CLI Job / Cron Runner 3.1.2
XF 2.2 / 2.3 CLI Job / Cron Runner 3.1.2
Titre du sujet Titre du sujet CLI Job \/ Cron Runner 3.1.2
Réponses Réponses 4
Affichages Affichages 291
This XenForo 2.2 addon implements an advanced CLI triggered job runner for use with Unix cron as a replacement for the built-in xf:run-jobs command introduced in XF 2.2
The command is called hg:run-jobs and does the same thing that xf:run-jobs does, but with more options and functionality.
Main features of this addon:
  • allows commands to process jobs/crons for up to 10 minutes at a time, even when triggered every minute from a cron task (uses a lock file to prevent multiple executions in parallel) - ideal for improving job performance on high traffic sites
  • extensive debugging output available for testing and identifying issues with jobs and cron tasks
  • drop-in replacement for xf:run-jobs
Requirements :
This addon requires PHP 7.0 or higher and has been tested on XenForo 2.2.0 beta 1
Installation :
Install as per normal addon installation.
Once installed, go to the System and performance options page as change the Job run trigger setting to "Server based trigger"
First, you should test that your job runner is functioning - execute the following command from your CLI :
Bash:
$ php <path to your forum root>/cmd.php hg:run-jobs
For example, if your forum root is /srv/www/xenforo/community, then the job runner command would be :
Bash:
$ php /srv/www/xenforo/community/cmd.php hg:run-jobs
Running this command will execute any outstanding jobs and then finish with a message about whether there are more jobs waiting to be executed or not. When executing this command from cron, it is recommended that you use the --quiet (or -q) flag to suppress output.
Once you are happy that the job runner functions correctly, you will need to create your own cron task to run it on a schedule of your choosing.
NOTE: if you already have a cron task set up to run xf:run-jobs simply disable that and replace it with an identical task which runs hg:run-jobs instead.
Approach #1 using crontab :
It is highly recommended that you have your cron task run as the web server user to prevent potential permission problems.
For example, on Ubuntu with a web server user of www-data, install a cron task by running the following command :
Bash:
$ sudo crontab -u www-data -e
Edit the crontab file and add :
Bash:
    *       *       *       *       *       php /path/to/your/forum/root/cmd.php --quiet hg:run-jobs
Save the crontab.
Approach #2 using cron.d :
Instead of using a crontab, some Linux distributions create a well-known directory which is automatically checked for cron tasks to execute. In the case of Ubuntu, you can create files in /etc/cron.d/ where you specify the schedule, the user to execute the command as, and the command itself.
Create a file in /etc/cron.d/ with the following contents :
Bash:
* * * * * webserver-user php /path/to/your/forum/root/cmd.php --quiet hg:run-jobs
... where webserver-user is changed to the name of the user your web server runs as and change the path to your forum root.
Again, using our previous example where web server user is www-data and our forum root is
/srv/www/xenforo/community, I would execute the following command to create the cron file :
Bash:
echo "* * * * * www-data php /srv/www/xenforo/community/cmd.php --quiet hg:run-jobs" | sudo tee -a /etc/cron.d/xenforo
Both options (crontab and cron.d) will execute the job runner every minute, checking for outstanding jobs to be run.
By default, the job runner will run for a maximum of 30 seconds, executing any outstanding jobs until there are no more runnable jobs in the queue.
Upgrading from addon v1.x after upgrading XenForo to v2.2
v2.0 of this addon changes the command name and the maximum permitted run time. Note also that the --time option in v1.x has been renamed to --max-execution-time in line with the core job runner provided in XF v2.2.
To upgrade :
  1. Upgrade to XF v2.2 RC2 or later
  2. Install v2.0.x of the addon
  3. change your unix cron entry to execute hg:run-jobs instead of xf:run-jobs
  4. if you use the --time option, rename this to --max-execution-time
  5. optional: adjust the --max-execution-time option to anything up to 600 seconds (10 minutes) to allow job processing to take as long as it needs. For example: --max-execution-time=180 will allow the Job Runner to execute for up to 3 minutes at a time
Note : make sure you have "Server based trigger" enabled in the System and performance admin options.
Configuration :
You may adjust the maximum execution time of the job runner by specifying the --max-execution-time=[TIME] option on the command line.
