Additional requirements : External SSL access (port 443 outbound)
Forum Fortress: a fresh take on forum spam blocking
Designed to be more than just another blocklist. Forum Fortress checks registration, posting and profile activity to let your genuine members sail through smoothly and stop the spambots and malicious humans.
It's designed specifically for forums - to catch the edge cases, such as those posing as genuine members then quietly editing in backlinks all over your community 3 months later, or 'profile link spam' that is a daily fight for many.
Screenshots
XF Admin CP
Management portal
Interactive Portal Demo
What it does
Easy to set up
Forum Fortress has been designed to be simple to set up with no complicated settings. Just install the plugin - and your protection starts. Every site gets a 30 day trial of Pro before being moved to the Free tier, which is designed to offer a decent level of protection for small-to-medium sites.
No credit card, no sign up form - you don't even have to enter your email if you don't want to.
Privacy
Individual IP addresses, email addresses, usernames and domains can be checked against the public hitlist, but those items aren't publicly linked together. A lookup of an IP address isn't going to give you a list of usernames and email addresses associated with it.
Try the Public Checker
Internally, Forum Fortress is largely built around scoring those individual indicators and combining the results to make a decision, rather than trying to build a profile of each forum member.
Plaintext values sent to the system are available in your portal logs and to Forum Fortress for 5 days before getting transformed to one way hashes. That gives you enough time to monitor how the system is performing on your site without us storing plaintext data any longer than needed.
We can then compare these hashes in the future to spot repeat offenders.
For communities that need the paperwork as well as the technical side, a Data Processing Agreement (DPA) is available.
Multimod
Pro also includes Multimod, giving people running several communities one place to deal with reports and moderation activity across them.
It can span different forum platforms too, so it's useful if you're looking after more than just XenForo.
Pricing
Free: 2,000 checks/month, up to 50 blocks/day
Core: $10/year, 20,000 checks/month
Pro: $40/year, 100,000 checks/month + Multimod
The Free plan isn't intended as a glorified trial. For plenty of small and medium communities it should be enough indefinitely.
Works well with other spam plugins
Forum Fortress is designed to work either as the only spam solution on your site, or as a complement to your existing anti-spam stack.
Use it as a 'mop up' tool for anything that gets through your existing layers, or strip out things that make life more difficult for your genuine members such as CAPTCHAs and let Forum Fortress handle everything.
Télécharger V1.9.3 :
Source :
forumfortress.com
Screenshots
XF Admin CP
Management portal
What it does
- Blocks spam registrations
- Catches profile, signature and link spam
- Can make CAPTCHA-free registration practical
- Works alongside XenForo's existing spam controls, StopForumSpam, DNSBLs and other tools
- Or can replace most/all of those layers if you prefer
- No client-side JavaScript or browser fingerprinting - no changes to your site templates at all
- Privacy-conscious by design, with limited retention of member data
- Multiple API endpoints with automatic failover if latency or availability becomes a problem
Easy to set up
Privacy
Multimod
Pricing
Source :
XenForo - Forum Fortress Documentation
Learn about XenForo in the Forum Fortress documentation.
