Additional requirements :XF 2.2 - [cv6] Core 1.0
Now new for XenForo 2.2.x
This AddOn works with the default Theme, if you change essential parts of the theme in your own styling, there may be changes to the template mods necessary. If it not works out of the box with your style, please drop me a conversation.
You can activate, if the nodes should be displayed in the admincp as well, and there is a brief icon preview n the settings.
Important: Now this AddOn requires my Core AddOn.
Settings in the Node Display Area of your Style :
You can add Duotone Icons and add every other FontAwesome Class to modify the icon (Exept sizing!)
Sample:
To enable the SVG Inject option, you need to turn this on in the Settings.
Now you can set Forums to read with a double click in the icon.
New: You now can collapse categories!
You can choose inside the categories, if they can be collapsed.
On a style base you can decide to disable collapsing and define the collapse Icon.
Have fun and tell me yout thoughts and ideas to improve this sneaky addon.
Have fun!
If you want to see, how it can look in Live Mode, just visit my Forum or look at this screenshot :
Télécharger V1.3.0 :
Version 1.3.2 :
- Updated the admin templates to allow users to properly select and update the node icons.
- Fixed browser console error related to missing admin.js
Télécharger V1.3.2 :
Version 1.3.3 :
There is no need to update if you are running version 1.3.2
Added support for forum search for this addon >> [J] Extra Widgets
Télécharger V1.3.3 :
Version 1.3.4 :
There is no need to update if you are not using this addon >> [J] Extra Widgets
Fixed font awesome icon support for find forum widget in this addon >> [J] Extra Widgets
Télécharger V1.3.4 :
Version 1.5.1 Release Candidate 3 :
Télécharger V1.5.1 Release Candidate 3 :
Version 1.5.1 Release Candidate 4 :
Télécharger V1.5.5 :
Release 1.5.7 (ID 1050770)
Sample:
Have fun!
Version 1.3.2 :
Version 1.3.3 :
Version 1.3.4 :
- Works fully with XF2.3
- Requires XF 2.3
- New Settings: Default Icons for several Icons appearing in XF
- Column view for subforums
- several mionor bugs
- page icon now displayed on page
- renaming to [DD]
- NEW: Default Icon Settings
- Deactivate yout forum in the Settins.
- Update Core AddOn
- Update any other AddOn
- Check if all runs as expected
- if Yes, turn on Forum again.
Version 1.5.2
- Setup: Fixed column checking logic in
upgrade1050070Step1to ensure missing columns are correctly added. - Setup: Updated
dropColumnsinuninstallStep1to use array syntax. - Entity: Cleaned up
NodeIconentity relations and finder methods.
- Core v1.4.0 Integration: Updated dependency on
cv6/Coreto v1.4.0 (1040070). - FontAwesome Icon Autocomplete: Enabled live autocompletion (
arg-autocomplete="{{ true }}") across all ACP node edit forms (cv6_ni_macros) and style property forms (cv6_collapse_icon). - Options Validation & Autocomplete: Enabled
autocomplete=1and linkedverifyValidIconOptionalvalidation to all default icon options in the ACP.
- Core Dependency: Raised minimum requirement for
cv6/Coreto version 1.4.2 (ID 1040270). - Macro Syntax Standardization: Converted all macro calls in template modifications to strict XenForo syntax
<xf:macro id="cv6_nodeicon_macros::..." />
- CSS Title Layout Fix: Added fixed dimensions for node icon images in page titles (
div.p-title img.cv6-node--img) to prevent unintended line breaks inside the flexbox container. - Controller Extension: Restored
parent::saveTypeData()call in theCategoryadmin controller extension. - JavaScript Promise Handling: Updated
XF.ajax()usage inmarkread.jsto native ES6 Promises using.then()and.catch(). - Template Fixes & Syntax: Fixed syntax errors in
cv6_nodeicon_macros.html, updated JS include syntax tosrc/min, and removed debug outputs. - Entity Architecture: Migrated database column definitions from event listeners to
getStructure()overrides in entity extensions.
- Template-Modifikationen Bereinigung: Verwaiste schließende Klammern (}}) in den Bedingungen der Template-Modifikationen für category_view, forum_list und forum_view entfernt.
- XenForo 2.3 Skript-Tag Standardisierung: Attribut-Syntax bei der SVG-Injection-Modifikation (PAGE_CONTAINER) von veraltetem dev/addOn auf das standardisierte src/addon umgestellt.
- Node Title CSS Layout: Added explicit height and width dimensions for node icon images in page titles (div.p-title img.cv6-node--img) to prevent flex container line breaks.
- Controller Extension: Restored parent::saveTypeData() call in Category admin controller extension to preserve the class extension chain.
- JavaScript Promise Handling: Updated XF.ajax() in markread.js to native ES6 Promises with [.then()[/I] and [.catch()[/I].
- Template Syntax & Cleanup: Fixed template condition syntax error in cv6_nodeicon_macros.html, updated admin JS include syntax to src/min, and removed debug output.
- Entity Architecture: Migrated entity structure column definitions from event listener to getStructure() overrides in entity extensions.