For example, to allow the job runner to execute for a maximum of 45 seconds :
Bash:
$ php <path to your forum root>/cmd.php --max-execution-time=45 hg:run-jobs
This addon uses lock files to prevent multiple job runner commands to execute at the same time, which also allows us to have the command run for longer periods on busy sites.
The maximum execution time allowed is 10 minutes (600 seconds). The command will execute until it finds no more outstanding jobs and then stop - so execution time is typically only a few seconds.
For further customisation of your job execution, you may also adjust the maximum time that each job is permitted to run.
This is configured via a XenForo config.php Option :
Bash:
$config['jobMaxRunTime'] = 8;
The jobMaxRunTime option configures the amount of time in seconds that processing jobs will be allowed to run before they are suspended for further processing on another go-around, if possible. The default setting is optimised for the browser-triggered job runner and so to allow jobs to execute longer in a CLI environment, you may want to adjust this to a higher value.
In general it is suggested that this setting be kept to a relatively small value to avoid the situation where a single very long job may prevent other jobs from executing in a timely manner. Some experimentation may be required to find the optimal value for your server load and forum size. If in doubt, leave it as the default setting of 8 seconds.
Usage :
The run-jobs command should be executed automatically using a cron task as per the instructions above.
Show Jobs :
The hg:show-jobs command outputs a list of all the currently pending jobs, so you can see how full the jobs queue is.
By default only the next scheduled 100 jobs will be shown, you may use the --all option to show a complete list of all pending jobs.
There should always be at least two jobs showing: the main Cron job and the Upgrade Check job.
Bash:
$ php cmd.php xf:show-jobs
2 pending jobs found
| Key            | Class           | Next Run             | Last Run             |
| cron           | XF\Job\Cron     | 11-Apr-2019 10:52:01 | 11-Apr-2019 10:52:31 |
| xfUpgradeCheck | XF:UpgradeCheck | 12-Apr-2019 00:12:21 | 10-Apr-2019 21:24:03 |
The current time is: 11-Apr-2019 10:52:31 (UTC+10:00)
Debugging Jobs :
There are extensive debugging tools to help identify issues with Jobs and Cron tasks.
To run in debug mode, first disable the Unix cron which runs jobs automatically (don't forget to turn it back on again once you are finished debugging!) and then use the verbosity options (Verbose: -v, Very verbose: -vv or Debug: -vvv) for the hg:run-jobs command to specify the level of output to show on the console.
Output is to the console and is in a format similar to that used by the Monolog library (although we do not use Monolog to generate the output).
For example, Verbose option -v :
Bash:
$ php cmd.php hg:run-jobs -v
[2019-11-27 23:53:09] XF\Job\Cron: Cron entry XF\Cron\CleanUp::runUserDowngrade executed in 0.01 seconds
[2019-11-27 23:53:09] XF\Job\Cron: Cron entry Hampel\LogDigest\Cron\SendLogs::serverError executed in 0.00 seconds
[2019-11-27 23:53:09] XF\Job\Cron: Cron entry XF\Cron\MemberStats::rebuildMemberStatsCache executed in 0.00 seconds
[2019-11-27 23:53:09] XF\Job\Cron: Cron entry Hampel\Slack\Cron\NotifyLogs::notify executed in 0.03 seconds
[2019-11-27 23:53:09] XF\Job\Cron: Cron entry XF\Cron\Feeder::importFeeds executed in 0.01 seconds
