Required for all XF2.1+ compatible add-ons.
A number of helper utilities designed to ease add-on development, does not have any direct user-facing changes.
Uploaded to aid dependency tracking and allow updating without updating every individual add-on.
Version 1.1.0 - Feature update, breaking change with some older add-ons
Add "replacevalue" templete filter used in a number of add-ons for implementing multi-select filter support
Add php 7 type hinting to various methods. Warning: this is a breaking change which cause site-disabling errors with older versions of the following add-ons;
Optimized List Queries v2.4.0 or earlier (free add-on)
Multi Prefix v2.7.5 or earlier (paid add-on)
Conversation Essentials v2.3.18 or earlier (paid add-on)
Bookmark Essentials v3.0.9 or earlier (paid add-on)
Tag Essentials v2.2.1 or earlier (paid add-on)
Additional 3rd party add-ons may have conflicts, and they will require updating or rolling back this add-on. This add-on is a drop-in replacement after updating the namespace being imported
Version 1.1.1 - Bugfix update : Fix typo in function name causing a templater error.
Version 1.1.2 Bugfix update :
When the installer is renaming things (phrases/options/etc), disable development file output as it can cause unexpected upgrade failures when the board is in dev mode.
Télécharger V1.1.2 :
Version 1.2.0 change : Add helper method for generating alias'ed classes to correctly support resolveExtendedClassToRoot function (used in controllers & entities)
Version 1.2.1 Bugfx update :
Add templater function which can reverse array/array collection
Fix possible MySQL 8.0+ collation error in renamePhrases
Version 1.3.0 Feature update :
Implement a custom date/time picker, with a custom input filter. Replacement for pikaday in XF2.2 no longer supporting a time component. Supports seconds (opt-out), and explicit time-zone selection.
Version 1.3.1 Bugfix update : Fix custom date/time picker incorrectly setting the 'day' component of a date to the 'year' value.
Télécharger V1.3.1 :
Version 1.4.0 - Feature update :
Bundle moment.js 2.29.1
Extract count down/up timer html/javascript from Vote Tally & Notice Time Replacables add-ons, this includes singular time.<part> phrases.
Example usage (generates html & loads javascript) ;
Télécharger V1.4.0 :
Version 1.4.1 - Maintenance update :
Ensure time counter timer doesn't cause unneeded HTML updates
When time counter code has maximum date parts set, do not append smaller units. ie "30 days 10 minutes" should be "30 days"
Télécharger V1.4.1 :
Version 1.5.0 - Admin Feature update
Add "View template modifications" when viewing a template with template modifications that apply.
A powerful diagnostic tool when diagnosing add-on conflicts in production!
Lists all modifications that are applying, and allows on-the-fly which are applying or not to view different permutations.
Allows viewing compiled template code various template modifications, extremely useful for isolating exactly where in a highly modified template is actually causing errors.
Note; viewing compiled template code dynamically compiles the selected template & modifications and does not read the actual on-disk representation.
If xdebug is active, this can be very slow !
Télécharger V1.5.0 :
Version 1.5.1 Maintainance update : Add "Compiler errors" missing phrase. Thanks @TickTackk
Télécharger V1.5.1 :
Version 1.5.2 Bugfix/Maintenance update : Improve installer helper
Télécharger V1.5.2 :
Version 1.5.3 - Bugfix update :
Restore php 7.0 compatibility
Fix "renamePhrases" install helper ignoring 3rd argument "replace"
Télécharger V1.5.3 :
Version 1.5.4 - Bugfix update : Fix minute value in time-selector not round-tripping as expected
Télécharger V1.5.4 :
Version 1.6.0 - Feature update :
Document features in Xon/XenForo2-StandardLib
Extend
Field name is set via
Télécharger V1.6.0 :
Version 1.7.0 - Feature update
Add hook-point for more aggressively rewrite inner-sub-query on early joins
Version 1.7.1 - Bugfix update
Fix out-of-memory error if multiple add-ons use EarlyJoinFinderTrait on the same class.
If using Optimized list queries add-on (free), this is a required update
Version 1.7.1 Patch 1
Rebuild redistributable to exclude incorrectly included bad class extension.
The 1.7.1 zip breaks the upload zip functionality! To recover;
Disable the Standard Library by Xon add-on.
