[Wutime] Snow storm effect 1.4.0
XF 2.1 / 2.2 / 2.3 [Wutime] Snow storm effect 1.4.0
Titre du sujet Titre du sujet [Wutime] Snow storm effect 1.4.0
Réponses Réponses 18
Affichages Affichages 809
Réaction Réaction 7
Ajoutez un subtil effet de tempête de neige à votre communauté Xenforo pour les vacances ou l'hiver.
  • Enable the effect
  • Enable/Disable for mobile
  • Choose usergroups to ignore
  • Fully multilingual and internationalized
Full credit for the JavaScript library to : JavaScript Snow: DHTML Snowstorm. Making it snow on the internets since 2003.
1655
Télécharger V1.0.4 :
Version 1.0.5 : Fixed bug whereby page X views setting wasn't enumerated on light-weight theme
Télécharger V1.0.5 :
Version 1.1.0 - Latest script and added ability to customize JS for 'Snow Storm' :
Version 1.2.0 :
  • Added: User preference setting
  • Added: Ignore snow effects globally based on user preference
  • User preference database setting on install/upgrade
  • Removem preference on install
Version 1.2.1 - Fixed issues :
  • Fixed: Snow not working
  • Added: Defer JavaScript
  • Removed minified javascript for now because it seems to gimp the snow.js effect (not sure if it's a new chrome browser issue or not)
Version 1.3.0 :
  • UPDATE: light-weight snow to v0.0.4 for compatability with XF 2.3x, document.write() and defer
  • ADD: link and create proper minified JS for production systems
  • UPDATE: build.json for updated *.min.js using UglifyJs
  • ADD: font-awesome 5 igloo icon to option group
Télécharger V1.3.0 :
Version 1.3.1 XF 2.3.x fix : FIX: Disabling snowstorm effects from account preferences is now visible in XF 2.3.x
Télécharger V1.3.1 :
Version 1.4.0 :
  • ADD: new snow flake system (nextapps-de)
  • ADD: optional seasonal schedule window (start/end date) for public snow rendering
  • ADD: display scope option (everywhere, homepage only, selected forums only, everywhere except selected forums)
  • ADD: forum include/exclude selectors for scope targeting
  • ADD: templater_setup listener + wutime_snowstorm_is_mobile() template helper
  • ADD: Detection\MobileDetect composer package for server-side mobile detection
  • ADD: admin-only preview checkbox to render selected theme on SnowStorm options page for quick testing
Télécharger V1.4.0 :
