Additional requirements : Standard Library by Xon
Un ensemble d'améliorations apportées à la recherche améliorée de XF et à certaines améliorations apportées à la recherche MySQL par défaut de XenForo.
MySQL & Elastic Search features ;
New Permissions
Version 2.2.9 Maintenance update : Add missing phrase for admincp user change log
Télécharger V2.2.9 :
Version 2.3.0 Maintenance update :
Require XF2.1+
Rework "Allow empty search" support, support for XF2.1.8+ features and also XF2.1.0+
Télécharger V2.3.0 :
Version 2.3.1 Maintenance update : Improve MySQL range-search support for Report Improvements warning points search
Télécharger V2.3.1 :
Version 2.4.0 - XF2.2 Compatibility update
Compatibility fix for Threadmarks v2.8.0+ and possibly other add-ons which may extend search page defaults
Requires php 7.0+
Support XF2.2+
Télécharger V2.4.0 :
Version 2.4.1 Maintenance update :
Allow weight-by-content to be extended.
Compatibility update when resolving an extended class to the root class
Require Standard Library by Xon v1.2.0+
Télécharger V2.4.1 :
Version 2.4.2 Maintenance update : Improve extendibility of weight-by-content feature
Télécharger V2.4.2 :
Version 2.4.3 - Maintenance update :
Improve extendibility of weight-by-content-type feature (Allow custom searches to opt-in to content weighting for single type searches)
Improve compatibility with ElasticSearch v7+
Support float-point weight values in weight by content-type
Ensure XFES doesn't swallow the actual error message for a query failing instead of "all shards failed" message (backport for older versions of XFES)
Télécharger V2.4.3 :
Version 2.4.4 - Maintenance update : Re-add "On error, log search DSL" option, default on.
Télécharger V2.4.4 :
Version 2.4.5 Bugfix update : Fix weight by content type for XF2.2
Télécharger V2.4.5 :
Version 2.4.6 Bugfix update : Fix the "Default search order" option would get reset when changing "Search options" under Enhanced Search Setup page.
Télécharger V2.4.6 :
Version 2.5.3 - Backend feature update :
This feature is powering tag autocomplete and username autocomplete which supports partial matches, and non-prefix lookups on SpaceBattles.
Require XenForo 2.2+, removes xf2.0/xf2.1 support
Add "Specialized index" support
Specialized search index allows generating single-purpose elastic search indexes while re-using as much XF search infrastructure as possible.
Elasticsearch index is more akin to an SQL table than an entire database, so for very specific tasks a single purpose search index works better.
A separate index also allows changing indexing properties and re-indexing just that one index without impacting the main search index
Implementation of a specialized index notes;
At the core, a XenForo search handler is used to drive the functionality.
The search handler should implement the interface
Use the types
These types will be rewritten to add
Register the search handler with the following content type fields
This handler really shouldn't be registered with
Add the behavior
Télécharger V2.5.3 :
Version 2.5.4 - Maintenance update :
- When using the 'content weighting' feature, reduce the ElasticSearch query complexity by not applying redundant content weighting terms.
Télécharger V2.5.4 :
Version 2.5.5 Bugfix update :
- Fix "array_fill_keys() expects parameter 1 to be array, null given" error when content weighting has not been configured.
Télécharger V2.5.5 :
Version 2.6.2 :
Require php 7.2+
Add ability to push "can view threads/tickets by other" permission(s) into ElasticSearch query, reducing php-side culling of matching content.
This improves searching forums/tickets where the user lacks these permissions.
This is gated behind the option Push "View X by others" check into XFES', as it requires a full reindex. (Default disabled)
Supports the following add-ons:
View Sticky Threads (free) add-on.
Collaborative Threads (paid) add-on.
@NixFifty's Tickets (paid) add-on.
For best results, use ElasticSearch Essentials add-on, as it simplifies this permission constraint compared to stock XenForo.
Télécharger V2.6.2 :
Version 2.6.3 Bugfix update :
- Fix incorrectly adding a return type to XF\Search\Search::isValidContentType
- Fix typo in admincp options phrase
Télécharger V2.6.3 :
Version 2.7.4 - Feature update :
- Fix bug where 'weight by content type' feature didn't work as expected in general search
- Thanks to @NamePros for sponsoring this update.
- Display various search term constraints on the search results form.
- For developers to implement support in 3rd party add-ons:
- Each search constraint needs a
- Arrays are mapped to phrases by adding a
- Each search order needs a
- Extend
- Extend
- Extend
- Use the debug option "List all unphrased search constraints" which will dump unmapped contraints to search results page.
