DEBtech AI Hub 1.0.2
XF 2.3 DEBtech AI Hub 1.0.2
Titre du sujet Titre du sujet DEBtech AI Hub 1.0.2
Affichages Affichages 26
⚠️ Important notice — please read first​
The DEBtech AI Hub is not a standalone add-on and provides no visible functionality on its own. It is a technical foundation whose sole purpose is to supply our DEBtech AI add-ons with a unified, secure, and observable API layer.
In other words: Without at least one of the supported DEBtech add-ons, the AI Hub has no purpose. Installing it only makes sense if you are using (or plan to use) one of the following add-ons.
🧩 Add-ons this hub was built for​
  • DEBtech Portal AI Suite Pro — AI news, AskBox, interest categories, cover images (hard dependency)
  • DEBtech Advertising Suite Pro — AI-optimized product descriptions (next release)
  • Future DEBtech AI add-ons — all of them route through this central hub
If you are not running any of these add-ons, do not install the AI Hub — it will sit idle.
🚀 What does the AI Hub do?​
The AI Hub provides a single unified interface to eight different AI providers. Instead of every add-on bringing its own API keys, retry logic, and cost tracking, the hub bundles it all centrally — with budget enforcement, structured logging, and an admin dashboard.
Supported providers:
  • ☁️ Cloud: OpenAI · OpenRouter · DeepSeek
  • 🖥️ Local: Ollama · LocalAI · vLLM · LM Studio · SD.cpp
✨ Core Features​
  • Multi-provider management — All 8 providers usable simultaneously, each add-on picks its own
  • Smart routing — Automatic retry on HTTP 429/500/502/503/504 with exponential backoff
  • Fallback provider chain — If OpenAI goes down, OpenRouter/DeepSeek takes over automatically
  • Budget tracking & enforcement — Monthly budget per provider; calls are blocked when exceeded
  • Streaming support (SSE) — Live-typing output for long chat responses
  • API log with filter & search — Every API call with tokens, cost, duration, and prompt excerpt
  • Log export — CSV or JSON for analysis in Excel/BI tools
  • Reasoning model detection — o-series, GPT-5+, DeepSeek-R1 get longer timeouts and proper parameters automatically
  • Setup assistant — Detects OS, RAM, GPU, Docker, Python and recommends suitable models for your hardware
  • Zero-load dashboard — Stats are pre-computed every 10 minutes via cron; dashboard loads with 0 SQL queries
  • Model test tool — Test chat and image generation straight from the admin panel, including custom prompts
🔒 Security​
  • Admin permission system — Per-admin "Manage AI Hub" permission control
  • SSRF protection — Provider URLs validated against an allowlist (AWS/GCE metadata endpoints blocked)
  • CSP-compliant JavaScript — No inline onclick, runs under strict Content Security Policies
  • API key redaction — Bearer tokens and keys stripped from all error messages and logs
  • CSV injection protection — Exported log cells hardened against Excel formula injection
  • XSS hardening — All user/provider strings escaped; image URLs only via DOM API (no innerHTML)
  • Input validation — Model tester with provider and model allowlist, prompt length cap
📊 Admin Dashboard​
  • KPI overview: Requests today/week/total · Monthly cost · Avg response time · 24h error rate
  • Provider status: Live check for each provider with latency
  • Usage per add-on: Which component consumes how many tokens
  • Budget monitor: Percentage bar per provider, warning at 80 %
  • Recent API calls: The last 10 calls at a glance
⚙️ Technical Details​
  • XenForo version: 2.3.9+
  • PHP version: 8.1+
  • Database tables: 2 (xf_deb_aihub_log, xf_deb_aihub_budget)
  • Cron jobs: 3 (stats pre-compute, log cleanup, budget sync)
  • Namespace: DEB\AiHub
  • Languages: English (master) + German (fully translated, 210 phrases)
  • No external dependencies beyond XenForo Core + Guzzle (already included in XF)
🎯 Currently Supported Image Models (April 2026)​
  • GPT Image 1.5 (Flagship) — OpenAI's successor to DALL-E 3, 15 % cheaper
  • GPT Image 1 Mini (Budget) — For high-volume use cases, approx. 67 % cheaper than Flagship
  • Stable Diffusion 2.1 / SDXL Turbo / FLUX.1 via SD.cpp locally (GPU recommended)
Note: DALL-E 2 and DALL-E 3 have been deprecated by OpenAI as of May 12, 2026 and have already been fully replaced by GPT Image 1.5 / 1 Mini in this add-on.
📦 Installation​
  • Download the ZIP file
  • Install via Admin → Add-ons → Install/Upgrade from Archive
  • Under DEBtech AI Hub → Settings, enable at least one provider and enter an API key
  • Optional: Visit the setup assistant for hardware analysis and model recommendations
  • Install a matching DEBtech AI add-on (e.g. Portal AI Suite Pro)
Version 1.0.2 :
Fixed :
  • Fixed local OpenAI-compatible provider URLs when the configured base URL already ends in /v1, preventing invalid /v1/v1/... requests for model listing, connection tests, chat completions, streaming, and image generation.
  • Fixed the custom admin settings form so disabled boolean options are saved correctly for API logging and budget alerts.
  • Fixed provider configuration drift by adding DeepSeek and SD.cpp consistently to default provider options, settings UI, and exported add-on data.
Verified :
  • Verified PHP syntax for all AI Hub PHP files.
  • Verified XenForo add-on metadata, options, routes, controllers, entities, cron entries, templates, and package contents.
  • Verified fresh install setup steps create the AI Hub log and budget tables with the expected schema and indexes.
  • Verified release packaging includes the updated add-on data and hashes.