Update the add-on
Ensure the Standard Library by Xon add-on is enabled
Télécharger V1.7.0 Patch 1 :
Version 1.7.2 - Maintenance update : Update
Télécharger V1.7.2 :
Version 1.7.3 - Bugfix update :
Add sanity check for add-ons with composer during add-on install
In XF2.2+, fix pikaday css not being loaded when using extended day-time picker
Impacted addons; Advanced Bb-Code Pack (Time bb-code), Live Content, Vote tally.
Télécharger V1.7.3 :
Version 1.8.0 - Feature update :
When viewing a template, always show the 'view template modifications' link to allow viewing compiled code
Add an addValue template filter, to complement removeValue filter, and related phrases
Télécharger V1.8.0 :
Version 1.8.1 : Fix "DevTools failed to load source map: Could not load content for .../js/sv/vendor/moment/moment.min.js.map"
Télécharger V1.8.1 :
Version 1.8.2 - Bugfix update : Fix triggering an error on /forums/1/page-9223372036854775807 when Optimized Query List add-on is used and php7+ type hinting is used.
Télécharger V1.8.2 :
Version 1.9.0 - Maintenance update :
Fix 32bit support when detecting early-join behaviour (ie Optimize List Queries add-on)
Move helper features for extending forum/prefix filters into Standard Lib from a number of other add-ons
Télécharger V1.9.0 :
Version 1.10.0 - Feature update :
Update EarlyJoinFinderTrait to add support tables with compound primary keys
Document using InstallerHelper
Add
Takes the result of
Version 1.10.2 - Bugfix update :
Fix for using SqlJoinTrait and EarlyJoinFinderTrait together
Resolves compatibility issue when using
Télécharger V1.10.2 :
Version 1.11.1 - Feature update :
Remove outdated comment in
Add
Add
Use
Adds the extendable class
Add new template filters/functions
Backport
Télécharger V1.11.1 :
Version 1.11.2 Bugfix update : Fix type-error when a collection is passed to the
Télécharger V1.11.2 :
Version 1.12.0 - Feature update :
Move quick_filter template/js which dynamically updates body/pagenav in an overlay from SV/WhoReplied into SV/StandardLib
See Who Replied v2.2.0+ or User Mention Improvements v2.8.0+ for examples of usage
Télécharger V1.12.0 :
Version 1.12.1 - Bugfix update : XF2.2.10 compat fix for "view template modifications" link not rendering.
Télécharger V1.12.1 :
Version 1.12.2 - Maintenance update : Avoid duplicate some join expressions multiple times when using optimized list query add-on.
Télécharger V1.12.2 :
Version 1.13.0 :
Add
The stock
Example of a default collapsed node-list :
Télécharger V1.13.0 :
Version 1.13.1 :
- Add a work-around for horribly not recommended add-on updating process.
- Deleting an addon's files while the add-on is active will very likely break your site.
Télécharger V1.13.1 :
Version 1.14.0 - php compatibility update :
- Update bundled moment.js library
- If using the Svg Template addon, update to SVG Template 2.4.5 or rendering SVGs to PNGs will stop working.
Télécharger V1.14.0 :
Version 1.15.0 - Minor feature update :
- Add controller plugin 'SV\StandardLib\ControllerPlugin\Delete' a plugin helper for implementing soft/hard/undeleting of content.
Télécharger V1.15.0 :
Version 1.15.2 :
- Fix join index hint support.
- Fix XF2.2.11 and before error:
- Fix XF2.212+ index hints not applying as expected in some cases.
Télécharger V1.15.2 :
Version 1.16.0 - Feature update :
- Add helper repository for manipulating permissions.
- Will be used by a number of upcoming updates for various add-ons.
Télécharger V1.16.0 :
Version 1.16.1 - Bugfix update :
- Fix caching global permissions was broken (Impacts Can Warn Staff & User Essentials, but depends heavily on content if this bug was triggered)
Télécharger V1.16.1 :
Version 1.17.0 - Feature update :
- Add "patch_route_build_callback" code event, used to manipulate the router state during construction.
- Add input filter option "empty-str-to-null". Example usage for developers :
Télécharger V1.17.0 :
Version 1.18.0 - Feature update :
- Add support for addon.json 'require'/'require-soft' to support addon version strings instead of the addon version_id.
