Redis backed view counters 2.6.2
XF 2.1 / 2.2 / 2.3 Redis backed view counters 2.6.2
Titre du sujet Titre du sujet Redis backed view counters 2.6.2
Réponses Réponses 7
Affichages Affichages 534
Moves some view counters to use Redis-based increment counters rather than scratch tables in MySQL. Redis provides atomic get & del when pushing view counts totals into the database.
Note ;
  • Currently only handles thread or attachment views.
  • There is an effective limit of ~100000 threads that can be updated per 'Update View Counters' cron task run.
Contributing features or bug fixes
Please create a GitHub Pull request via the "Find more info at github.com..." link.
php 7.0+
Redis Cache add-on
Redis (v3.0.0 or better)
Télécharger V2.1.0 :
Version 2.2.0 - Feature update : Add support for page view counts
Télécharger V2.2.0 :
Version 2.3.0 : This add-on is now available on atelieraphelion.com
  • Require php 7.2+
  • Require XenForo 2.2+
  • Require Redis v3.0.0+
  • Remove deprecated code, hard requiring Redis v2.6+
  • Fix page views where not being updated as expected
  • Add support for @Bob's Article Management System
  • Add support for XenForo Resource Manager
Télécharger V2.3.0 :
Version 2.4.0 : XF2.3 Compatibility update
  • Requires StandardLib v1.19.0+
  • Requires Redis Cache v2.17.0+
  • XF2.3 compatibility update
Télécharger V2.4.0 :
Version 2.4.1 - Maintenance update :
  • Restore XF2.1 support
  • XF2.3 support requires Redis Cache v2.17.0+
Télécharger V2.4.1 :
Version 2.5.0 - Maintenance update :
  • Adjust add-on title to be "Redis backed view counters"
  • Require StandardLib v1.22.0+
  • Fix Redis Cache dependency did not report the required version correctly
  • Implement content view updates in a background job instead of a blocking process during the cron-tasks
Télécharger V2.5.0 :
Version 2.6.0 - XF2.3 compatibility fix :
  • Require StandardLib v1.23.0+
  • Implement support for XF2.3 activity log view metrics
    • Requires updating ElasticSearch Essentials to v3.18.3+ if view counts are being pushed into search
Version 2.6.1 - Bugfix update :
  • Fix "all to a member function batchDatabaseUpdate() on null" when
  • Fix new view counts would be lost for Page node-type when bb-code pages add-on was not install
Version 2.6.2 - Bugfix update :
  • Fix "incrementalBatchUpdateViews(): Argument #3 ($batch) must be of type int, float given" due to strict_types flag
  • Depends on how long the job takes to run and how the AbstractJob::calculateOptimalBatch behaves as it can return int, but is inconsistent about it.
Télécharger V2.6.2 :
