[Spolzer] Avatar History 1.0.1
XF 2.3 [Spolzer] Avatar History 1.0.1
Titre du sujet Titre du sujet [Spolzer] Avatar History 1.0.1
Affichages Affichages 2
Avatar History :
Automatically saves a user's avatar history every time they change or remove their avatar.
This allows users to quickly restore any previously used avatar without re-uploading the image.
The plugin stores a limited number of recent avatars and provides a convenient interface for viewing and restoring them.
✨ Features​
  • 💾 Automatic avatar saving
    Every time an avatar is changed or removed, the previous version is automatically saved to history.
  • ⚡ Quick restore
    The user can select any saved avatar and set it again with a single click.
  • ♻️ Smart deduplication
    If the user sets an avatar that already exists in history, no duplicate is created.
  • 🔒 Privacy settings
    The user can control who is allowed to view their avatar history.
  • ✍️ Use another user's avatar
    If a user allows others to view their avatar history, other users can open it and choose any saved avatar.
    The selected avatar can be applied to themselves with one click.
  • ⚙️ Quantity limit
    The administrator can set the maximum number of avatars stored for a single user.
  • 🧹 Automatic cleanup
    Old avatars are automatically deleted when the configured limit is exceeded.
📸 Screenshots​
🖼️ Avatar editing
👀 Public avatar history view
🔁 Using another user's avatar from history
⚙️ Plugin settings
👥 User group permissions