Uses version_compare under the hood after some very basic standardization.
php version strings support dotted versions, '1.2.3' and also each part may also support special character strings :
Télécharger V1.18.0 :
Version 1.18.2 - Mini-feature & bugfix update :
Note; The 1.18.x branch will be the last branch to support XenForo 2.1.x
Version 1.18.3 - Bugfix update : Fix accidental hard XF2.2 requirement.
Télécharger V1.18.3 :
Version 1.18.4 - Bugfix update : Fix accidental hard XF2.2 requirement. Take #2
Télécharger V1.18.4 :
Version 1.19.0 - Feature update :
Télécharger V1.19.0 :
Version V1.19.2 - Bugfix update :
Version V1.19.3 - Bugfix update : Actually distribute minified ajaxPagination.js file
Télécharger V1.19.3 :
Version 1.19.4 : Fix
Télécharger V1.19.4 :
Version 1.19.5 :
Version 1.20.0 :
Version 1.21.1 - XenForo 2.3 support :
Version 1.21.2 - Bugfix update :
Version 1.21.3 - Maintenance update :
Version 1.21.5 - Maintenance update :
- Update
Télécharger V1.21.6 :
Version 1.21.7 - Maintenance update :
- Update choices.js integration
Version 1.21.9 - Bugfix update :
Version 1.21.10 - Bugfix update :
Update choices.js to v11.0.3
Version 1.21.11 - Bugfix update :
- Fix XF2.3.5 compatibility
- Actually update choices.js to v11.0.3
Télécharger V1.21.11 :
Version 1.21.12 - Bugfix update :
- Fix javascript paginated filtering for XF2.3 support
- Used in (paid) Threadmarks Pro add-on and (free) Who Replied add-on
Version 1.21.13 - Bugfix update :
- Fix javascript paginated filtering for XF2.2 support
Télécharger V1.21.13 :
Version 1.21.14 - Bugfix update :
- Update to choices.js v11.0.4
Version 1.21.15 - Bugfix update :
Version 1.22.2 - Feature update :
Version 1.22.3 - Bugfix update : Fix single-select mode could incorrectly have multiple items selected when pre-rendering choices.js widget.
Télécharger V1.22.3 :
Version 1.22.4 - Maintenance update :
- Improve compatibility when using
- Avoid possible expensive table expression queries being computed multiple times
Télécharger V1.22.4 :
Version 1.22.5 - Maintenance & Bugfix update :
Version 1.22.6 - Bugfix update :
- When using "AJAX pagination with filter bar" (
Version 1.23.0 - Feature & Bugfix update :
Version 1.23.2 - Maintenance update :
Version 1.23.3 - Bugfix & Maintenance update :
Version 1.23.4 :
Version 1.23.6 - Bugfix & compatibility update :
Télécharger V1.23.7 :
Version 1.23.8 - Bugfix update :
Version 1.23.9 - Bugfix update :
Version 1.24.0 - Feature update :
It can then be used via
And in templates;
- Allow radiobox type style properties to implement style variants (Used in Selectable Logos)
Télécharger V1.24.0 :
Version 1.24.1 - Bugfix update : Compatibility fix for XF2.3.0-XF2.3.4
Télécharger V1.24.1 :
Version 1.24.2 - Bugfix & compatibility update :
Version 1.24.3 - Bugfix update :
Version 1.24.4 Maintenance update :
Version 1.24.5 Bugfix update :
Version 1.24.8 Bugfix update :
- Compatibility fix with XF2.2.6 and older
Télécharger V1.24.8 :
Version 1.24.9 : Backport update of IP ranges used by XF to identify google/cloudflare requests.
Version 1.24.10 : Fix mobile pagenav support for ajax pagination/filtering.
