Redis backed flood checking 2.3.1
XF 2.1 / 2.2 / 2.3 Redis backed flood checking 2.3.1
Titre du sujet Titre du sujet Redis backed flood checking 2.3.1
Réponses Réponses 5
Affichages Affichages 422
Redis Cache add-on
Redis (v3.0.0 or better)
Moves flood checking use Redis-based atomic keys rather than scratch tables in MySQL
Télécharger V2.0.4 :
Version 2.1.0 : This add-on is now available on atelieraphelion.com
  • Require php 7.2+
  • Require XenForo 2.2+
  • Require Redis v3.0.0+
  • Support fractions of seconds when doing flood checks (with 1 millisecond resolution)
Version 2.1.1 : Remove debug code forcing a 10s flood check limit
Télécharger V2.1.1 :
Version 2.2.0 : XF2.3 Compatibility update
  • Requies StandardLib v1.19.0+
  • Require Redis Cache v2.17.0+
  • XF2.3 compatibility update
Télécharger V2.2.0 :
Version 2.3.0 - Maintenance update :
  • Adjust add-on title to be "Redis backed flood checking"
  • Require StandardLib v1.22.0+
  • Re-add XF2.1 support
  • Tighten up type checking of data sent to/from redis
Télécharger V2.3.0 :
Version 2.3.1 - Bugfix update :
  • Fix flood check with a non-integer value would clamp to a flood value of 1s
  • This only would effect 3rd party code as all XF flood checks use integer values
Télécharger V2.3.1 :
