Demo :
Video demo :
Télécharger V1.1.0 Bêta 2 :
Version 1.1.0 bêta 5 : Fix a few small bugs
Télécharger V1.1.0 Bêta 5 :
Version 1.1.1 :
Add compatibility with XenForo 2.2
Fix error sometimes list threads doesn't show up
Fix some CSS bugs
Improve performance
Version 1.1.2 :
Minor bugs fixed.
Code optimized.
Télécharger V1.1.2 :
Version 1.1.3 : Add new order "Last message" for widget "New Threads".
Version 1.1.3 Patch Level 1 :
Fix error rendering widget: Call to a member function repository() on null
Fix error [E_WARNING] Undefined array key "threadTitleLimit" in src/addons/DC/Widgets/Widget/RandomThreads.php at line 198
Télécharger V1.1.3 Patch Level 1 :
Version 1.1.3 Patch Level 2 : Fix error "Undefined array key threadTitleLimit".
Télécharger V1.1.3 Patch Level 2 :
Version 1.1.3 Patch Level 3 :
- Fixed missing thumbnail on Slide wide/narrow template on mobile.
Télécharger V1.1.3 Patch Level 3 :
Version 1.1.4 : Add the possibility to filter only threads with specific tags.
Télécharger V1.1.4 :
Version 1.1.4 Patch Level 1 : Fix error after clearing all specified tags, the widget doesn't show any threads.
Télécharger V1.1.4 Patch Level 1 :
Version 1.1.5 Patch Level 1 :
- Fixed "thread_action_buttons() error" (Refer to the case of @Enes3078 here: D.C Style - Widgets)
Télécharger V1.1.5 Patch Level 1 :
Version 1.1.5 Patch Level 2 :
- Fixed error when create a thread redirect.
Télécharger V1.1.5 Patch Level 2 :
Version 1.1.5 Patch Level 3 :
- Update JS code to work in case there are no JQuery
Télécharger V1.1.5 Patch Level 3 :
Version 1.1.5 Patch Level 4 : Replace SwiperJS CSS link rel="stylesheet" tag to
Télécharger V1.1.5 Patch Level 4 :
Version 1.1.5 Patch Level 5 :
- Fixed SQL performance leaks when using
Télécharger V1.1.5 Patch Level 5 :
Version 1.1.6 :
Refer to the suggestion from @Tamasita post: https://xenforo.com/community/threads/d-c-style-widgets.185181/page-5#post-1795973
Video demo :
Version 1.1.1 :
Fix some CSS bugs
Improve performance
Version 1.1.2 :
Minor bugs fixed.
Code optimized.
Version 1.1.5 New Feature Updates :
This version contains some significant feature updates as detailed below. Please read carefully to understand how they work!
(Refer to suggestion of @Enes3078 here: D.C Style - Widgets)
Individual Widget Promotion
From this version, each widget can be set to be promotable by specific user groups. This adds more flexibility for you to control how each widget is displayed on your website!
Additionally, a user group can be set to always have permission to promote their own threads to "all" widgets, regardless of the widget configurations.
Also, you can grant a user group permission to promote any threads to widgets.
Time Limit on Promotion Actions
You can now set a minimum time limit between user promotion actions.
Schedule Widget Promotion
You can now schedule a thread to be promoted or unpromoted at a specific time.
Widget Action Log
You can view the users' log by visiting AdminCP -> Logs -> Widget Action Logs.
Widget Action Log
<xf:css src="https://cdn.jsdelivr.net/npm/swiper@11/swiper-bundle.min.css" />
Random threads widget on a large forum (Refer to the issue from @Goldex post: https://xenforo.com/community/threads/d-c-style-widgets.185181/post-1767232 )Télécharger V1.1.5 Patch Level 5 :
Version 1.1.6 :
- Added Forum order sorting: sticky threads first, followed by the selected forum’s saved sorting settings.
- Added sticky-first, latest-activity ordering when combining multiple forums.
- Fixed missing child forums when using “Current forum and its child nodes”.
- Fixed Forum order widgets showing too few entries after inaccessible or ignored threads were skipped.