Télécharger V1.24.10 :
XML:
<xf:macro template="svStandardLib_helper_macros" name="date_time_input" arg-name="startTime" arg-timestamp="{$xf.time}" />
XML:
<xf:macro template="svStandardLib_helper_macros" name="date_time_input_row" arg-label="{{ phrase('start_time') }}" arg-name="startTime" arg-timestamp="{$xf.time}" />
PHP:
$timestamp = $this->filter('startTime', 'sv-datetime');
PHP:
$func = \XF::$versionId >= 2010370 ? 'func' : 'fn';
return $this->app->templater()->$func('sv_relative_timestamp', [
$now->getTimestamp(), $other->getTimestamp(), // now and other date time obj
0, $countUp, // maximum date parts and if allowed counting up
'time-notice', // class added to the span
'click', '< .notice-content | .notice-dismiss' // event to trigger and who trigger it on
addOrChangeColumn to be rename-aware to avoid generating invalid SQLTélécharger V1.5.2 :
Extend
XF.Tabs to store the ID of the selected tab on submit via a hidden field.Field name is set via
data-sv-store-selected-tab-input-name added to the data-xf-init="tabs" element
HTML:
<xf:js addon="SV/StandardLib" src="sv/lib/xf/core/structure.js" min="1" />
<div class="hScroller"
data-xf-init="h-scroller tabs"
data-panes=".js-categoryTypeTabPanes"
data-sv-store-selected-tab-input-name="category_type">
Update the add-on
EarlyJoinFinderTrait to send additional arguments to the getEarlyJoinThreshold method, this is a non-breaking changeTélécharger V1.7.2 :
Add
InstallerHelper::getReversedAlterTables (with example usage in README.md), to hopefully simplify uninstaller code.Takes the result of
getAlterTables (array of table alters) and reverses simple column adds, renames and index adds.Version 1.10.2 - Bugfix update :
Bump Thread and Optimized List Queries add-ons togetherTélécharger V1.10.2 :
EarlyJoinFinderTraitAdd
isPermissionInUse install helperAdd
SV\StandardLib\Behavior\Cacheable behavior, to help automate calling rebuildCache (or a defined function) on a repository which matches the entity's nameUse
templater_setup code event to inject various filters/functions into multiple templater types.Adds the extendable class
SV\StandardLib\TemplaterHelper to help add filters/functions to templates without manualy extending every templater typeAdd new template filters/functions
parse_less_funcabsarray_diffsv_array_reverse => array_reverseBackport
phrase_dynamic function to XF2.1Télécharger V1.11.1 :
removeValue templater filter function.Télécharger V1.11.2 :
Version 1.13.0 :
Add
is_toggle_set template function and toggle-storage-ex backend for the XF toggle JS.The stock
is_toggled does not allow setting the default value, while is_toggle_set does.Example of a default collapsed node-list :
PHP:
<xf:js src="sv/lib/storage.js" addon="SV/StandardLib" min="1" />
<xf:set var="$isActive" value="{{ is_toggle_set($forum.node_id, false, 'node-toggle') ? ' is-active' : '' }}"/>
<div class="block block--collapsible-child-nodes">
<div class="block-container">
<h3 class="block-minorHeader collapseTrigger collapseTrigger--block {$isActive} "
data-target=".block--collapsible-child-nodes .block-body"
data-xf-click="toggle"
data-xf-init="toggle-storage-ex"
data-storage-type="cookie"
data-storage-container="node-toggle"
data-storage-key="{$forum.node_id}"
data-default-value="0"
>{{ phrase('sub_forums') }}</h3>
<div class="block-body toggleTarget {$isActive}">
</div>
Version 1.13.1 :
Version 1.15.2 :
Undefined array key "indexHints".- Fix XF2.212+ index hints not applying as expected in some cases.
PHP:
$foo = $this->filter('bar', '?uint,empty-str-to-null');
any string not found in this list < dev < alpha = a < beta = b < RC | Release Candidate = rc < # < patch level | pl = p.
- Deprecate getContentPermissions function, as the 2nd string argument was not actually used, with a replacement function getPerContentPermissions added.
- Add
\SV\StandardLib\Helper::isAddOnActive()helper function. Similar to\XF::isAddonActive(), except it understands version strings - Shim template funciton
is_addon_activecode to understand version strings
- Only add
phrase_dynamictemplate method in XF2.1 - Add various strongly typed helpers to automatically type hint returns based on using
::classargument instead of magic strings.
