[Roi] ALTACHA CAPTCHA 2.1.1
XF 2.3 [Roi] ALTACHA CAPTCHA 2.1.1
Titre du sujet Titre du sujet [Roi] ALTACHA CAPTCHA 2.1.1
Affichages Affichages 37
ALTCHA for XenForo
A XenForo add-on that integrates the ALTCHA human verification system, providing a modern, privacy-friendly CAPTCHA alternative that offers better protection against bots with a smooth user experience.
Github: https://github.com/Rayzggz/Xenforo-ALTCHA
🧩 Notes
This add-on uses ALTCHA Server Integration with the “Verifying without Sentinel” mode. Thanks to this, it works completely independently and it is completely free to use. It does not depend on, require, or support ALTCHA Sentinel.
Hence, this add-on does not support the advanced features provided by ALTCHA Sentinel.
⚙️ Configuration
Admin Control Panel -> Setup -> Options -> User registration -> Enable CAPTCHA for guests
Private Secret Key: Your ALTCHA private secret key. This key used to HMAC sign the verification requests. Make sure to keep it secure and do not share it publicly.
Complexity: A numeric value that determines the difficulty of the challenges presented to users. Higher values increase security but may impact user experience.
ALTCHA Script URL: The URL of the ALTCHA JavaScript file to be included on pages where verification is required. Default is https://cdn.jsdelivr.net/gh/altcha-org/altcha/dist/altcha.min.js . See ALTCHA Documentation for more details.
i18n JS URL: The URL of the ALTCHA internationalization JavaScript file to support multiple languages. See ALTCHA Documentation for more details.
🧰 Compatibility
Developed and tested for XenForo 2.3.3 and PHP 8.3.14
Technically compatible with XenForo 2.2+ and PHP 8.2+ but not officially tested.
✨ Acknowledgements
ALTCHA
altcha-lib-php
📄 License
This add-on is licensed under the MIT License. See the LICENSE file for more details.
Version 2.0.0 :
This version is only recommended for users who want to use ALTCHA Widget v3.
ALTCHA Widget v3 is still in beta testing.
Version 2.0.0 is only recommended for users who want to use ALTCHA Widget v3.
It is recommended to download version 1.1.0 of the plugin, as this version works well with ALTCHA Widget v2.
Known issues:
minDuration, hideLogo, and hideFooter do not work.
Version 2.1.0 What's Changed :
🆕 New Features
* Add options to allow for more configuration.
🐛 Bug Fixes
* Fix hideLogo and hideFooter not working in v3 widget.
Version 2.1.1 What's Changed :
🐛 Bug Fixes
  • Fix exceptions caused by debugging code.
  • Fix some potential security issues.
Télécharger V2.1.1 :
