Ajoutez un subtil effet de tempête de neige à votre communauté Xenforo pour les vacances ou l'hiver.
Télécharger V1.0.4 :
Version 1.0.5 : Fixed bug whereby page X views setting wasn't enumerated on light-weight theme
Télécharger V1.0.5 :
Version 1.1.0 - Latest script and added ability to customize JS for 'Snow Storm' :
Version 1.2.0 :
Version 1.2.1 - Fixed issues :
Version 1.3.0 :
Version 1.3.1 XF 2.3.x fix : FIX: Disabling snowstorm effects from account preferences is now visible in XF 2.3.x
Télécharger V1.3.1 :
Version 1.4.0 :
Version 1.4.1 :
- Enable the effect
- Enable/Disable for mobile
- Choose usergroups to ignore
- Fully multilingual and internationalized
- Added textarea option to set JS customizations for SnowStorm
- See: JavaScript Snow: DHTML Snowstorm. Making it snow on the internets since 2003.
- Updated to v1.44.20131215 snowstorm.js
- Added appropriate javascript path for addon js/wutime/snowstorm/*.js
- Added setup installer and included Snow Storm icon image
Version 1.2.0 :
- Added: User preference setting
- Added: Ignore snow effects globally based on user preference
- User preference database setting on install/upgrade
- Removem preference on install
- Fixed: Snow not working
- Added: Defer JavaScript
- Removed minified javascript for now because it seems to gimp the snow.js effect (not sure if it's a new chrome browser issue or not)
Version 1.3.0 :
- UPDATE: light-weight snow to v0.0.4 for compatability with XF 2.3x, document.write() and defer
- ADD: link and create proper minified JS for production systems
- UPDATE: build.json for updated *.min.js using UglifyJs
- ADD: font-awesome 5 igloo icon to option group
Version 1.4.0 :
- ADD: new snow flake system (nextapps-de)
- ADD: optional seasonal schedule window (start/end date) for public snow rendering
- ADD: display scope option (everywhere, homepage only, selected forums only, everywhere except selected forums)
- ADD: forum include/exclude selectors for scope targeting
- ADD: templater_setup listener + wutime_snowstorm_is_mobile() template helper
- ADD: Detection\MobileDetect composer package for server-side mobile detection
- ADD: admin-only preview checkbox to render selected theme on SnowStorm options page for quick testing
Version 1.4.1 :
- FIX: Prevent snow falling behind the menu before reappearing when using "Snow Storm"
- FIX: Prevent snow falling behind the menu before reappearing when using "Snowflake (nextapps-de)"
