PHP 7.4.0+ (8.2+ recommended)
Description
Stripe Checkout grants your forum the full power of Stripe, allowing all payment options Stripe offers including Klarna, GiroPay, SEPA and more.
Uses
By adding Stripe Checkout support, you can increase your sales by allowing your users to pay how they want.
Extended Product Information
Multiple Payment Options: Stripe Checkout can integrate with a large range of payment options, tailored for the specific part of the world your customers hail from. If you still want to accept PayPal, Stripe also has support for PayPal via Stripe.
Version 1.2.0 bêta 1 : Feature : Experimental recurring payment support
Télécharger V1.2.0 Bêta 1 :
Version 2.0.0rc1: 2.0.0 Release Candidate 1
Update highlights
!!!This version requires PHP 8.0+!!!
This version removes the "Recurring" support, as this is now natively added to XenForo 2.3. This add-on has also been updated with support for the updated Stripe payment profile handler.
Complete Change Log
Change : Update for compatibility with XF 2.3's built-in Stripe Checkout
Change : Remove "Recurring" flag
Change : Updated macros to XF 2.3 format
Change : Replace various references with class-string<T> equivalents
Change : Update code for PHP 8.0
Fix : Fixed template modifications
Télécharger V2.0.0rc1:
Version 2.0.0 : This version is now considered stable. No issues were discovered during the testing phase.
- Complete Change Log : Version bump
Version 2.0.1 : This version fixes an issue where the custom options would be ignored in the front-end.
- Complete Change Log : Fix the options not loading correctly
Télécharger V2.0.1 :
Version 2.0.2 :
- In this version, you can now specify MobilePay as a supported payment method, if your business is registered in Finland and you sell to Finnish customers.
Feature : Add MobilePay as a supported payment method.
Télécharger V2.0.2 :
Version 2.1.0 :
- This version adds support for the new "Business Profile" feature in eCommerce v5.
Feature : Add support for DragonByte eCommerce v5's Business Profiles
Télécharger V2.1.0 :
Version 2.1.1 :
- This version improves compatibility with future versions of XenForo by moving certain code calls out of templates.
There are no changes to functionality, but the update is recommended to avoid compatibility issues with the upcoming XenForo v2.3.8 & newer.
Télécharger V2.1.1 :
Version 2.1.2 :
- This version fixes an issue with recurring payments where certain payment processors would cause an issue. This add-on's overrides now only apply to single payments.
Télécharger V2.1.2 :
Description
Uses
Update highlights
Complete Change Log
Version 2.0.2 :
Version 2.1.0 :
Version 2.1.1 :
Complete Change Log
Change: Move database query calls from templates to PHP filesTélécharger V2.1.1 :
Version 2.1.2 :
Complete Change Log
Fix : Don't use overridden payment processors list for recurring paymentsTélécharger V2.1.2 :