PHP:
$obj = Helper::repository(\XF\Repository\User::class);
- For static analysis and IDE,
$objwill have the type\XF\Repository\User
While XF2.3 intends to implement this, adding this functionality to this add-on allows migrating before hand and simplifies migrating as the Helper bit just needs to be swapped with\XF - Add
js/sv/lib/ajaxPagination.js
HTML:
<xf:js src="sv/vendor/domurl/url.js" addon="SV/StandardLib" min="1" />
<xf:js src="sv/lib/ajaxPagination.js" addon="SV/Threadmarks" min="1" />
<div class="block" data-xf-init="sv-ajax-pagination" data-content-wrapper=".block-body--wrapper">
<div class="block-body--wrapper">
<xf:pagenav ... />
<xf:hiddenval name="final_url" value="{$finalUrl}" />
</div>
</div>
<xf:pagenav> and <xf:hiddenval name="final_url" /> must be inside the div which is tagged with data-content-wrapper's css selectorTélécharger V1.19.0 :
- Fix Who Replied pagination could get confused on the non-first page of a thread, similarly for ajax pagination code (used in Threadmarks v2.19.0+)
- Fix ajax pagination could push changes to URL history when in an overlay
Helper::createEntity() could cause "Call to undefined method ...\XF\Entity\...::where()" errors when verifying content is uniqueTélécharger V1.19.4 :
Version 1.19.5 :
- Fix
Helper::find()andHelper::findCached()assumed entity ids are only ints (can be string/int/array) - Add
Helper::instantiateEntity()type-safe wrapper
Version 1.20.0 :
- Require php 7.2+
- php 8.4+ compatibility fix
- Improve custom AJAX pagination and AJAX pagination with filter bar javascript. Includes admincp option helper option rendering code
- See Who Replied for an implementation of the feature allowing selectable pagination styles
Add Helper::Pluginfor type-safe plugin creation
- Fix
\SV\StandardLib\Helper::repo()->aliasClass()had a compatibility issue with XF2.2.13+ when the aliased class was the top-most class extension.
- XF2.3 support
- Various .js files should work with XF2.1/XF2.2/XF2.3
- Fix
hasDesiredAddOnVersioncould error if the target addon was in a processing state - Fix
Standard Lib: Log parse_less_func debug infooption not working - Backport <xf:macro name="template::macro syntax to to XF2.1
- Update parse_less_color to not return CSS variables where possible
- Bundle
choices.jsas a near drop-in replacement forselect2- Enrich a select box with choices.js.
HTML:<xf:macro template="svStandardLib_macros" name="choices_setup" /> <xf:selectrow label="Select row example" name="select_row_example" multiple="multiple" data-xf-init="sv-choices" data-placeholder="{{ phrase('example')|for_attr }}" data-max-item-count="2"> <xf:option value="1">Option 1</xf:option> <xf:option value="2" selected="true">Option 2</xf:option> <xf:option value="3">Option 3</xf:option> </xf:selectrow> - The initial structure is pre-rendered to reduce/prevent page jank.
- To opt-out add the
skip-rendering="true"attribute to the<xf:select>or<xf:selectrow>element - This will be used by a number of my add-ons and other 3rd party addons.
- Fix ajax pagination & ajax filtered pagination code did not dynamically loading css/js
- Update
choices.js- Various performance fixes when used with large number of options (ie hundreds of prefixes when using Multi-Prefix)
- Fix filtering/search could return unstable search results
- Fix possible empty
aria-labelgeneration on remove item button - Fix enter could cause accidental form submit instead of open/closing the choices list in all cases
- Fix bad reference to
useNativeTimeInputsinREADME.md - Update choices.js (v11.0.0-rc7)
- Smaller bundle size
- Improve aria attribute handling (aka accessability)
- Many bugfixes around keyboard handling & displaying notices
- Update
choices.js (v11.0.0-rc8)- Maintenance of
choices.jsis now done by Xon - When filtering/searching, show all search result hits instead of just the top 4.
- Support all text/number configuration options as data-* attributes
- Cleanup font-size handling (on average slightly larger, but works on more styles)
- Convert CSS (generated from SCSS) into LESS
- Fix adding classes to choices.js via data-class-* attributes did not work as expected
- Fix a number of performance issues with very large number of options (ie hundreds to thousands), not fully resolved but better.
- Update choices.js
- Adjust font-size css to be more inline with standard XF
- Fix select did not reset correct after a form submit.
