Style Variation Default 1.1.1
XF 2.3 Style Variation Default 1.1.1
Titre du sujet Titre du sujet Style Variation Default 1.1.1
Réponses Réponses 9
Affichages Affichages 301
Adds an option to set the style variation default for guests
Version 1.0.0 Patch 1 :
- Due to a bad build (I probably should not release late at night, lol), version 1.0.0 contained a bad event listener definition in the XML and therefore could not be installed.
- 1.0.0 Patch 1 contains the correct XML
Télécharger 1.0.0 patch 1 :
Version 1.0.0 Patch 2 :
- Hot on the heels of 1.0.0 Patch 1 comes ... 1.0.0 Patch 2.
A recently discovered 1 character typo caused a fatal error if guest page caching was enabled; this is now fixed so guest page caching should work just fine and respect the default.
Télécharger 1.0.0 patch 2 :
Version 1.1.0 Patch 1 New Features :
  • Search for users by style variation
  • Update user style variation setting via batch user update
  • Change user style variation setting via edit user
Télécharger 1.1.0 patch 1 :
Version 1.1.1 : Fixed class extensions for compatibility with XenForo 2.3.12
Télécharger 1.1.1 :