[2019-11-27 23:53:09] XF\Job\Cron: Cron entry XFMG\Cron\RandomCache::generateRandomMediaCache executed in 0.07 seconds
[2019-11-27 23:53:09] XF\Job\Cron: Cron entry XF\Cron\EmailBounce::process executed in 0.00 seconds
[2019-11-27 23:53:09] XF\Job\Cron: Cron entry XF\Cron\Counters::rebuildForumStatistics executed in 0.02 seconds
[2019-11-27 23:53:09] XF\Job\Cron: Job executed in 0.20 seconds
No more runnable jobs pending
The Very Verbose option -vv adds context, typically about the JobResult :
Bash:
$ php cmd.php hg:run-jobs -vv
[2019-11-27 23:49:49] XF\Job\Cron: Cron entry Hampel\Slack\Cron\NotifyLogs::notify executed in 0.01 seconds {"entry_id":"slackNotifyServerErrors","cron_class":"Hampel\\Slack\\Cron\\NotifyLogs","cron_method":"notify","run_rules":{"day_type":"dom","dom":{"0":-1},"hours":{"0":-1},"minutes":{"0":-1}},"active":true,"next_run":1574898543,"addon_id":"Hampel\/Slack"}
[2019-11-27 23:49:49] XF\Job\Cron: Cron entry Hampel\SparkPost\Cron\MessageEvents::fetchMessageEvents executed in 0.00 seconds {"entry_id":"sparkpostMessageEvents","cron_class":"Hampel\\SparkPost\\Cron\\MessageEvents","cron_method":"fetchMessageEvents","run_rules":{"day_type":"dom","dom":{"0":-1},"hours":{"0":-1},"minutes":{"0":19,"1":49}},"active":true,"next_run":1574898543,"addon_id":"Hampel\/SparkPost"}
[2019-11-27 23:49:49] XF\Job\Cron: Job executed in 0.03 seconds {"completed":false,"jobId":2,"continueDate":1574898603,"continueDate_formatted":"2019-11-27 23:50:03 UTC","statusMessage":"Running... Cron entries"}
[2019-11-27 23:49:49] Hampel\SparkPost:MessageEvent: Job executed in 0.83 seconds {"completed":true,"jobId":12,"continueDate":null,"continueDate_formatted":"","statusMessage":""}
And finally the Debug option -vvv adds extra information about the job :
Bash:
$ php cmd.php hg:run-jobs -vvv
[2019-11-27 23:48:03] XF\Job\Cron: Cron entry XF\Cron\Feeder::importFeeds executed in 0.01 seconds {"entry_id":"feeder","cron_class":"XF\\Cron\\Feeder","cron_method":"importFeeds","run_rules":{"day_type":"dom","dom":{"0":-1},"hours":{"0":-1},"minutes":{"0":2,"1":12,"2":22,"3":32,"4":42,"5":52}},"active":true,"next_run":1574879524,"addon_id":"XF"} {}
[2019-11-27 23:48:03] XF\Job\Cron: Cron entry XF\Cron\Counters::rebuildForumStatistics executed in 0.02 seconds {"entry_id":"forumStatistics","cron_class":"XF\\Cron\\Counters","cron_method":"rebuildForumStatistics","run_rules":{"day_type":"dom","dom":{"0":-1},"hours":{"0":-1},"minutes":{"0":3,"1":13,"2":23,"3":33,"4":43,"5":53}},"active":true,"next_run":1574879584,"addon_id":"XF"} {}
[2019-11-27 23:48:03] XF\Job\Cron: Cron entry XF\Cron\MemberStats::rebuildMemberStatsCache executed in 0.03 seconds {"entry_id":"memberStatsCache","cron_class":"XF\\Cron\\MemberStats","cron_method":"rebuildMemberStatsCache","run_rules":{"day_type":"dom","dom":{"0":-1},"hours":{"0":-1},"minutes":{"0":0,"1":10,"2":20,"3":30,"4":40,"5":50}},"active":true,"next_run":1574880004,"addon_id":"XF"} {}
[2019-11-27 23:48:03] XF\Job\Cron: Cron entry XF\Cron\Trophy::runTrophyCheck executed in 0.00 seconds {"entry_id":"trophy","cron_class":"XF\\Cron\\Trophy","cron_method":"runTrophyCheck","run_rules":{"day_type":"dom","dom":{"0":-1},"hours":{"0":-1},"minutes":{"0":40}},"active":true,"next_run":1574880004,"addon_id":"XF"} {}
[2019-11-27 23:48:03] XF\Job\Cron: Cron entry XFMG\Cron\Statistics::cacheGalleryStatistics executed in 0.01 seconds {"entry_id":"xfmgCacheStats","cron_class":"XFMG\\Cron\\Statistics","cron_method":"cacheGalleryStatistics","run_rules":{"day_type":"dom","dom":{"0":-1},"hours":{"0":-1},"minutes":{"0":10,"1":40}},"active":true,"next_run":1574880004,"addon_id":"XFMG"} {}
