Posts Of The Week Add-on for XenForo
Elevate user engagement and highlight community interactions with the "Post Of The Week" XenForo add-on. This powerful tool automatically identifies and showcases the most reacted-to posts from your forum, providing a dynamic and engaging way to celebrate user contributions.
Key Features :
1. Highlight Top Content: Automatically feature the most reacted posts from the last week, capturing the essence of what your community loves and sparking more discussions.
2. Customizable Time Frame: Use the flexible backend settings to choose posts from the last week or earlier, with the ability to specify how many weeks back you want to look. This ensures that you can tailor the feature to fit your forum's unique rhythm and engagement patterns.
3. Applicable Forum Options: Admins have the flexibility to select specific forums from which the most liked posts will be displayed. This allows for targeted highlighting of content from particular areas of interest or importance within your community.
4. Engagement Insights: Gain insights into your community’s preferences by identifying which posts resonate most with users, helping you understand trends and popular topics.
5. User Recognition: Acknowledge and celebrate active contributors by putting their posts in the spotlight, encouraging continued participation and content creation.
6. API Integration: With the included API, you can easily integrate and retrieve data, allowing for seamless synchronization with other tools or custom solutions. This enables you to display the featured posts in various formats across different platforms.
Options :
Front End View
Why Choose Post Of The Week?
By regularly showcasing the most popular content, this add-on not only encourages higher engagement rates but also fosters a sense of community by recognizing and rewarding valuable contributions. Whether you're looking to boost activity on your forum or provide users with a curated view of the week's highlights, "Post Of The Week" is an essential tool for any XenForo community.
If you encounter any issues with the "Post Of The Week" add-on, please report them to ensure a smooth and efficient resolution.
Version 1.0.2 : [Update] Post Of The Week: Added Collapsible Posts + Image Hiding +Limit character of the Post
I'm excited to bring you some fantastic new features for the Post Of The Week add-on that will improve both the user experience and the presentation of your highlighted posts!
These features are designed to help you maintain a neat and engaging layout for your forum’s top content, making the "Post Of The Week" even more powerful for showcasing your community’s best discussions.
POTW v1.0.3 – Compatibility Fix for XF 2.2.17+
Changelog
Version 1.0.4 New Widget Feature: "Post of the Week" Now Fully Customizable with Image Hiding & Limit Options :
I've just released an exciting update for the Post of the Week (POTW) Add-on!
This update introduces several key improvements, including:
Version 1.0.10 What's New in 1.0.10 :
This major update brings recognition, moderation, and performance improvements:
Key Features :
Options :
Front End View
- Collapsible Week Posts: Posts within the Post Of The Week section can now be collapsed for a cleaner, more organized display. Users can expand them when they want to read more, making the section easier to navigate.
- Hide Images: Want a more streamlined presentation? Admins can now choose to hide images from the post content, ensuring a uniform look across all featured posts.
- Character Limit: You can now set a character limit for featured posts, ensuring that only concise and engaging content is highlighted, improving readability and user experience.
- Added option to collapse posts within the week section for a cleaner display.
- Added option to hide images from posts for a uniform appearance.
- Added character limit for featured posts to ensure concise and engaging content.
Changelog
- Fixed: Type error related to getConfigFromOptions() when used on XenForo v2.2.17+, where an unexpected ArrayObject was passed instead of the expected XF\Options instance.
- Improved: Controller logic now gracefully handles and recovers from option type mismatches to ensure compatibility across various XF versions.
- Tested: Add-on now fully tested and compatible with XenForo 2.2.17 and above.
- Customizable Post Limit: You can now control how many posts appear in the widget using the "Number of posts to display" option.
- Hide Images Option: A new feature allows you to hide images in post content while keeping reaction icons visible. This option is perfect for keeping your widget clean without losing engagement features.
- Enhanced Snippet Length: Easily control how much of each post is shown in the widget, with a customizable snippet length.
- Bug Fixes & Performance Enhancements: Various improvements to ensure smoother performance and better user experience.
- Simply install the latest version from the Admin Control Panel, and the new options will be available in the widget configuration page.
- Optionally, adjust the widget settings to enable or disable image hiding and tweak the number of posts shown.
- POTW Win Counter: The add-on now automatically records the winner of each week (the most reacted post) and keeps a full win history. Each user's total wins are displayed as a "POTW" counter in the message user info (postbit) and on member profiles — permanent recognition for your best contributors.
- Promote to POTW: A new "Can promote POTW?" permission lets your staff manually promote any post to the POTW page. A "Promote POTW" link appears next to Reply on every post; after confirmation, the post is pinned in a dedicated collapsible "Promoted posts" section at the top of the POTW page until the end of the week, marked with a "Promoted post" badge. Promotions can be removed at any time by permitted users.
- Exclude Threads: A new "Exclude Thread IDs" option lets admins keep specific threads (e.g. games or off-topic megathreads that farm reactions) out of POTW entirely, so the spotlight stays on genuine discussion.
- Smarter Alerts: Watchers are now only alerted when there actually are new qualifying posts — no more empty "post of the week has been updated" notifications.
- Major Performance Upgrade: The POTW page and widget now run on a single optimized query with built-in caching and a supporting database index, dramatically reducing load on busy boards.
- Pagination Fix: Week sections now paginate cleanly — each page shows only its own weeks' headings and posts.