- Noticeable with Threadmarks Pro add-on on replying to a thread
- Fix "no choices to choose from"/"no results found" notice did not reliably trigger
- Fix options loader would unexpectedly clear options. This impacts the move thread function.
- Update count down timer to only show seconds in the last 2 minutes by default, this avoid excessive page-reflows
- Noticeable with notice time replacables add-on
- Fix accessibility around tab/shift//esc key handling
- Fix "No choices to choose from" was displayed when it shouldn't be
- Fix max item notice handling would stop displaying when it shouldn't
- Fix HTML comments could be displayed as part of a item's text label when they shouldn't be.
- Fix selected option being escaped twice (Affects MultiPrefix editing a thread prefix)
- Fix reaching maximum item limit notice is not cleared after removing selections
- Fix
tab=> direction keys handling- Fix performance regression when loading options after choices.js object creation (Affects MultiPrefix loading per-forum prefixes)
- Update to choices.js v11.0.6
- Fix regression where clicking the item would close & then re-open the dropdown instead of expected behavior
- Fix regression in setChoices API call (interaction with selected items, does not affect bundled select.js library)
- Workaround unexpected behavior in
\XF::options()and strongly typed property hints (generated by XF CLI commandxf-dev:generate-options-stub)which may cause bugs in some add-ons - Update choices.js v11.1.0
- Remove
role="textbox"from search input, per a11y practices - Add choices.search-kmp.js build, more advanced than a simple prefix match but less complex than using FUSE for search
- Support
<option label="..." />HTML (not generated by XF natively)
- Remove
EarlyJoinFinderTrait and SqlJoinTrait together- Avoid possible expensive table expression queries being computed multiple times
- Partial workaround for buggy XF2.3 behavior around repository uniqueness. Does not affect call sites to
\XF::repository, onlyHelper::repository - Fix incorrectly using
SqlJoinTraitwould swallow the actual error - Improve detection of excluding non-required joins when using EarlyJoinFinderTrait. This affects Multi Prefix is optimizing for matching on a single prefix, and also Extended Ignore
- Remove usage of
assert()for XF Cloud compatibility
js/sv/lib/xf/filter.js), fix invalid javascript error message when filtering by a value without pagination wrapper- Noticeable on the "logo selection" page of the Selectable logo (paid) add-on
- Fix bad type-hint
on whereImpossible()method forEarlyJoinFinderTraittrait - Update
Helper::newExtendedClass()to execute in the context of the class being executed, this allows private/protected constructors to be called - Add tab-nav helper code to work with collapsible sections (
sv/lib/tab-nav.js), this allows tabbing between elements to trigger collapsing/expanding of collapsed sections - Add support for 3rd party add-ons implementing XF2.3 style property variations to use the "default" variant in XF2.1/XF2.2
- Update to choices.js v11.2.0
- Adjust choices.js input-box css to have expected
@xf-inputTextColortext color - Add "Default Choices.js bundle" option to expose which choices.js bundle to use (controls the search-as-you-type implementation)
- Add support for
requiredhtml attribute (Note; requires css changes) - Improve UX on the select dropdown
- Fix data-label-description from source html was not treated as trusted (ie MultiPrefix & prefix help)
- Fix selected choice was not reliably highlighted when opening the dropdown
- Fix dropdown would stick closed when a search loses focus
- Enhance admincp batch add-on installer to sort add-ons by their dependencies to make updating multiple add-ons more reliable
- Fix move thread dialog didn't update allowed prefixes when the forum changed on XF2.2
- Fix time count up/down javascript would incorrectly use the phrase
time.minutesinstead oftime.minutewhen referencing1 minute
- Adjust addo-on version string comparison so "preview" releases as less than stable releases
- Do not patch option entity in XF2.3.8+ to support strict type checks against \XF::options() properties, as this is now natively supported
- Backporting array_* templater function changes
- Add
array_sumtemplater function for pre-XF2.3.8 - Only backport
array_diff/array_reversetemplater functions for older XF versions
- Add
- Fix XF2.2 boolean options was not cast as bools as expected
- Fix XF2.2 default value for float options were cast to integers instead of floats
- Update backported templater functions
array_diff/array_reverse/array_sumto match XF2.3 behavior. These return arrays, not collections depending on input. - Add
