Hide Sidebar 1.0.4
XF 2.1 / 2.2 / 2.3 Hide Sidebar 1.0.4
Hide Sidebar 1.0.4
Titre du sujet Titre du sujet Hide Sidebar 1.0.4
Réponses Réponses 8
Affichages Affichages 621
Hide sidebar on selected nodes.
Simply add a comma-separated list of node_ids to the options and the sidebar will not appear on those nodes.
This affects both forum_view* and thread_view* as well as search_forum_view templates.
Version 1.0.1 - cleanup release :
- Mostly just code cleanup - no addon changes, upgrading optional
Version 1.0.2 (2025-12-11)​
- run enqueuePostUpgradeCleanUp during upgrades if we're running XF2.3+
Version 1.0.3 (2026-09-27)​
  • XenForo 2.2.0 or later is now required
  • the node list option now rejects anything that is not a node ID and names the rejected values; previously a typo such as 1O was saved and read as node 1 — re-save the option after upgrading to check an existing value
  • reworded the option's explanation: the sidebar is hidden on each listed forum, on every thread in it, and on each listed search forum
Version 1.0.4 (2026-10-12)​
  • answers the hampel_admin_api_redaction code event, declaring that none of this add-on's settings are secrets, so a monitoring add-on that fires the event can report them; a forum without such an add-on is unaffected
  • no change to how the sidebar is hidden
Télécharger V1.0.4 :
