Location Explain 1.0.5
XF 2.2 / 2.3 Location Explain 1.0.5
Titre du sujet Titre du sujet Location Explain 1.0.5
Affichages Affichages 257
Adds an explanation to the Location field on the registration form (if it is shown) and on the account details form.
If you prefer users to enter their location in a specific format, this will allow you to describe your requirements.
Note that v1.0.1 is the minimum version required for XF 2.2.8 or later
Settings :
Registration form :
Account details form :
Version 1.0.2 fix for XF 2.3 compatibility :
- fix for XF 2.3 compatibility
Version 1.0.3 (2025-12-12)​
- run enqueuePostUpgradeCleanUp() during upgrades if we're running XF2.3+
Version 1.0.4 (2026-09-30)​
- the option's explanation now says the registration form shows the text only when "Require location" is enabled, and that it is plain text
Version 1.0.5 (2026-10-13)​
  • answer the hampel_admin_api_redaction code event to declare that the option is not a secret, so an add-on that reports a forum's configuration with secrets removed can show the explanation text — this adds no dependency, and does nothing on a forum where no add-on defines that event
Télécharger V1.0.5 :
