Hide Resource Ratings 2.0.2
XF 2.2 / 2.3 Hide Resource Ratings 2.0.2
Titre du sujet Titre du sujet Hide Resource Ratings 2.0.2
Réponses Réponses 5
Affichages Affichages 268
Additional requirements : XFRM v2.2.x+
XenForo allows you to prevent people from rating resources using simple permissions, however it does not hide the ratings stars from the UI.
This XF 2.x addon simply hides all reference to resource ratings from the UI - including the stars
It does not disable or prohibit people from using ratings - you should use the core permission settings for that.
You may also want to disable the Top resources widget - it's a bit pointless if you're not doing ratings.
Version 1.x of this addon is for XF 2.2 / XFRM 2.2 only
Version 2.x of this addon is for XF 2.3 / XFRM 2.3 only and is NOT compatible with XF 2.2 / XFRM 2.2
(Note that installing the wrong version won't really break anything - it just won't hide things as expected)
Let me know if you use this addon and find any stars that I've missed !
Version 2.0.1 (2026-09-27)​
  • fix rating stars and rating count still showing in the article style of the trending content widget
  • also hide rating stars in the reviews page header, the featured content widget and embedded reviews
  • now requires XenForo Resource Manager 2.3.0 or later, so the add-on can no longer be installed on a forum without it
  • corrected the add-on description
Version 2.0.2 (2026-10-12)​
  • tell the Hampel/AdminApi add-on, where a forum runs it, that this add-on has no secret settings; nothing changes on a forum without it, and nothing changes in what is hidden
Télécharger V2.0.2 :
XF 2.1 / 2.2 / 2.3  [TC] Robohash Avatars 1.1.0
XF 2.2 / 2.3  Who Viewed 1.0.1
