- XFA RM Marketplace 5.8.5 or newer.
- XFA RM Marketplace Cart 1.1.4 or newer (optional).
- [OzzModz] RM Marketplace: Account Tabs 2.1.1 (optional).
- MySQL 8.0+.
Adds selectable purchase price options to XFA RM Marketplace resources while keeping customer-facing purchase and renewal choices inside XenForo.
Key Features:
Do not redistribute, resell, publish, share, provide, or make available modified copies without permission from the copyright holder, including private modifications.
Do not install this add-on on ****, illegal, or unsupported XenForo installations.
Important Note:
Back up your site and database before installing or upgrading marketplace payment add-ons. Payment profile routing and license durations should be tested on a staging site before production use.
Télécharger V1.0.0 Beta 5 :
- MySQL 8.0+.
Key Features:
- Selectable purchase price options for XFA RM Marketplace resources.
- Per-option title, purchase price, renewal price, license duration, default option, recommended option, and optional XenForo payment profile routing.
- AdminCP switches can hide buyer-facing Recommended labels or disable seller payment-profile selection. Disabling profile selection also ignores any previously stored per-option profile and restores RM Marketplace payment routing.
- Option-aware order totals, renewal totals, and license end dates.
- Optional automatic recurring payments for eligible timed initial purchases and license renewals through compatible XenForo payment providers.
- Native customer cancellation controls and a recurring-payment account page.
- Optional recurring-payment tab integration with [OzzModz] RM Marketplace: Account Tabs 2.1.1.
- Optional early license extension before RM Marketplace's normal renewal-delay window, including the OzzModz customer license tab.
- Optional XFA RM Marketplace Cart support for selected option IDs and option prices.
- Seller-facing price option management from existing RM Marketplace add/edit screens and the management overlay, with sortable rows, automatic row addition, draft restoration, responsive controls, and a global AdminCP option that limits the available choices per resource.
- Resource list, grid, featured, sidebar, purchase, and renewal displays use effective RM Marketplace/custom option prices instead of a free or zero fallback.
- Optional renewal option mode supports fixed renewal prices and percentage-based renewals from the original option amount.
- The default option is used when direct purchase requests omit the selected option ID.
- AdminCP settings are grouped under the existing XFA RM Marketplace options group with a dedicated tab.
- The Extend license button appears only before RM Marketplace's normal renewal-delay window. Inside that window, the native Renew now label remains.
- Extension time is added after the license's current expiration date, so extending early does not discard the buyer's remaining license time.
- The button is available in RM Marketplace license lists and in the [OzzModz] RM Marketplace: Account Tabs customer license tab when that add-on is installed.
- Disabling the AdminCP option immediately restores RM Marketplace's normal renewal-delay behavior.
- Recurring payment is an opt-in choice on eligible paid timed initial purchases and license renewals. The provider repeats the displayed checkout amount for each selected license term.
- Initial recurring checkout is limited to one digital license with quantity one. Gift purchases, coupons, physical products, lifetime terms, and multi-item carts remain one-time purchases.
- The selected XenForo payment profile must support the exact license interval.
- Coupons are intentionally rejected for recurring payments so later provider charges match the immutable recurring amount.
- The user can cancel an active agreement through the payment provider's native XenForo cancellation control. An ordinary unpaid checkout reservation can be cleared after 24 hours from the recurring-payments account page. A reservation whose provider outcome is unknown after an exception remains blocked so a retry cannot create a second remote agreement; an administrator must investigate the provider before resolving that reservation.
- Turn off the AdminCP recurring-payments option to stop new agreements while preserving existing callback fulfillment and cancellation. Do not disable or uninstall the add-on while provider-side recurring agreements still exist.
- Paid Marketplace resources, resource updates, and version downloads require an active validated license backed by a validated purchase or renewal order. The resource author retains access to their own files.
- Direct paid-update pages, resource-overview update previews, feeds, attachment access, notifications, and API update listings use the same entitlement check. An order-item status without a validated parent order is not sufficient.
- Category-level download-without-purchase permissions cannot bypass the paid Marketplace entitlement check for other users.
- Licensed Marketplace downloads continue through XenForo Resource Manager's native attachment or external-download flow.
- External download addresses are supplied and validated by XenForo Resource Manager; this add-on does not contact, proxy, rewrite, or independently redirect to external download services.
- The add-on adds an immutable license-entitlement check before XFRM returns API or webhook download metadata or serves the native download response.
Important Note:
