AndyB Staff 1.0
XF 2.3 AndyB Staff 1.0
AndyB Staff 1.0
Titre du sujet Titre du sujet AndyB Staff 1.0
Affichages Affichages 1
Displays a widget of current staff.
(Example of page node) :
(Example of Staff widget) :
All phrases start with staff_ for your convenience.
Node setup :
Follow these steps if you want to create a page node.
  1. From the Admin Control Panel select Forums -> Nodes.
  2. Click the Add node button.
  3. Node type = Page.
  4. URL portion = staff.
  5. Title = Staff
  6. Template HTML = <xf:widget key="staff" />
  7. Click Save.
Widget setup :
  1. From the Admin Control Panel select the Widgets under the Appearance tab.
  2. Click the Add widgets button.
  3. Select the Staff widget.
  4. Widget key = staff
  5. Title = (leave blank)
  6. Display in positions = Forum list: Above nodes
  7. Click Save.
User group permissions :
Registered = View
Unregistered / Unconfirmed = View
Questions and answers :
Q: When does the widget get updated?
A: The widget is updated by cron entry at the top of the hour. You can run the cron entry manually if you don't want to wait.
