- [DD] Core
- You want to easy style your prefixes?
- You want them different in different styles?
- You want own styles?
- You want the same for userbanners?
- You want icons?
Easy, here you are!
Works also with the Resource Manager!
Télécharger V1.1.0 Release candidate 4 :
Version 1.3.3 :
Version 1.3.4 (Patch Release)
Fixed:
- [DD] Core
- You want icons?
Easy, here you are!
Version 1.3.3 :
- Fixed several minor bugs
- optimizes Setup and Code Maintenance
- Prefix Icons are now visible also in Drop Downs in Create Thread and in Inline Moderation
Fixed:
- Fixed
LogicExceptionwhen sorting label layouts by guardingStyleProperty::_postSave()withisChanged('property_value')andforceSet. - Full PHP 8.2+ baseline and PHP 8.4-ready code review: strict method return types, typed class properties, and unused imports cleaned up across all PHP files.
- Fixed cache key mismatch in
XFRM\Entity\ResourcePrefixto useResourceItemIcons. - Fixed fatal undefined method call
getUserGroupRepo()inXF\Entity\UserGroup. - Fixed class name casing for
StyleRepository::classinAdminPrefixoption handler. - Repaired broken
LabelLayoutRepository::fixLayoutData()method. - Added complete set of documentation screenshots in
_docs/screenshots/.
- XFCP Class Extension Compatibility: Fixed method signature declarations on overridden XenForo core methods (
ForumController::saveTypeData(),UserGroupController,StyleController,StylePropertyController,UserGroup,ThreadPrefix,ResourcePrefix, andUserGroupRepository) by removing narrowed return types, preventing PHP fatal declaration incompatibility errors when other add-ons extend the same classes.
- Bugfix: Fixed an issue where dynamically created label layout style properties and their phrases were deleted during add-on upgrades or dev imports. These properties and phrases now strictly retain an empty
addon_id, preventing XenForo from dropping them. An automated migration cleanly migrates existing installations.
