[ITD] Hide Avatar (Lite) is a simple yet powerful add-on designed for forum administrators who want better control over the visual layout of their community.
This add-on allows you to hide user avatars in specific forums (Nodes) within the thread view and quick reply areas. It is particularly useful for religious, serious, educational, or documentation-based forums where you may want to reduce visual distractions or follow specific display policies.
Key Features :
Pro Version (Coming Soon!)
We are already working on a Pro version with exciting new features :
Key Features :
- Node-Specific Control — Hide avatars only in selected nodes using a simple comma-separated list of Node IDs.
- Thread View Toggle — Easily enable/disable avatar hiding in thread posts.
- Quick Reply Toggle — Option to hide the visitor’s own avatar in the quick reply editor.
- Layout Stability — Carefully engineered to maintain perfect alignment even after hiding avatars.
- High Compatibility — Fully tested and working on XenForo 2.1, 2.2, and 2.3.
- Advanced Node Selector (no more manual ID entry)
- Replacement Mode (replace avatars with default placeholder or custom image)
- User Group Permissions (e.g., allow Staff to bypass hiding)
- Thread List View support