Télécharger V2.7.4 :
Version 2.7.5 - Minor bugfix update :
- Remove usage of
- Fix HTML markup error in
Télécharger V2.7.5 :
Version 2.8.1 :
- Fix "before" search result term would print an integer instead of a human readable yyyy-mm-dd formatted string
- Change 'no results found' handling to display search terms on the relevent page
If using ElasticSearch Essentials, recommend updating to v3.13.0+ as this change may impact some options which display on no results found.
- Fixes for search term on results page
Add missing "With X thread" search term
Fix "Users" search term could fail to render the list of usernames
Add the 'content type' search term
Télécharger V2.8.1 :
Version 2.8.3 - Security update (recommend updating ASAP) :
- Fix cached search results would be unexpectedly be viewable to anyone if they guessed the search result URL.
Affected versions; v2.8.1
These search URLs expire after a day
- Fix search term on search result pages leaking information for non-viewable content
Affected version; v2.7.4, v2.7.5 and v2.8.1
Fix leaking thread title when using "In thread" search area, and rendering a bad phrase if the thread doesn't exist
Fix linking to non-active user profiles when searching by members
- Workaround for an XF bug where the cached search results for a member search could be directly shared with a guest
Non-visible items on the result page where not rendered, but this does leak that there are hits in not viewable to guests areas.
Télécharger V2.8.3 :
Version 2.8.4 - Bugfix update : Fix searching by member without a keyword for a guest.
Télécharger V2.8.4 :
Version 2.9.1 - Feature update :
This update will require a full search rebuild, truncating the index before re-indexing.
Télécharger V2.9.2 :
Version 2.9.5 - Bugfix & maintaince update :
- Workaround XF bug where a search type parameter was not validated as being allowed for a search handler
- Workaround XF bug where a search could be constructed which targeted the parent (ie thread) content type and not the child (ie post) content type resulting in potentially degraded search results
- Replace
XF lacked a "search only X" per search tab that this add-on injects
XF would target the parent type and didn't figure out the child type
- Force a search without a query string to render it as
- Redirect to XFES configuration page if XFES isn't configured instead of the search index list
- Show basic statistics on the search index list page
Version 2.9.6 - Bugfix : Fix error "Object of class XF\Mvc\Reply\View could not be converted to string" when a user is denied search tries to use search.
Télécharger V2.9.6 :
Version 2.9.7 - Bugfix update :
- Fix "Push "View X by others" option being disabled would cause some user information to not be indexed, which had the implicit "rebuild search index" if this setting was then enabled.
- This fixed conversation search when using Conversation Improvements v2.4.x+
- Requires a re-index of at least conversations/conversation messages to re-add the missing information.
- For most sites, disabling the "Push "View X by others" check into XFES" option is not recommended
Télécharger V2.9.7 :
Version 2.9.8 - Bugfix update :
- Cleanup add-on description & readme file
- Update XFES dependent option descriptions to include if they require XFES
- Improve styling of 'no results' search result in an overlay
- Fix search result terms do not display when search results are in an overlay
- Fix custom styling triggering "Your changes have been saved." when clicking a member search link
Télécharger V2.9.8 :
Version 2.10.0 - Feature update :
- Improve how thread/tickets by others in a category without view-other permission are filtered out of search results when using XFES without ElasticSearch Essentials
- Add
- Add "Collect search DSL & debug statistics" option (Default off), designed as a developer tool and strongly not recommended for production usage.
Télécharger V2.10.1 :
Version 2.10.2 - Maintainance update :
- During upgrades, fix " Access to undeclared static property " error.
- Do not show the "Tags will be searched" tooltip as part of "Search titles only" in advanced search for content types which do not implement tagging
Télécharger V2.10.2 :
Version 2.10.3 - Maintenance update :
Version 2.10.4 - Bugfix update :
- Fix viewing the index list could be blocked when elasticsearch is configured but inaccessible.
Télécharger V2.10.4 :
Version 2.11.0 - Maintenance update : Support tag/username autocomplete using XFES add-ons todo prefix matching on autocomplete.
Télécharger V2.11.0 :
Version 2.11.1 :
Version 2.12.0 : Maintenance & minor feature update
Version 2.13.0; XF2.3 Compatibility update
Version 2.13.1 - Bugfix update : Fix guests searching by user would restart the search query the first time they tried to visit the a different page of the search results
Télécharger V2.13.1 :
Version 2.14.0 :
Version 2.15.4 - Feature update & XenForo 2.3 support :
Version 2.15.5 - Bugfix update : Fix XF2.3.0 infinite search redirect for guests.
Télécharger V2.15.5 :
Version 2.15.6 - Bugfix update : Fix guest user searches could be sent into a redirect loop depending on search criteria.
Télécharger V2.15.6 :
Version 2.15.7 - Bugfix update :
- Fix min/max range searches (ie word-count) where flipped when using MySQL full-text search
Version 2.15.8 - Bugfix update :
- Compatibility fix for Username auto-complete using XFES and Tag auto-complete using XFES add-ons.
Télécharger V2.15.8 :
Version 2.15.9 - Bugfix update :
Version 2.16.0 - Compatibility update :
Search extensions API changes for better XF compatibility, required for Conversation Improvements/Essentials
Version 2.16.1 - Maintenance update :
Version 2.16.2 - Maintenance update : Improve 3rd party support for specialized search index support.
Télécharger V2.16.2 :
Version 2.17.0 - Feature & bugfix update :
- Enhanced specialized search with additional debug capabilities
- Update specialized search to support SearchOrder type
- Fix XF2.1 when using specialized search functionality (aka fix tag/user autocomplete with XF2.1)
Télécharger V2.17.0 :
Version 2.17.1 - Bugfix update : Fix when logging debugging for some search queries would throw unexpectedly
Télécharger V2.17.1 :
Version 2.17.2 - Bugfix update : For XF2.3.4+, check "View server information" admin permission when viewing elasticsearch statistics
Télécharger V2.17.2 :
Version 2.17.3 - Maintenance update :
- Improve handling of expired search links to return a 404 if any errors exist with the arguments as this stops google search indexer from complaining about the previous 400 error code
Télécharger V2.17.3 :
Version 2.17.4 - Maintenance update :
- Adjust defaults for autocomplete boosts to better favor exact matches.
- Affects non-default "Tag/Username auto-complete search field boosts" option
Télécharger V2.17.4 :
Version 2.17.5 - Bugfix update : XF2.3.8 compatibility fix
Version 2.17.6 - Bugfix & Maintenance update :
- XF2.3.8 compatibility fix
- Adjust
Télécharger V2.17.6 :
Version 2.17.7 - Bugfix update :
Version 2.18.0 - Compatibility & bugfix update :
Version 2.19.0 - Feature & bugfix update :
Version 2.19.3 - Security bugfix & minor feature update :
- range_query search DSL
- allows arbitrary range queries for numerical data
- Allow users to select the default search order independent for the forum wide setting.
- Per content type weighting
- Adds Elastic Search information to the AdminCP home screen.
- Adds a debug option to log the search DSL queries to error log for troubleshooting
- Option to extend search syntax to permit;
- + signifies AND operation
- | signifies OR operation
- - negates a single token
- " wraps a number of tokens to signify a phrase for searching
- * at the end of a term signifies a prefix query
- ( and ) signify precedence
- ~N after a word signifies edit distance (fuzziness)
- ~N after a phrase signifies slop amount
- In order to search for any of these special characters, they will need to be escaped with \.
New Permissions
- Search Options
Require XF2.1+
Requires php 7.0+
Support XF2.2+
\SV\SearchImprovements\Search\Specialized\SpecializedDataUse the types
MetadataStructure::KEYWORD or MetadataStructure::STR fields in setupMetadataStructure.These types will be rewritten to add
.exact & .ngram subfields. To skip this pass ['skip-rewrite' => true] to the MetadataStructure::addField's 3rd argument.MetadataStructure::KEYWORD - shortish text which is semi-structured such as tags or usernamesMetadataStructure::STR - Arbitrary text which uses phrases of textRegister the search handler with the following content type fields
specialized_search_handler_classentityThis handler really shouldn't be registered with
search_handler_class content type field.Add the behavior
SV\SearchImprovements:SpecializedIndexable to the entity.Télécharger V2.5.3 :
Version 2.6.2 :
Require php 7.2+
svSearchConstraint. prefixed phrase.- Arrays are mapped to phrases by adding a
_ for each sub-array/key as such; c[warning][points][lower] => svSearchConstraint.warning_points_lower- Each search order needs a
svSearchOrder. prefixed phrase.- Extend
XF\Entity\Search::getSpecializedSearchConstraintPhrase(string $key, $value) to provide custom phrase handling (ie node names)- Extend
XF\Entity\Search::formatConstraintValue(string $key, $value) to provide custom formatting.- Extend
XF\Entity\Search::setupConstraintFields to populate $svDateConstraint/$svUserConstraint/$svIgnoreConstraint properties which control formatting- Use the debug option "List all unphrased search constraints" which will dump unmapped contraints to search results page.
