StarAddons Moderator Toolkit Pro
Titre du sujet Titre du sujet StarAddons Moderator Toolkit Pro
Auteur de la discussion Auteur de la discussion adrin
Affichages Affichages 7
Dernier message par Dernier message par adrin
adrin
Membre super Actif
Membre
2e contributeur
Réputation: 19%
My latest add-on.
StarAddons Moderator Toolkit Pro turns the XenForo Admin CP into a professional moderation workspace. Instead of jumping between the report center, the approval queue, the moderator log, user profiles and half a dozen browser tabs, your team gets one dedicated Mod dashboard tab with eight tightly integrated modules: a live dashboard, an upgraded report workflow, one-click moderation menus in the forum itself, a repeat-offender detector, a full per-user history timeline, a team notes system, deep moderation statistics, and a no-code automation engine that acts on problems before a human even sees them.
The design is inspired by professional trading terminals: a dark, information-dense, multi-panel layout where charts, queues, feeds and detail panels live side by side. Everything a moderator needs to answer the three eternal questions — what is happening, who is causing it, and what should we do about it — is one click away.
The suite is built the XenForo way. Report state changes go through XenForo's own report service so the standard report center and notifications stay perfectly in sync. Moderation actions are written to the native moderator log. Permissions use the standard group permission system, options use the standard options page, and the automation engine runs on a normal XenForo cron entry. Nothing is bolted on; everything upgrades cleanly.
    16.9 KB · Affichages: 1
    35.3 KB · Affichages: 1
    27.6 KB · Affichages: 1
    63.2 KB · Affichages: 1
