- Development mode enabled
This is a tool I have been using because I find it annoying to have to login to the Admin CP repeatedly on my local installations. As per the title, this add-on will allow you to be automatically signed in to the admin control panel under configured conditions.
Never run this in production. This add-on signs you into the Admin control panel without a password. Use it only on a local, single-user development install. Do not enable it on any server others can reach, or on any install holding real member data.
Features
- Automatically signs you in to your admin control panel, completely bypassing the login panel.
- Multiple security requirements are enforced for this to run properly:
- Development mode is a requirement.
$config['development']['enabled'] = true; - Our specific config flag must also be enabled.
$config['mcBypassAdminLogin'] = true; - Your username must be added to the allowed admins list.
- Your IP Address must be configured, unless you explicitly allow any source.
- Optionally enable denied login attempts logging. This is useful if you choose to use this on a live private and directory locked development installation. It also helps diagnose any failed login attempts due to any IP address issues.
- Includes optional email alerts as well.
127.0.0.1and::1are default to include local IP's for local installs.- IPv6 addresses should include it's /64 prefix since v6 addresses can rotate on a daily bases:
- Example:
2600:1700:28e0:45a0:dc65:ed44:5c30:2d37to2600:1700:28e0:45a0::/64
- Example:
- To allow any source, you must EXPLICITLY type in
0.0.0.0/0and::/0