[2019-11-27 23:48:03] XF\Job\Cron: Cron entry XF\Cron\CleanUp::expireTempUserChanges executed in 0.00 seconds {"entry_id":"expireTempUserChanges","cron_class":"XF\\Cron\\CleanUp","cron_method":"expireTempUserChanges","run_rules":{"day_type":"dom","dom":{"0":-1},"hours":{"0":-1},"minutes":{"0":42}},"active":true,"next_run":1574880124,"addon_id":"XF"} {}
[2019-11-27 23:48:03] XF\Job\Cron: Cron entry XFMG\Cron\RandomCache::generateRandomAlbumCache executed in 0.02 seconds {"entry_id":"xfmgGenerateRandomAlbum","cron_class":"XFMG\\Cron\\RandomCache","cron_method":"generateRandomAlbumCache","run_rules":{"day_type":"dom","dom":{"0":-1},"hours":{"0":-1},"minutes":{"0":12,"1":42}},"active":true,"next_run":1574880124,"addon_id":"XFMG"} {}
[2019-11-27 23:48:03] XF\Job\Cron: Cron entry XF\Cron\EmailUnsubscribe::process executed in 0.00 seconds {"entry_id":"emailUnsubscribe","cron_class":"XF\\Cron\\EmailUnsubscribe","cron_method":"process","run_rules":{"day_type":"dom","dom":{"0":-1},"hours":{"0":-1},"minutes":{"0":13,"1":43}},"active":true,"next_run":1574880184,"addon_id":"XF"} {}
[2019-11-27 23:48:03] XF\Job\Cron: Cron entry XF\Cron\Ban::deleteExpiredBans executed in 0.01 seconds {"entry_id":"deleteExpiredBans","cron_class":"XF\\Cron\\Ban","cron_method":"deleteExpiredBans","run_rules":{"day_type":"dom","dom":{"0":-1},"hours":{"0":-1},"minutes":{"0":45}},"active":true,"next_run":1574880304,"addon_id":"XF"} {}
[2019-11-27 23:48:03] XF\Job\Cron: Job executed in 0.32 seconds {"completed":false,"jobId":2,"continueDate":1574898543,"continueDate_formatted":"2019-11-27 23:49:03 UTC","statusMessage":"Running... Cron entries"} {"job_id":2,"unique_key":"cron","execute_class":"XF\\Job\\Cron","execute_data":{},"manual_execute":0,"trigger_date":1574879464,"last_run_date":1574879405,"trigger_date_formatted":"2019-11-27 18:31:04 UTC","last_run_date_formatted":"2019-11-27 18:30:05 UTC"}
[2019-11-27 23:48:03] Hampel\SparkPost:MessageEvent: Job executed in 0.90 seconds {"completed":true,"jobId":10,"continueDate":null,"continueDate_formatted":"","statusMessage":""} {"job_id":10,"unique_key":"SparkPostMessageEvents","execute_class":"Hampel\\SparkPost:MessageEvent","execute_data":{},"manual_execute":0,"trigger_date":1574898483,"last_run_date":null,"trigger_date_formatted":"2019-11-27 23:48:03 UTC","last_run_date_formatted":""}
[2019-11-27 23:48:03] Hampel\SparkPost:EmailBounce: Job executed in 0.02 seconds {"completed":true,"jobId":11,"continueDate":null,"continueDate_formatted":"","statusMessage":""} {"job_id":11,"unique_key":"SparkPostEmailBounce","execute_class":"Hampel\\SparkPost:EmailBounce","execute_data":{},"manual_execute":0,"trigger_date":1574898483,"last_run_date":null,"trigger_date_formatted":"2019-11-27 23:48:03 UTC","last_run_date_formatted":""}
Custom job debugging
You can add additional debugging to your custom jobs.
Add the following function to your job class to call the logJobProgress function of our Logger class :
Bash:
    protected function log($message, array $context = [])
        // check to see if we actually have a logger available and abort if not
        if (!isset($this->app['cli.logger'])) return;
        /** @var Logger $logger */
        $logger = $this->app['cli.logger'];
        $logger->logJobProgress($message, $context, $this);
Then you can call the log() function in your job code to send information to the console when the Job Runner is executed in verbose mode.
