[DD] Admin Tools 2.5.1
XF 2.2 / 2.3 [DD] Admin Tools 2.5.1
Titre du sujet Titre du sujet [DD] Admin Tools 2.5.1
Réponses Réponses 7
Affichages Affichages 425
You can collapse some lists per add-on.
Requirement : [DD] Core
Actual suuported lists :
  • Template Modifications
  • Event Listeners
  • Class Extensions
  • AddOns
  • Widgets
For details see images.
Update from older Version, see Update Post.
Télécharger V2.1.0 :
Version 2.1.1: [cv6] Admin Tools for XenForo 2.2+ Update 2.1.1
Added collapse ability to permission definition list
Télécharger V2.1.1:
Version 2.1.2 :
- Adds an extra column indicating the modification type:
- 'Magnifying glass' for Search & Replace
- "File code" for Regex.
Télécharger V2.1.2 :
Version 2.4.0 RC 1 - Now Admin Tools :
  • Added several lists
  • Added AddOn Filter to several Pages
  • Renaming to [DD] Admin Tools
Télécharger V2.4.0 Release Candidate 1 :
Version 2.4.2 :
  • Corrected Setup Files
  • Code Maintenance
Télécharger V2.4.2 :
Release 2.5.0 (ID 2050070)
  • Smilies List Collapsing: Added category-level collapse and expand support for the AdminCP Smilies list with persistent state storage.
  • Generic Prefix List Collapsing: Implemented collapse and expand functionality on the generic base_prefix_list, automatically enabling collapsible prefix groups across thread prefixes, resource prefixes, and third-party prefix lists.
  • Collapsible Areas Option: Added options for smilies and prefixes to cv6CollapseArea.
  • Core Multi-Toggle Standard: Migrated all collapsible list views (class_extension_list, code_event_listener_list, template_modification_list, widget_list) to the standardized cv6-multi-toggle component from cv6/Core.
  • Clean Table Layout: Replaced legacy <tbody> splitting with clean row-level targeting using dataList-row--childRow and animated slide wrappers.
  • Core Dependency: Updated minimum required cv6/Core version to 1.5.1 (ID: 1050170).
  • Prefix Route Sanitization: Resolved selector syntax errors when handling route prefixes containing slashes (such as resource-manager/prefixes).
Release 2.5.1 (ID 2050170)
  • Widget List Layout & Visibility: Resolved an issue in widget_list where widget rows remained hidden on page load with default collapse behaviour. Fixed invalid selectors for unpositioned widgets. Fixed header layout where position title and description were forced into a single line inside the flex toggle; description is now cleanly separated below the title with native subsection typography.
  • Template Modification Type Icons: Fixed an issue where the type icons (Simple, RegExp, Callback/PHP) in template_modification_list disappeared due to an exact string matching conflict with child row classes.
Télécharger V2.5.1 :
    127.1 KB · Affichages: 107
    131.5 KB · Affichages: 98
