Sort Warnings 1.0.2
XF 2.1 / 2.2 / 2.3 Sort Warnings 1.0.2
Sort Warnings 1.0.2
Titre du sujet Titre du sujet Sort Warnings 1.0.2
Réponses Réponses 3
Affichages Affichages 115
Sorts warnings alphabetically (using natcasesort), rather than the default, which is by points.
Admin UI:
Before :
After :
Warn member:
Before :
After :
Version 1.0.1 (2025-12-12)​
- run enqueuePostUpgradeCleanUp during upgrades if we're running XF2.3+
Version 1.0.2 (2026-10-14)​
  • requires XenForo 2.2.0 or later
  • declares to the Admin API add-on, where it is installed, that this add-on has no secret settings, using the hampel_admin_api_redaction code event; nothing is required or changed where it is not
  • the add-on description now says which lists are sorted