For example - see the test job included in this addon Hampel\JobRunner\Job\TestJob :
Bash:
    public function run($maxRunTime)
        $this->log("About to start test job", $this->data);
        $mail = $this->app->mailer()->newMail();
        $mail->setTo($this->data['email']);
        $mail->setContent(
            "Test job",
            "This is an email sent from a test job"
        $sent = $mail->send();
        $this->log("Sent mail", ['sent' => $sent]);
        return $this->complete();
The above code will generate the following output when the Job Runner is in debug mode :
Bash:
[2019-11-28 00:26:21] Hampel\JobRunner:TestJob: About to start test job {"email":"foo@example.com"} {"job_id":17,"class":"Hampel\\JobRunner\\Job\\TestJob","status_message":"Testing jobs","data":{"email":"foo@example.com"},"execution_time":"0.00"}
[2019-11-28 00:26:21] Hampel\JobRunner:TestJob: Sent mail {"sent":1} {"job_id":17,"class":"Hampel\\JobRunner\\Job\\TestJob","status_message":"Testing jobs","data":{"email":"foo@example.com"},"execution_time":"0.95"}
[2019-11-28 00:26:21] Hampel\JobRunner:TestJob: Job executed in 0.95 seconds {"completed":true,"jobId":17,"continueDate":null,"continueDate_formatted":"","statusMessage":""} {"job_id":17,"unique_key":null,"execute_class":"Hampel\\JobRunner:TestJob","execute_data":{"email":"foo@example.com"},"manual_execute":0,"trigger_date":1574900777,"last_run_date":null,"trigger_date_formatted":"2019-11-28 00:26:17 UTC","last_run_date_formatted":""}
No output will be shown when run in quiet mode - and more importantly, if this addon is disabled the logging code will not need to be removed. The important part is the if (!isset(\XF::app['cli.logger'])) return; line, which will abort if our Logger is not available.
Custom Cron task debugging :
Using a similar mechanism, we can add debugging code to our custom Cron tasks too :
Add a slightly different function to your Cron tasks to call the log() function of our Logger class :
Bash:
    protected static function log($message, array $context = [])
        $logger = \XF::app['cli.logger'];
        $logger->log("XF\Job\Cron", $message, $context);
Then, simply call something like: self::log("some message about something happening", ['key' => 'value']); within your code to output information to the console when the Job Runner is executed in verbose mode.
Logger Trait :
There is also a trait you can include in your classes: Hampel\JobRunner\Cli\LoggerTrait which implements some basic logging functions you may call from your code:
  • getLogger
  • log
  • logQuiet (will show even if the -q option is specified for the Job Runner) - use this for critical errors only
  • logNormal (will show for no verbosity or higher)
  • logVerbose (will show only for the -v option or higher)
  • logVeryVerbose (will show only for the -vv option or higher)
  • debug (will show only if the -vvv option option is specified for the Job Runner)
There is no need to remove your logging or debugging code from your addon when you deploy - when running hg:run-jobs in normal or quiet mode, none of the output is shown unless it uses logNormal or logQuiet (which should only be used for errors).
Télécharger V2.0.0b3 :
Version 2.0.0 stable release :
Stable release of v2.0.0 - tested on XF 2.2.0 stable
Changes :
listen to app_cli_setup rather than app_setup do we don't instantiate our SubContainer unnecessarily
fix an issue where upgrade from v1.5 fails due to legacy Setup.php file
Version 2.1.0 update and bugfixes :
had required parameters after optional parameters - re-arranging logJobProgress function signature to make it more usable
added new option --reset to delete any existing lockfile - useful in situations where a job has crashed without removing the lock and you don't want to wait 10 minutes for the lock to expire
Important : if you also run my SparkPost addon - you must update that to the new v2.1.0 release after updating this addon
Addon has now been tested on PHP 8.0
Télécharger V2.1.0 :
Version 2.1.1 XF 2.3 compatibility update :
- XF 2.3 compatibility
Télécharger V2.1.1 :
2.1.2 (2025-12-12)​
- run enqueuePostUpgradeCleanUp() during upgrades if we're running XF2.3+
2.1.3 (2026-09-29)​
  • now requires PHP 7.1 or later, up from 7.0 - XenForo 2.3 already requires 7.2, so this affects XenForo 2.2 forums only
  • bugfix: a cron task throwing an Error, such as a TypeError, no longer stops the rest of the cron tasks due in that run. On XenForo 2.3 it also removed the cron job from the queue, which stopped every scheduled task on the forum until a cron entry was next saved; on XenForo 2.2 it crashed hg:run-jobs
  • bugfix: hg:run-jobs releases its lock when a job throws, rather than leaving it in place and refusing every run for up to ten minutes with JobRunner already running.
