Clean Admin UI 2.0.1
XF 2.3 Clean Admin UI 2.0.1
Titre du sujet Titre du sujet Clean Admin UI 2.0.1
Affichages Affichages 137
If you create an admin user but don't give them any admin permissions, you'll see the following information in the admin cp.
You'll also see a bunch of other warnings and notices, depending on what's happening on your server.
This addon simply hides all of these extra bits of information (which really shouldn't be visible to admin users without any permissions!), so you can have a clean admin UI if you need to give certain users administrative access to certain functionality - but you don't want them accessing this other information.
In addition to the Tools menu on the side, the following information is removed from the admincp home/index page:
  • Unicode warning
  • Stopped jobs / Stopped manual jobs notice
  • Legacy Config notice
  • Import running notice
  • Staff online info block
  • Environment report info block
  • File health checks info block
With this addon installed, this is what the admin UI looks like to a user with no admin permissions:
("XenForo 2.3" is the board title of my dev server - you'll see your board title there instead)
This addon adds three new admin permissions for finer control over who can see what:
  • Use checks and tests
  • View server info
  • View staff online
As per the standard behaviour of XenForo, a user with SuperAdmin rights will automatically have these permissions and see everything in the AdminCP.
This addon has been tested with XF 2.3
Version 2.0.0 :
- This update is for v2.3.4 and above only - it hides the warnings about license expiry and so on that still displays, even with the changes introduced in v2.3.4
With this addon installed, only superadmins can see warnings such as this:
All other previous functionality has been removed - this is the only thing this version currently does.
Version 2.0.1 (2026-09-22)​
  • bugfix: the scheduled upgrade check never contacted XenForo unless a super administrator happened to trigger the job queue — the super-administrator restriction now applies only inside the admin control panel
  • refusing Check for upgrades to an administrator now shows a permission error, instead of a message blaming the board's configuration
Télécharger V2.0.1 :
