Additional requirements : Standard Library by Xon
Pushes title edits into XenForo's Edit History system.
Supported content
Please create a Github Pull request via the "More Information" link.
Télécharger V2.2.2 :
Version 2.3.0 Maintainance update :
Adjust 'title history' link to have better style compatibility
Requires php 7.0+
Confirm XF2.2 support
Télécharger V2.3.0 :
Version 2.3.1 : Fix installer listener did not correctly apply schema changes when a supported add-on was detected being installed.
Télécharger V2.3.1 :
Version 2.3.2 - Bugfix update :
php 8.2 compat fixes
Fix "Declaration of X::getHtmlFormattedContent must be compatible" error on viewing title history
Télécharger V2.3.2 :
Version 2.3.3 Maintaince update : Update php 8.2 compatibility fixes
Télécharger V2.3.3 :
Version 2.4.0 - Bugfix Maintainance update :
This add-on is now available on atelieraphelion.com
Version 2.4.1: Fix permission denied error when viewing title history
Télécharger V2.4.1:
Version 2.5.1 - XenForo 2.3 support :
Version 2.6.0 Feature update :
Supported content
- Threads - To see Title history, the "Manage any thread" permission is required.
- Resources - To see Title history, the "Edit any resource" permission is required.
- Media - To see Title history, the "Edit any media items" permission is required.
- Album - To see Title history, the "Edit any album" permission is required.
Requires php 7.0+
- Require php 7.2+
- Require XenForo 2.2+
- Require Standard Lib v1.18.0+
- Fix template error when $config['enableListeners'] is set to false, or this add-on is being upgraded
- Compatibility fix for addons which iterate the entity content type field list.
- XF2.2.15+ has a behavior change which causes checking the existence of some XF authored classes to throw instead of return false.
Télécharger V2.4.1:
- Require StandardLib v1.20.0+
- XF2.3 support
- php 8.4+ compatibility fixes
- Require StandardLib v1.23.0+
- Add support for ticket titles from @Naz's Tickets add-on