  • bugfix: hg:run-cron runs a cron task's class as extended by other add-ons, the same code the scheduler runs, and reports an Error from the task rather than failing with a PHP fatal error
  • hg:run-jobs --help gives the real maximum for --max-execution-time: 600 seconds, not 900
  • README rewritten: requirements, setting up cron and the Job run trigger option, and every command with its options
2.1.4 (2026-09-29)​
  • bugfix: under server-based job triggering, the admin control panel no longer reports "There are scheduled jobs outstanding which have not run" when jobs are running normally. The add-on had stopped XenForo recording when the next job was due, so the check read a time that never moved
3.0.0 (2026-09-29)​
Renamed from CLI Job Runner to Job & Cron Monitor. The add-on no longer runs your jobs:
XenForo's own xf:run-jobs does, and this add-on is for watching and diagnosing it. See
"Upgrading from 2.x" in the README.
  • change your crontab from hg:run-jobs to xf:run-jobs. hg:run-jobs still works - it now runs xf:run-jobs with the same options and prints nothing of its own - but will be removed in a later major version. --reset is accepted and ignored
  • commands renamed: job-monitor:run-jobs, job-monitor:show-jobs, job-monitor:show-crons, job-monitor:run-cron and job-monitor:queue-test-job. The old hg: names still work in 3.x
  • job-monitor:run-jobs logs each job and cron task without -v; --max-execution-time=0 runs until the queue is empty
  • new: job-monitor:health-check checks that jobs and cron are running - the cron job queued, overdue jobs and cron tasks, failed jobs, and an old crontab still calling hg:run-jobs. Exits 0, 1 or 2; --fix re-queues a missing cron job; --json for monitoring
  • new: on XenForo 2.3 every failed job is recorded, not only in debug mode, and job-monitor:show-failed-jobs lists them
  • new: every job and cron task run is timed and kept hour by hour for 90 days; job-monitor:show-stats shows the busiest, slowest or one task's history
  • new: a daily cron task prunes failed jobs after 30 days and statistics after 90
  • XenForo's own xf:run-jobs now runs cron tasks with the add-on installed - the add-on used to hold them back for its own runner
  • the lock is gone: XenForo already stops two runners running the same job. The old lock file is deleted on upgrade
  • on XenForo 2.2, a cron task throwing an Error now ends that run, as it does in XenForo itself; the other due tasks run on the next pass
3.0.1 (2026-09-29)​
  • the job-monitor: commands are listed without their old hg: names beside them. hg:show-jobs, hg:show-crons, hg:run-cron and hg:test-jobs still work in 3.x, but no longer appear in list
3.1.0 (2026-10-08)​
  • job-monitor:health-check is now job-monitor:validate, and its exit codes have changed. It exits 1 if any check found a problem and 0 otherwise, warnings included, so a deploy or a cron job can depend on it. It used to exit 1 on a warning and 2 on a problem. The old name now checks nothing and exits 1, so anything still calling it fails loudly
  • new: --strict makes a warning exit 2, for a monitor that should hear of one. 1 still means a problem - this is not the monitoring-plugin numbering
  • a check that did not apply is shown with a blank marker and not as OK: failed jobs on XenForo 2.2, which does not record them, and the cron job on a forum with no active cron tasks. --json reports these as skipped, and gains a strict key
  • activity based job triggering is now a warning, since jobs then wait for page views and do not run from cron
  • a check that cannot run is reported as a problem with the reason, and the other checks still report. It used to end the run
  • server error log entries written by the add-on begin JobRunner:
  • on XenForo 2.2, upgrading removes the files earlier versions left behind, which that version of XenForo never deletes
3.1.1 (2026-10-12)​
  • declares to the Admin API add-on, on a forum that has it, that this add-on has no secret settings. It answers the hampel_admin_api_redaction code event, which is never fired on a forum without that add-on
Major update: renamed from CLI Job Runner to Job & Cron Monitor - this tool no longer runs your jobs and hg:run-jobs is deprecated, use the core xf:run-jobs instead. This addon is now for watching job & cron tasks and diagnosing issues.
Version 3.1.2 (2026-10-14)
  • job-monitor:validate accepts --unattended. Other add-ons use the option to skip a check that sends something, such as a test email; these checks send nothing, so it changes nothing here. It is accepted so that a monitor can run every add-on's validate with the same options
Télécharger V3.1.2 :