array_first/array_lasttemplater functions
Version 1.23.4 :
- Backport
array_is_listtempleter function which is native in XF2.3.9+ - Fix for custom date/time macro (
svStandardLib_helper_macros::date_time_input)- Fix seconds would be prompted in the time input even when
$showSecondsarg was false - Fix safari support as safari (ie any iphone browser) doesn't support seconds for the
input[type=time]field
- Fix custom date-time handling parsing had a broken condition for non-safari browsers
- Fix installer could sometimes cause errors when using aliasClass helper method
- Fix rebuilding or updating StandardLib could cause option values to be incorrectly cached without expected types, only applies to pre-XF2.3.8
- Only noticeable if StandardLib is updated without updating another other add-on
- Update
array_first/array_last functions to not mutate the array pointer - Choices.js integration
- Fix pre-rendered choices.js widget didn't respect
data-search-enabled="0"to disable search - Fix javascript error when parsing boolean data-* options on XF2.2
- Fix 'required' attribute didn't work as expected
- Workaround for widget height collapsing when no items are selected and not placeholder exists
- Compatibility fix for
Finder::fetchDeferred()- Fixes unexpected results from XFMG when Optimized List Queries add-on is installed
- Fix InstallerHelper::renamePhrases used to migrate phrases from one title scheme to another when the new phrase already exists would probably fail to migrate any customizations
In practice, this would only happen on re-running the install-step or if the user manually created a new phrase - Fix installer for pre-XF2.3 not backporting the
xf_style_property.has_variationscolumn - Minor code cleanup around the use of
\SV\StandardLib\Helper::repo()->aliasClass() - Update to choices.js v11.2.2
- Fix opening the dropdown could cause the entire page to scroll
- Fix non-fixed width font support when computing width for input element
- Harden installer when backporting features could cause the add-on to get caught into a silent zombie state depending on if the GUI updater is used
- Update choices.js v11.2.3
- Fix search input width unexpectedly collapses
- Implement XF2.4's
link-postjavascript used to prevent crawler repeatedly following GET's with per-session tokens in them.
Applies to;- Front end style/style variation/advanced cookie consent/logout
- Admin language/style variation
- Backport updating cloudflare/google/googlecloud ips
- Backport latest XF user-agent definitions for robot/crawlers
- Update
Helper::repo()->aliasClass()to avoid needing to generate shim files which live in the code cache, but requires additional argument to define the base class - Add Basic implementation of
config.phpbased feature flags
Inconfig.php
PHP:
$config['svFeatureFlags']['flag'] = true;
PHP:
if (Helper::isFeatureFlagEnabled('flag'))
And in templates;
XML:
<xf:if is="sv_feature_flag('flag')">...</xf:if>
- Fix
php cmd.php xf-addon:install-step SV/StandardLib 1CLI command would error - Fix rewriting advanced cookie consent form from GET to POST would just redirect and not accept/reject cookies
- Adjust template modifications when rewriting various GET links to use link-post construct for better 3rd party add-on compatibility
- Fix advanced cookie concent form didn't work as expected when redirecting from GET to POST links
- Fix possible javascript error in
link-post.json XF2.2
- Remove
_xfRedirectattribute from various GET links as these cause many redundant fetches by bots. This was only is required if the link is opened as a GET without a referrer being set. At which point just redirecting back to the same selection dialog is good enough.
- Fix unexpected recursion causing a stack overflow when add-on cache data is rebuilt
- Harden
post-link.jsto avoid infinite redirect due to a WAF security check redirecting back to the same page (aka cloudflare security checks) - Update
choices.js- More reliably trigger iOS virtual keyboard in all cases
- Fix arrow-key navigation did not start from the selected choice when no choice is currently highlighted
- Harden
Helper::getEntityStructure()to not cause an internal server error on an invalid Entity definition- Compatibility fix for Signup Abuse Detection and blocking's admincp options with some 3rd party add-ons.
- Fix
Undefined array key 'src' template error on XF2.3 - Adjust installer to avoid triggering non-required class extension cache rebuilds on updates
- Fix backport changes not applying to older XF versions as expected
- Fix pre-XF2.3.8 support for
\XF::options() returning strongly typed data after updating SV/StandardLib
