This add-on allows you to customize your 404 error page, keep track of missing URLs and redirect them to new pages.
It comes with a basic error message but you can customize the page the way you want it using HTML and XF template syntax, having the option to remove the header and the footer.
Log can be found in ACP > Tools > 404 not found
Télécharger V1.1.6 :
Version 1.1.7 Bug Fix :
Fixed an issue with checkbox selection reset button.
Also made some changes to the list to make it more compact.
Télécharger V1.1.7 :
Version 1.2.0 : This version is compatible with XenForo 2.3.
Version 1.2.1 :
Version 1.2.1 :
- Added admin option "Enable 404 error log".
- Added new field "Bot name" and search for it.
- Added separate search fields for "URL" and "Redirect URL".
- Made improvements on how search works withing the active tabs and added a new global "Any" when searching.
- Added admin options shortcut in the 404 not found list page.
