[DBTech] DragonByte Member Map 3.0.2
XF 2.1 / 2.2 / 2.3 [DBTech] DragonByte Member Map 3.0.2
Titre du sujet Titre du sujet [DBTech] DragonByte Member Map 3.0.2
Réponses Réponses 21
Affichages Affichages 1 541
Geolocate your members and plot them on an interactive Google map!
Uses
Show your users' locations can be shown on an interactive Google map after being geolocated from their IP addresses.
Also supports the ability to show all users or only those that are currently logged in.
Locations are calculated in batches to ensure smooth performance, or updated by each person using drag & drop.
Markers feature a popup with a mini profile including avatar.
Complete Feature List
  • Choose whether to show all users or only those logged in, and the default map type
  • Choose the number of users to process per scheduled task run
  • Usergroup setting to set if they can access or should be excluded
Notes
If you like this add-on, please consider leaving a Like and/or a review. We would really appreciate it! ?
1597
Télécharger V2.3.6 :
Version 2.3.7 : Update highlights
This version is a quick maintenance update to implement a new method of downloading GeoIP update data as a result of changes made by the provider of the geolocation data (MaxMind).
Complete Change Log
Change: Implemented new method of downloading GeoIP data
Télécharger V2.3.7 :
Version 2.3.8 : Update highlights
This version is a follow-up to the previous version, in order to address an issue where another change in the download format prevented the GeoIP2 database file from being read properly after it was downloaded.
Complete Change Log
Change: Updated GeoIP reader
Fix: Fixed an issue that would prevent a valid GeoIP database file from being downloaded
Télécharger V2.3.8 :
Version 2.4.0 Beta 1 Update highlights
!!! THIS VERSION REQUIRES XENFORO 2.2.0 AND PHP 7.2.0 !!!
This version contains coding style updates and changes for XenForo 2.2.0 / PHP 7.2.0.
It's now possible to auto-fill the location field by utilising the "Google Places" API. Furthermore, the geolocation feature has received some back-end changes to improve reliability and 3rd party support.
This version is flagged as a Beta version as it has not been tested on a live site.
Complete Change Log
Feature:
Autofill for the Location field (powered by Google Places)
Change: Switch geolocating fall-back WebService to a 3rd party alternative
Change: Rework GeoLocate service to be more extendable by other add-ons
Télécharger V2.4.0b1 :
Version 2.4.0 Gold Update highlights
Coinciding with the release of XenForo 2.2.0, all XenForo 2.2 versions are now Gold This is also the last version that will contain the XF 2.2 / PHP 7.2 warning in the release notes.
Complete Change Log : No changes, version bump only
Télécharger V2.4.0 :
Version 2.4.1 Update highlights :
This version resolves an issue when loading options on certain pages other than the main AdminCP settings page.
Fix: When viewing options from pages other than the "Settings" page, a server error could be generated
Télécharger V2.4.1 :
Version 2.4.2 Update highlights :
- This version resolves a couple issues with regards to some members showing on the map who should not be.
Fix : The opt-out setting was not correctly applied
Fix : Users who have been excluded from the map should now more reliably be excluded.
Télécharger V2.4.2 :
Version 2.4.2.1 Fix : The "opt-out" flag behaviour was reversed.
Télécharger V2.4.2.1 :
Version 2.4.3 Fix : "Online users only" would not work as intended.
Télécharger V2.4.3 :
Version 2.5.0 :
This version adds an automatic refresh of the GeoIP database when the MaxMind license key is changed. It also refactors some backend code as well as fixing compatibility issues with PHP 8.2 / 8.4.
Complete Change Log
Feature : Changing the MaxMind GeoIP license key will now immediately trigger a background update
Change : Refactored backend code
Change : Bump minimum PHP version to 7.4 and recommended version to 8.2
Change : Update dependencies to the latest version(s)
Fix : Fix PHP 8.2 compatibility issue
Fix : Fix PHP 8.4 compatibility issue
Télécharger V2.5.0 :
Version 3.0.0rc1: 3.0.0 Release Candidate 1
Update highlights
!!!This version requires PHP 8.0+!!!
This version mainly introduces compatibility with XenForo 2.3. The add-on has been fully updated, meaning no compatibility layers such as loading jQuery or other such patches are required for this add-on.
One big thing to highlight is the fact that Google Maps has been deprecated and replaced with Leaflet/OpenStreetMaps. You no longer need an API key or worry about being charged by Google for your member map. All functionality should be retained.
Furthermore, a few reported bugs since the release of the last version for XenForo 2.2 have also been resolved.
Complete Change Log
Change: Reduced query count due to new XenForo 2.3 functionality
Change: Replace deprecated function calls
Change: Updated macros to XF 2.3 format
Change: Replaced Google Maps with Leaflet/OpenStreetMaps
Change: Replace various references with class-string<T> equivalents
Change: Update code for PHP 8.0
Change: Remove "XenForo" from copyright footer
Change: Necessary changes for the new XenForo 2.3 coding style
Change: Automatically clean up files on upgrade
Fix: Fixed template modifications
Télécharger V3.0.0rc1 :
Version 3.0.0 : This version is now considered stable. No issues were discovered during the testing phase.
- Complete Change Log : Version bump
Télécharger V3.0.0 :
Version 3.0.1 Change Log : Fix: Fix server error when geolocating IP addresses
Télécharger V3.0.1 :
Version 3.0.2 :
- This version brings a slew of bug fixes thanks to automated testing.
- Please see the full changelog below for information about the bugs fixed in this version.
Fix :
Fix a potential issue where the member map pins could be cached too aggressively
Fix : Updating the GeoIP database no longer fails when it runs more than once in the same request, or after an earlier update was interrupted
Fix : The pin color picker in the user group editor no longer lists the map's own marker and layer images as pins
Télécharger V3.0.2 :
merci un petit tuto pour avoir la cle appi google serait le bienvenu j arrive pas a afficher la carte ca me met erreur verifier votre console javascript
