About
Note: v2.0 of this addon is a re-release of my existing "
This addon creates additional BBCodes for linking to various content found on XenForo forums:
I've basically aimed to reproduce the original vBulletin (v3.8.x) functionality of simply rendering a link to a thread or post with the user supplied link text - if the user does not have permission to access the thread or post, they'll find out when they click the link! Thread titles are not rendered automatically, so there is no risk of information leakage.
The main reason you'd want to use this addon is if you have migrated content from vBulletin or another forum which uses
The additional BBCode tags were added primarily to support some forum statistics scripts I had written for my sites as I needed a way of programmatically generating links which were also independent of the site URL.
If you just want to use the thread and post tags, you can always disable the other custom bbcode tags in the admin UI.
Requirements
This addon requires PHP 5.4 or higher and has been tested on XF v2.0, v2.1 and v2.2
The
Usage
In post content (or anywhere that BBCode is allowed), the following substitutions will occur:
THREAD
... will be rendered as:
Alternative syntax:
POST
SEARCH
Examples:
TAG
Examples:
XFMG
[Examples:
You can also display full sized images:
|CODE=rich][xfmg=img,1][/xfmg][/CODE]
Note that if lightbox is enabled for images - the image will be rendered using the standard lightbox template in the same way that the IMG bbcode tag works.
Similarly, you may display a thumbnail as follows:
Unlike other links, images and thumbnails will only display if the user has permission to view them.
FORUM
Examples:
PREFIX
Examples:
RESOURCE
Télécharger V2.0.2 :
Télécharger V2.1.1 :
[thread] and [post] BBCode" addon with a new addon ID. If you previously used this addon, it should automatically upgrade when installing this new version - but otherwise, just uninstall the old addon before installing this new one - no data will be lost.This addon creates additional BBCodes for linking to various content found on XenForo forums:
- thread
- post
- search (see below for details)
- tag
- xfmg
- media
- category
- album
- image
- thumbnail
- forum (node)
- prefix
- thread
- resource
- resource
- forums
- threads
- posts
- resources
- media
- media comments
- user profiles
- tags
- Google
- site search
- web search
- image search
- map search
- video search
- news search
[THREAD] and [POST] BBCodes which were used in vBulletin and may be present in post content after migration.I've basically aimed to reproduce the original vBulletin (v3.8.x) functionality of simply rendering a link to a thread or post with the user supplied link text - if the user does not have permission to access the thread or post, they'll find out when they click the link! Thread titles are not rendered automatically, so there is no risk of information leakage.
[thread] and [post]BBCodes.The additional BBCode tags were added primarily to support some forum statistics scripts I had written for my sites as I needed a way of programmatically generating links which were also independent of the site URL.
Requirements
The
[thread] and [post] component of this addon basically does the same job as @Xon's Thread & Post BB Code for XF2 addon - but mine is (deliberately) much less sophisticated and does no permission checking or thread/post lookups. You should not install both addons!Usage
THREAD
Rich (BB code):
[thread=1]see this thread[/thread]
HTML:
<a href="http://www.example.com/threads/1/">see this thread</a>
Alternative syntax:
Rich (BB code):
[thread]1[/thread]
HTML:
<a href="http://www.example.com/threads/1/">http://www.example.com/threads/1/</a>
POST
Rich (BB code):
[post=2]see this post[/post]
HTML:
<a href="http://www.example.com/posts/2/">see this post</a>
SEARCH
Examples:
Rich (BB code):
[search]foo[/search] (default is to search entire forum - search term between tags)
[search=forum]foo[/search] (general forum search - search term between tags)
[search=forum,foo]search the forums for 'foo'[/search] (general forum search - search term as option)
[search=thread,foo]search threads for 'foo'[/search]
[search=post,foo]search posts for 'foo'[/search]
[search=resource,foo]search resources for 'foo'[/search]
[search=media,foo]search media uploads for 'foo'[/search]
[search=comments,foo]search media comments for 'foo'[/search]
[search=tag,foo]search tags for 'foo'[/search]
[search=site,foo]Google site search for 'foo'[/search] (search google with 'site:example.com' tag to perform a Google search of your site
[search=web,foo]Google web search for 'foo'[/search]
[search=image,foo]Google image search for 'foo'[/search]
[search=map,foo]Google map search for 'foo'[/search]
[search=video,foo]Google video search for 'foo'[/search]
[search=news,foo]Google new search for 'foo'[/search]
TAG
Examples:
Rich (BB code):
[tag=foo bar]link to the tag 'foo bar'[/tag]
HTML:
<a href="http://www.example.com/tags/foo-bar/">link to the tag 'foo bar'</a>
XFMG
[Examples:
Rich (BB code):
[xfmg=media,1]link to media item with id = 1[/xfmg]
[xfmg=album,1]link to album with id = 1[/xfmg][/ICODE]
[xfmg=category,1]link to category with id = 1[/xfmg]
HTML:
<a href="http://www.example.com/media/1/">link to media item with id = 1</a>
<a href="http://www.example.com/media/albums/1/">link to album with id = 1</a>
<a href="http://www.example.com/media/categories/1/">link to category with id = 1</a>
HTML:
<img src="http://example.com/media/1/full" data-url="http://example.com/media/1/full" class="bbImage" data-zoom-target="1" alt="">
Rich (BB code):
[xfmg=thumb,1][/xfmg]
FORUM
Examples:
Rich (BB code):
[forum=1]link to this forum node[/forum]
HTML:
<a href="http://www.example.com/forums/1">link to this forum node</a>
PREFIX
Examples:
Rich (BB code):
[prefix=forum,1,2]link to this prefix for a node[/prefix] (ie show all threads from node_id = 1 using prefix_id = 2)
[prefix=resource,0,1]link to this prefix for a resource[/prefix] (ie show all resources using prefix_id = 1)
[prefix=resource,2,3]link to this prefix for a resource category[/prefix] (ie show all resources from category_id = 2 using prefix_id = 3)
HTML:
<a href="http://www.example.com/forums/1/?prefix_id=2">link to this prefix for a node</a>
<a href="http://www.example.com/resources/?prefix_id=1">link to this prefix for a resource</a>
<a href="http://www.example.com/resources/categories/2/?prefix_id=3">link to this prefix for a resource category</a>
RESOURCE
Rich (BB code):
[resource=1]link to this resource[/resource]
HTML:
<a href="http://www.example.com/resources/1">link to this resource</a>
2.0.3 (2025-12-11)
- run enqueuePostUpgradeCleanUp during upgrades if we're running XF2.3+2.1.0 (2026-09-26)
- requires XenForo 2.2.0 or later - XenForo 2.0 and 2.1 are no longer supported
- fix a
TypeErrorwhich prevented a post being saved when its[xfmg]link text began with formatting, eg[xfmg=media,1][b]text[/b][/xfmg] - fix
[search]search terms: a term given in the option keeps its spaces, terms are no longer encoded twice, and Google searches no longer contain HTML entities - fix
[search=tag]links, which were built from the encoded search term - fix the
[xfmg=thumb]fallback link shown to visitors who cannot view the media item - fix
[prefix]and[tag]link text being escaped twice [xfmg]link text now renders nested BB code- a search term given in the
[search]option may now contain commas - every tag now renders a plain link in signatures and emails (the simple and email renderers), as
[thread]and[post]already did
Version 2.1.1 (2026-10-11)
- declare that the add-on has no secret settings, via thehampel_admin_api_redaction code event - no effect unless an add-on that defines that event is installedTélécharger V2.1.1 :
