[DD] Custom Field Extension 1.3.5
XF 2.3 [DD] Custom Field Extension 1.3.5
Titre du sujet Titre du sujet [DD] Custom Field Extension 1.3.5
Réponses Réponses 14
Affichages Affichages 643
With this brand new AddOn you can add new types of custom fields :
  • Image
    The User can upload one or multiple images (XenForo Attachment System is used for this)
  • Combo Box
    The Combo Box combines a Text box and a Simple Drop Down Box. You can change settings for both elements as usual and define the order of both.
New Options :
  • The number files now has a step value
  • You can specify a placeholder
All other: See images !
Supports also Resource Manager.
You can add very simple with this add on a tab with screenshots.
Even if this Version has the RC label, please not use this in production and create a bckup first!
This addon changes some core templates on a heavy base. I tried to do this very carefully, but it can interfere with other addons that modified attachment behavior. If you encoutner issues with other addons, please let me know and I will take a look.
It works in default Style. Please drop me a conversation if it not works in your modified style.
Télécharger V1.0.0 RC2 :
Version 1.0.0.RC3 Bugs fixed :
Fixed Bug which occurs when editing a post with attachments. The Insert Button was gone..
Optimized Code, minor things
added Developer Help
succesfully tested on actual version
Télécharger V1.0.0 RC3 :
Version 1.0.1 RC now with calculation field Bugs fixed update :
Bugs fixed :
error if image file is set as required field and no image is uploaded
image entity not deleted after deleted last attachment for one field
add custom fields database changes after resource manager install
New Features :
Calculation field
with new dependency to loaded library via composer nxp/math-executor
added field id into field list view to grab easily an field if for calculation
Improvements :
switched from listener to Entity Extension with trait, to use entity functions for needed checks
moved development help into AdminCP Page
Télécharger V1.0.1 RC :
Version 1.0.1 RC 3 Bug fixed : creating UserField Entity fails
Télécharger V1.0.1 RC3 :
Version 1.0.3 :
New Field : Entity Chooser
choice field auto sorter buttons
fixed: delete attachments and fields during uninstall
Télécharger V1.0.3 :
Version 1.0.4 : added missing phrases
Version 1.0.5 :
- Fixed image in ACP bug
- Fixed uninstall Bug
Télécharger V1.0.5 :
Version 1.1.0 RC new Features and many bug fixes :
  • fixed mandatory combo field bug
  • fixex resource rating image (wasn't working properly)
  • fixed bug entity chooser ignores required
  • fixed bug with entity chooser has no class selected
  • fixed bug with step display on mobile devices
  • fixed bug with drag-drop upload in first post
  • optimized database structure
  • Upgrade nxp/math-executor to 2.3.1
  • rewrite of save routine to a better (the correct) solution
New features :
  • added ability to allow/disallow empty option with label and styling for combo and default select
  • added empty option also for entity chooser
  • added better styling option for combo box
  • added own zoom icon for compact display
  • added 'full image' and 'thumbnail only' option without overlay and optional lightbox
  • added phrase support for placeholder and new integrated choosertext
  • added sort button for all xf custom field pages
Télécharger V1.1.0 RC :
Version 1.1.0 Release Candidate 2 : Bug in registration fixed.
Télécharger V1.1.0 RC 2 :
Version 1.1.0 Release Candidate 3 Changelog :
  1. Resolved missing column creation issue for Image custom field during initial installation, ensuring consistent functionality for both fresh installs and upgrades. >> [cv6] Custom Field Extension
  2. Fixed Typo related to XFRM, that was throwing errors when creating a resource.
  3. Fixed Issue to allow editing of custom field on user profile.
Télécharger V1.1.0 RC 3 :
Version 1.3.1 RC 2 - Now with Megia Gallery Support :
  • Added Media Gallery Support
  • Finally fixed New Thread Bug
  • renaming to [DD]
  • NEW: Thread Image Support
Update Core before you update any other of my addons.
  1. Deactivate yout forum in the Settins.
  2. Update Core AddOn
  3. Update any other AddOn
  4. Check if all runs as expected
  5. if Yes, turn on Forum again.
Télécharger V1.3.1 RC 2 :
Version 1.3.2 - xf 2.3.8 +
- Works with 2.3.8
- Fixed Install Bug
- Several minor bugs
Is you encounter after update, that fields are not shown. Just edit and save any field of that part (UserField, ThreadField, etc)
Télécharger V1.3.2 :
Version 1.3.5 :
  • Fixed several minor bugs
  • Code optimisation
Télécharger V1.3.5 :
    60.8 KB · Affichages: 67
    45.6 KB · Affichages: 65
    136.5 KB · Affichages: 65
    29.7 KB · Affichages: 55
    4.9 KB · Affichages: 61
    13 KB · Affichages: 60
    58.2 KB · Affichages: 67
    36.1 KB · Affichages: 57
    148.1 KB · Affichages: 67
    186.1 KB · Affichages: 53
