FX – CopyShield 1.1.1
XF 2.0 / 2.1 / 2.2 / 2.3 FX – CopyShield 1.1.1
Titre du sujet Titre du sujet FX – CopyShield 1.1.1
Réponses Réponses 7
Affichages Affichages 176
Introduction :
FX – CopyShield is a lightweight XenForo add-on that helps prevent unauthorized copying of post content. It is the ideal solution for forums that share knowledge, documents, or other exclusive content that requires protection.
Key Features :
  • Disable right-click, text selection, copy, and drag
  • Block keyboard shortcuts: Ctrl+C, Ctrl+U, F12, PrintScreen, and more
  • Show a minimal toast notification instead of intrusive alerts
  • Option to apply protection to the first article only or all articles
  • Lightweight, fast, and performance-friendly
Easy Integration :
  • Install the add-on via AdminCP
  • Change the addon's options
  • Check permission on Usergroup
Technical Information :
  • Add-on Name: FX - CopyShield
  • Version: 1.0
  • Compatible with: XenForo 2.1+, 2.2+, 2.3+
  • Developer: FX
Version 1.1 :
README.md
  1. XFRM (XenForo Resource Manager) Support:
    • Extended copy protection to XFRM resource description pages, resource updates, and review content.
    • Added dedicated permission under Resource Manager permissions: FX - CopyShield: Lock resource content.
  2. Form Input Bypass Fix (Regression Prevention):
    • Added smart element detection (isInputElement) for <input>, <textarea>, Froala Editor (.fr-element, .js-editor), and [contenteditable="true"].
    • Users can type, select (Ctrl+A), copy (Ctrl+C), cut (Ctrl+X), and paste (Ctrl+V) freely inside input fields without triggering protection blocks.
  3. New Admin CP Options:
    • Lock first post only: Choose whether to lock only opening posts or all posts in threads.
    • Enable protection for XFRM (Resource Manager): Toggle copy protection specifically for XFRM pages.
    • Block Developer Tools & View Source shortcuts: Toggle blocking of developer inspection keys (F12, Ctrl+Shift+I/J/C, Ctrl+U, PrintScreen, Ctrl+S, Ctrl+P).
  4. Glassmorphic Toast Alert & Print Shield:
    • Modern floating toast notification with smooth 2.2s auto-fade animation.
    • @media print rules automatically hide protected content when printing web pages.
Télécharger V1.1 :
Version 1.1.1 : Fix copy protection to XFRM resource error in 1.1
XF 2.0 / 2.1 / 2.2 / 2.3  s9e Media Sites 2.19.3