- Remove usage of
utf8_* function(s), and use native php multi-byte functions instead.- Fix HTML markup error in
svPushViewOtherCheckIntoXFES option description.Télécharger V2.7.5 :
Version 2.8.1 :
- Require Standard Library by Xon v1.18.0+
- Workaround for XF bug where the search URL did not contain the various query string arguments, causing issues when the URL was shared
- Workaround for XF bug where the search ownership check wasn't strict enough
- Workaround for XF bug where a user's recent content had a "view more" link which rendered even if the visitor didn't have permission to search
- Move some permission handling code into StandardLib so it has a common hook point
- Fix edge case where XFES is installed by not enabled causing XFES-only code-paths to be triggered
- Fix reporting search terms without phrases on the results page return false positives
- Fix various search result terms missing phrases, bad rendering of links
- Fix pushing viewable ticket category constraints into ElasticSearch for NixFifty's Tickets add-on
- Search result terms are now sorted to pull known important bits first
- Add various helper functions & template macros for writing search criteria
- Improvements which require ElasticSearch (aka Xenforo Enhanced Search)
- Support for ElasticSearch Essential's "container only" search term result criteria
- Tickets:
- Search by min/max number of replies, sort by number of replies
- Search by ticket participants
- Replace
search/member search with a redirect to a standard search with the appropriate parameters entered. Stock XF member searches are slightly specialized and the general search is missing several features to support normal search being a strict super-set of member search.XF lacked a "search only X" per search tab that this add-on injects
* which allows member searches to be edited/refined- Redirect to XFES configuration page if XFES isn't configured instead of the search index list
- Add
PermissionConstraint helper class, designed to simplify implementing XF Search handler's getTypePermissionConstraints function- Add "Collect search DSL & debug statistics" option (Default off), designed as a developer tool and strongly not recommended for production usage.
- Improve phrasing of custom search term on the advanced search page.
- Change the phrase 'search only x' to 'search x only' to match XenForo.
- Supports arbitrary phrases for 'search x only' by adding the phrase
svSearchImprov_search_container.xwherexis the content type. Ships with the current customizations:svSearchImprov_search_container.thread: "Search titles and first posts only"svSearchImprov_search_container.conversation: "Search titles and first messages only"
Version 2.11.1 :
- Workaround XF2.2.13 does the search beforechecking it it can save it as a cached value, which can result in a query that is massively more complex than expected being sent to elasticsearch
- This issue practically doesn't occur with stock XFES, but with additional search addons such as ElasticSearch Essentials this can generate unexpected errors
- Require StandardLib v1.19.0+
- Code cleanup
- Add getSearchIdFromEntityId() helper method for transforming an XF entity id into the Elasticsearch index id
- Requires StandardLib v1.19.0+
- If installed, requires Redis Cache 2.17.0+
- XF2.3 compatibility update
- php 8.4 compatibility fix
Version 2.14.0 :
- Add "Push thread prefix text into search" option (default true)
- Supports ElasticSearch Essential's autocomplete
- Requires manual rebuild of threads on changing this option
- Restore XF2.1 support
- XF2.3 support
- Fix "[E_DEPRECATED] Use of "parent" in callables is deprecated" on search
- Update installer to verify ElasticSearch index does not require rebuilding when this add-on is installed/updated/rebuilt
- Return 400 status code instead of 200 when the search query is wrong
- XF2.3 compatibility fix for custom "SearchOrder" class
- Simplify
asSqlConstraintcode (expected to always return an array) AbstractConstraint::setMatchTypeneeds to normalize to an int forMetadataConstraint::matchType
- Add additional hookpoints for customizing "specialized search indexer" functionality
- On search results page, when searching a conversation(XF2.2)/direct message(XF2.3) display "with conversation/direct message"
- Adjust
Collect search DSL & debug statistics so Log & show on search results only displays to members by defaults and not guests.Télécharger V2.17.6 :
- Improve XF Cloud support
- Fix sorting by a custom elasticsearch field didn't work as expected when using SearchOrder class (ie Report Improvements and sorting reports by comment count)
- Require StandardLib v1.23.0+
- php 8.4+ compatibility fixes
- Fix Ticket's reply-count range search criteria into search page didn't work
- Ensure injecting participants search for Tickets keeps working if the macro syntax is updated
- Compatibility update for upcoming Content Ratings v2.9.0+
- Workaround "Maximum writeset size exceeded" SQL error when pruning search results
- Add Maximum number of search/find new results for guests option
- Initialized to the same value as "Maximum number of search/find new results"
Version 2.19.1 - Minor feature update :
- Update for StandardLib v1.24.0+ support (not required)
- Add "Only show posts in member's recent content" option (default to true, XF 2.3.8+ default behavior)
- Fix XSS with search term rendering
- Render thread prefixes in search result terms for a search query
