Probably not recommended for larger forums, but..
This is a 2-or-3-step cache rebuild for reactions, depending on how you wish to proceed;
To use it: install the add-on, then run via Tools > Rebuild Caches > "Rebuild reaction caches"
Provided at no cost in recognition of admins having to deal with morons inclined to abuse such features.
- Orphans - Only if you tick the checkbox - Deletes reactions from hard-deleted accounts first.
- Content caches - Always runs - Recalculates
reaction_score/reactions/reaction_userson every registered content type. - User totals - Always runs - Sweeps every member and recalculates their
xf_user.reaction_score, using the exact same repository method XF's own "Rebuild reaction score" option uses.
