This add-on allows infinite scrolling for threads and posts. It removes the bottom pagination and replaces it with the infinite loading functionality, while top pagination is left available.
Supported add-ons:
After connecting three times has failed :
Built-in options :
Disclaimer :
This is something I use on my forum and decided to share with everyone else. I'm not offering unlimited support for this, but will help where needed.
Télécharger V1.0.0 Alpha 3 :
Version 1.0.0 Bêta 5 :
Version 1.0.0 Beta 6 :
Télécharger V1.0.0 Bêta 6 :
Version 1.0.0 :
- Added: Infinite scrolling for whats new posts.
- Only /whats-new/posts
Version 1.0.1 :
Version 1.0.2 :
Currently, the pause feature is not available for [XB] Forum Content List Tabs because the add-on does not use pagination. Will consider adding in the future.
Version 1.0.3 :
- Fix: Whats new posts banner 'Threads below have not been updated since your last visit.' would would only display on page 1. If on page 2 or further, would not show.
Télécharger V1.0.3 :
Version 1.0.4 :
Télécharger V1.0.5 :
Version 1.1.0 :
We have released a new version with new features and improvements.
Version 1.1.1 :
We have released a new maintenance update that fixes a critical issue with XenForo 2.3.13. Please update to the latest version before upgrading.
Supported add-ons:
- [XB] Forum Content List Tabs - with infinite scrolling enabled here, you can have a Discourse-like view on the index page.
Built-in options :
Disclaimer :
Version 1.0.0 Bêta 1 :
Doing a beta round, since more issues have been identified. @Max Taxable has very helpful in testing and identifying problems.
Version 1.0.0 Bêta 3 :
- Fixed: S9e Media Embeds were not being initialized after load. This issue has been fixed.
- Added: For extremely long threads, it is difficult to reply to it with the infinite loading. So I have added a reply stopper that appears when a user clicks on a reply button in the thread. Once the reply has been clicked, there will be a button under the last post that says "Resume loading". This is a phrase and can be changed.
- Added: Added a style property to force top pagination back on mobile. Something I overlooked is that the default theme removes top pagination so it can be difficult to navigate through the thread. Some themes already do this, so I only recommend clicking on this style property if your current theme doesn't do it.
<div class="infinite-scroll-ad-container">
<!-- ad here -->
</div>
- Fix: Better handling for loading procedures in all areas
- Fix: Better handling for reply stopper in posts
- Fix: Article forum grid support
- Added: Page divider for threads and posts. This option is located in style properties to enable.
- Added: Mobile scrolling distance option. I added this option to help counteract long sidebars below content.
- Added: User preference option to disable infinite scrolling. This user preference is enabled by default.
- Added: User group permission to use infinite scrolling.
- Added: Clicking on Page X in the page divider will now take you to that page.
- AdSense does not work between posts. I'm currently working on getting an AdSense account set up to test this.
- Depending on your uBlock configuration, it may block the infinite scrolling script. I changed the ad detection class
infinite-scroll-ad-containertoinfinite-scroll-container to help counteract this. It's working on my end with uBlock enabled, but I would like feedback regarding this.
- Fix: Extra query parameter removed when clicking on page number in threads and posts
- Fix: Array to string conversion error occurred when filtering prefixes with Multi Prefix installed.
- Add: All text is fully phrased now for easy translation.
Version 1.0.0 :
Version 1.0.1 :
- Added: New option to prevent the user's new reply from being inserted in the middle of a thread. This only applies if there are more pages in the thread to load. Users will receive an AJAX notification indicating their reply has been posted. If the user is at the last page of the thread, default reply behavior will resume.
- Maintenance: Code clean up and performance improvements
Version 1.0.2 :
- Change: 'Resume loading' button is now 'Resume scrolling'. Phrase can be changed.
- Change: Bottom pagination is now always visible.
- Change: Reorganized and renamed options slightly
- Added: Pause button is now available inside page dividers, so users may pause infinite scrolling if they need to access pagination or other reasons. Pause button will not show up on the last page. Once the user hits pause, the resume scrolling button will appear at the bottom. This change applies to discussion list, threads, and whats new posts.
Version 1.0.3 :
Version 1.0.4 :
- Fixed issue where the page title on the new posts tab on the what's new page would revert to the board title.
- Removed support for [XB] Content Feeds since they have implemented their own infinite scrolling.
- Merged all JS into scroll.js
- Various performance improvements
Version 1.1.0 :
- There is now a floating reply bar over every thread longer than 1 page that will take you to the editor when clicking on it. It has a scroll progress bar indicating scroll distance, the page number, and a play/pause button to control infinite scrolling.
- There are now four options to control reply behavior:
- Insert reply inline follows default behavior, adding the post to the loaded content.
- Hold reply, display notice with link keeps it out of view and links to it.
- Jump to reply navigates directly to the reply on its own page.
- Confirm reply quietly displays a brief message and makes no changes to the loaded posts.
- Infinite scrolling is now available in direct messages
- Fixed broken infinite scrolling in article forums
- Our shared branding is now integrated. Removal at no extra cost.
Version 1.1.1 :
- XenForo 2.3.13 introduces new security measures that caused a fatal error regarding our shared copyright footer.
