[TH] UI.X 2 2.1.4.0.0 a 2.3.7.0.0
XF 2.1 / 2.2 / 2.3 [TH] UI.X 2 2.1.4.0.0 a 2.3.7.0.0
Catégorie Catégorie Styles
Titre du sujet Titre du sujet [TH] UI.X 2 2.1.4.0.0 a 2.3.7.0.0
Réponses Réponses 38
Affichages Affichages 2 656
Ajout de la version 2.2.15.0.0 :)
Ajout de la version 2.2.15.0.1 :)
Ajout de la version 2.2.15.0.2 :)
Based off the tried-and-true methodologies of its XenForo 1 predecessor, UI.X continues to push the boundaries of intelligent design. With a basis in Google’s Material Design, the framework is backed by a team well-versed in the XenForo software making UI.X a wise choice for any forum. ThemeHouse has been building products for XenForo since day one of the software’s release and we aren’t going anywhere.
1119
Demo : ThemeHouse XenForo 2 Themes Demo
Télécharger V2.1.4.0.0 : [Contenu caché]
Version 2.1.5.0.0 Changelog :
XenForo 2.1.5 compatibility
Note : This release cannot be used on XenForo 2.0, it is exclusively for XenForo 2.1 only.
Télécharger V2.1.5.0.0 : [Contenu caché]
Version 2.1.6.0.0 :
Télécharger V2.1.6.0.0 : [Contenu caché]
Version 2.1.7.0.0 Changelog :
XenForo 2.1.7 compatibility
Télécharger V2.1.7.0.0 : [Contenu caché]
Version 2.1.8.1.0 changelog :
Télécharger V2.1.8.1.0 : [Contenu caché]
Version 2.2.0.2.0 :
Note :
This release cannot be used on XenForo 2.1, it is exclusively for XenForo 2.2 only.
Télécharger V2.2.0.2.0 : [Contenu caché]
Version 2.2.1.0.0 :
Note :
Télécharger V2.2.1.0.0 : [Contenu caché]
Version 2.2.2.0.0 Released :
Version 2.2.2.1.0 Released :
Télécharger V2.2.2.1.0 : [Contenu caché]
Version 2.2.3.1.0 Changlog :
Fixed an issue that caused nodes to disappear when upgrading to the last update.
Fixed JS packaging issues
Télécharger V2.2.3.1.0 : [TH] UI.X 2 2.3.1.0
Version 2.2.4.0.0 Changelog :
XenForo 2.2.4 compatibility
Added a feature that wraps the nav phrase in span for additional design options with the sidebar navigation
Fixed an issue on Legend that caused the login phrase to not be viewable on mobile
Fixed an issue that caused meta titles to not work properly
Fixed an issue with the overlay blur effect that caused page width issues on mobile when modals are opened
Fixed an issue with the Fab button which caused it to show above the text input area on mobile devices
Fixed an issue that caused the sticky tab bar to cover the entire screen when scrolled past certain points with either infinite scroll addons or with header wrapper disabled
Fixed an issue with the style property known as drop-down menus (beta) which caused random jumping when hovering over navigation items
Fixed an issue with the search bar drop-down button "Advanced" which lost its color in the last update
Fixed a height issue with overflow category nodes
Télécharger V2.2.4.0.0 : [Contenu caché]
Version 2.2.5.0.0 Changelog :
XenForo 2.2.5 compatibility
Note : This update does require a UI.X add-on update to function properly.
Version 2.2.5.1.0 Changelog :
Version 2.2.6.0.0 Changelog :
XenForo 2.2.6 compatibility
Télécharger V2.2.6.0.0 : [Contenu caché]
Version 2.2.7.0.0 Changelog :
XenForo 2.2.7 compatibility
Télécharger V2.2.7.0.0 : [Contenu caché]
Version 2.2.8.1.0 Changelog:
XenForo 2.2.8 compatibility
Mobile usability fixes
Télécharger V2.2.8.1.0 : [Contenu caché]
Version 2.2.9.0.0 Released Changelog :
XenForo 2.2.9 compatibility
Télécharger V2.2.9.0.0 : [Contenu caché]
Version 2.2.10.0.0 Released Changelog :
XenForo 2.2.10 compatibility
Multiple bugfixes
Télécharger V2.2.10.0.0 : [Contenu caché]
Version 2.2.10.0.1 Changelog :
Fixes for some notification/message placement configurations causing them to be inaccessible
Other minor bugfixes
Télécharger V2.2.10.0.1 : [Contenu caché]
Version 2.2.12.0.0 Changelog :
- Updated compatibility with XenForo 2.2.12
Télécharger V2.2.12.0.0 : [Contenu caché]
Version 2.2.13.0.0 Changelog :
- Updated compatibility with XenForo 2.2.13
Télécharger V2.2.13.0.0 : [Contenu caché]
Version 2.2.13.0.1 Changelog :
Minor update to properly hide JS back button on standard rendering methods
Télécharger V2.2.13.0.1 : [Contenu caché]
Version 2.2.13.0.2 Changelog :
Multiple optimizations and minor bugfixes
Télécharger V2.2.13.0.2 : [Contenu caché]
Version 2.2.15.0.0 Changelog :
  • Multiple optimizations and minor bugfixes
Télécharger V2.2.15.0.0 : [Contenu caché]
Version 2.2.15.0.1 Changelog :
  • Fix for postbit toggle
Télécharger V2.2.15.0.1 : [Contenu caché]
Version 2.2.15.0.2 Changelog :
  • Fix for clickable threads
Télécharger V2.2.15.0.2 : [Contenu caché]
Version 2.3.0.0.0 Changelog :
Updating for XF 2.3 compatibility
Note : This release cannot be used on XenForo 2.2, it is exclusively for XenForo 2.3 only.
Télécharger V2.3.0.0.0 : [Contenu caché]
Merci :)
Ajout de la version 2.3.0.0.1 :)
Ajout de la version 2.3.0.0.2 :)
Ajout de la version 2.3.1.0.0 :)
Ajout de la version 2.3.1.0.1 :)
Ajout de la version 2.3.2.0.0 :)
Ajout de la version 2.3.3.0.0 :)
Ajout de la version 2.3.3.0.1 :)
Ajout de la version 2.3.3.0.2 :)
Ajout de la version 2.3.4.0.0 :)
Ajout de la version 2.3.4.1.0 :)
Ajout de la version 2.3.5.0.0 :)
Ajout de la version 2.3.6.0.0 :)
Ajout de la version 2.3.7.0.0 :)
