails like forum subscriptions and password resets. However, if someone unsubscribes or blocks you from transactional emails, you should disable their account, since you will no longer be able to email them about important forum information.
Suppression lists
- handle WhatsNewDigest emails in this addon rather than via adapter
- check for WndSparkPost adapter during setup and fail until it is removed - it is incompatible with this version
- change execution order of XF\Admin\Controller\Tools class extension
Version 4.0.0 (2025-09-03) - unreleased
- drop the usage of sparkpost/sparkpost package because it hasn't been updated in many years - write our own SparkPost
API wrapper instead - convert to using XF 2.3 classnames instead of short names
- add CLI commands to fetch message events, process message events and prune message events
- add monolog logging support for most functions
- convert email bounce processor into the MessageEventService
- move to latest version of hampel/symfonymailer-sparkpost to fix bug with ReplyTo headers
- latest composer dependencies
Version 4.0.1 (2026-09-03)
- bugfix: message event processing failed when the Monolog addon was not installed
- bugfix: SparkPost error details render correctly again on the outbound email test page - the
message, description and error code fields were empty and the code shown was the HTTP status
rather than SparkPost's own - remove a template modification which no longer matched any XenForo 2.3 template
- align the bundled Symfony packages with the versions XenForo itself ships, so that the versions
Composer resolves are the versions which actually run - latest composer dependencies, including hampel/symfonymailer-sparkpost 1.1.4
5.0.0 (2026-09-07)
- PHP 8.3.0 or later is now required - PHP 8.1 and 8.2 are no longer supported
- replace the bundled
hampel/symfonymailer-sparkposttransport and this add-on's hand-written
SparkPost API client with thehampel/sparkpostandhampel/sparkpost-transportpackages, which are
maintained and tested independently of the add-on - SparkPost API calls now go through XenForo's own outbound HTTP stack, so the board's proxy
configuration and its checks on untrusted requests apply to them - auto-replies and opt-in confirmations are no longer treated as delivery failures - an out-of-office
reply previously recorded a soft bounce against a recipient whose address works perfectly well - message event fetching now pages through SparkPost's own cursor, and honours the
Retry-After
period SparkPost sends when rate limiting instead of always waiting two minutes - test mode now rewrites the SMTP envelope rather than the
To:header, so a test message is
delivered to the sink while still reading as addressed to the real recipient - previously the
.sink.sparkpostmail.comsuffix was visible to whoever received one - the outbound email test page now reports how many recipients SparkPost rejected when it accepts a
transmission but refuses its recipients - remove the 47 unused
sparkpostmail_bounce_classification_*phrases - nothing displayed them - drop the
nesbot/carbondependency and its chain - latest composer dependencies
5.0.1 (2026-09-07)
- bugfix: boards running the Hampel/Monolog add-on with its log-by-email option enabled hit
Maximum call stack size reached on every page that sent mail - building the SparkPost transport asked for the logger, and Monolog's email handler builds a mailer to construct its channel, so the
Version 5.1.0 (2026-10-14)
Addon now uses the well-testedhampel/sparkpost and hampel/sparkpost-transport packages for sending and communicating with SparkPost.- new:
sparkpost:configreports what this forum is set up to do and where each value came
from - the selected transport, whether an API key is set and which host it points at, test mode,
click and open tracking, the message event page size and the fetch watermark. It never prints the
key itself, so its output is safe to paste into a support thread - new:
sparkpost:validateproves the forum can actually do it: the container wiring, the
message event table, the cron entries and the fetch watermark, then one authenticated read from
SparkPost to confirm the API key is accepted. It sends no mail.--unattendedskips that call for
an unattended check, and--strictexits 2 on warnings rather than 0 - bugfix: with the log level set to
debug, every outgoing email was written to the log in full -
subject, HTML body and text body - which on a busy forum meant every notification and every
password-reset link. Only a description of the send is logged now. This needshampel/sparkpost
1.1.1, which is included - bugfix: a bounce classification introduced by a later release of
hampel/sparkpostno longer
stops the message event processing job with anUnhandledMatchError. An unrecognised
classification takes no action against the recipient and is logged as a warning instead - XenForo 2.4 readiness: every
log()this add-on implements now declares a void return type.
Without it, the add-on would fail fatally on the first email sent once XenForo ships psr/log 3 - the log channel is now requested through
Hampel/Monolog5.x'schannel(), falling back to
newChannel()on 4.x. The channel name is unchanged, so a per-channel log level set in
config.phpkeeps working - the add-on now declares which of its settings are secrets, so a forum running the Admin API can
report the rest of them - bugfix: a spelling mistake in the message shown when the incompatible
Hampel/WndSparkPost
adapter is installed
THANKS
