Attention cette version fonctionne uniquement sur xenforo 2.3
This is an AJAX based chat application that does AJAX calls to the server to get new messages.
Main Features
Chat uses the built in XenForo rich-text editor and you can disable individual buttons/BB codes.
Room options
You can also use the /find command followed by a keyword to search for messages.
Demo (Guest Mode) without registration can be seen here: Chat
To test all the features, please register.
This version is compatible with XenForo 2.3
- Also added the new GPT-4o model for AI command.
Version pour xenforo 2.0, 2.1, 2.2 ici : XF 2.0 / 2.1 / 2.2 - Chat 2 by Siropu 2.1.1 a 2.3.1
Télécharger V2.4.0 :
Lien pour les membres Premium :
Version 2.4.1 Bug Fixes :
- Fixed an issue with a JS error.
- Issue on mobile with conversation user list where messages won't show on click.
- Fixed an issue with missing icon on mobile view.
Version 2.4.2 Bug Fixes :
- Fixed an issue with image uploads not working.
- Fixed an issue with message color where a user automatically gets the first color in the list when a setting is changed.
- Fixed an issue with whisper messages breaking the editor when page loads.
- Fixed some JS errors when using guest mode.
- Other JS minor fixes for AJAX loaded messages.
Version 2.4.3 Bug Fixes :
- Reactions not displaying correctly when updated via AJAX.
/idle command not working
- "Load more messages" feature not working correctly with images where they do not display in fancybox when clicked on.
- Joining a room, won't display the user list correctly.
- Updating user status removes user from the list.
Version 2.4.4 Bug Fixes :
- Fixed an error that shows up in ACP.
- Fixed an issue with the submit button not displaying in "all pages mode".
Version 2.4.5 Bug Fixes :
- Fixed a JavaScript error causing submit function to not work properly.
- Fixed an issue with the right side chat navigation link on some custom styles.
Télécharger V2.4.5 :
Version 2.4.6 Bug Fixes :
- Fixed an issue with "who's typing" display, where it shows under the room name instead of inline with it.
- Fixed an issue with submitting messages when BB code editor is off.
- Fixed an issue with submit button disappearing after posting.
- Fixed an issue with "start private conversation" form toggle from the chatter list.
Télécharger V2.4.6 :
Version 2.4.7 Improvements & Bug Fixes :
- Added new profile posts forum activity notifications.
- Added xAI integration for /ai command.
- Added custom css class siropuChatAiBot for AI responses to style the message row.
- Fixed an issue with reaction user list not displaying usernames.
Télécharger V2.4.7 :
Version 2.4.8 Bug Fixes :
- Fixed an issue with room reactions disappearing on chat refresh.
- Fixed an issue with /help command not working.
Télécharger V2.4.8 :
Version 2.5.0 Improvements & Bug Fixes :
- Added DeepSeek as a new option for /ai command.
- Fixed an issue with thread notifications when threads require approval.
- Fixed an issue with chat bar disappearing on mobile when editor is focused.
Télécharger V2.5.0 :
Version 2.5.1 Improvements :
- Replaced ChatGPT, xAI and DeepSeek with OpenRouter API where you can choose from various AI models.
Télécharger V2.5.1 :
Version 2.5.2 Bug Fix :
- Fixed an issue with "Conversations tab info" admin option where "Disabled" will generate an error.
- Fixed an issue with editing conversation messages where message will appear as "undefined".
- Fixed an issue with AI room message thread posts not using the Bot Name as author.
- Fixed an issue with message edit function where the message actions will disappear upon editing.
Télécharger V2.5.2 :
Version 2.5.3 (XF 2.3.x Only) - Improvements & Bug Fixes :
- Added admin option to display [0] badge in the chat public navigation if there are no active users in the chat.
- Fixed a JS error on mobile.
Télécharger V2.5.3 :
Version 2.5.4 Improvements :
- Added two new fun commands: /coinflip and /rps (Rock Paper Scissors)
- Added search function for conversation list.
- Added user setting to change timestamp format.
- Added unread count for conversations.
- Added conversation order options based on last message date and alphabetically.
Télécharger V2.5.4 :
Version 2.5.5 Improvements & Bug Fixes :
- Added 3 new fun commands: /bite, /push, /punch - each command has custom options in ACP where you can add body parts/objects to use randomly.
- Fixed an issue with room "Enable thread reply" where you still get thread replies posted into the chat even when disabled.
- Fixed JS error on mobile/responsive view.
- Fixed an issue with some commands where using @Username will not work as expected.
Version 2.5.6 Improvements & Bug Fixes :
- Made the Chat bar to have the same with as the forum container.
- Fixed an issue with display user count in navigation tab working even when disabled due to a JS error.
- Fixed an issue with "No chatters list", generating a JS error, preventing the message you post to display.
Télécharger V2.5.6 :
Version 2.5.7 Bug Fixes : Fixed an issue with "Load more messages" button where the text was inserted outside the button. This is due to a recent code cleanup.
Télécharger V2.5.7 :
Version 2.5.8 Improvements & Bug Fixes :
- Updated the OpenRouter AI model list.
- Fixed an issue with a JS error if the <html> tag id was changed from XF to something else.
Version 2.5.9 Bug Fixes :
- Fixed an issue with "All pages mode" where the script fails to add a footer padding to prevent the bar from blocking visibility of some footer elements.
- Fixed an issue with BB code toggle button where it breaks the editor if the button is not enabled in the Chat when toggled off from a thread or a different content type.
- Fixed an issue on archive page where action buttons do not display when hovering over the message date.
- Fixed an issue on archive page where edit and delete do not work as expected.
Removed Tenor gif command option as they are terminating the API service.
Télécharger V2.5.9 :
Main Features
- Rooms (with embed option)
- Dedicated guest room with nickname support
- Archive with search criteria
- Polls
- Top chatters page
- Private conversations
- Sound, desktop & browser tab notification
- Global user commands (21 commands that you can manage and you can also add you own custom commands)
- Custom user commands (Can be used to set predefined messages/responses via command)
- User settings
- User status
- User group permissions
- User sanctions (Mute/Kick/Ban)
- User image uploads
- Style properties
- Lots of admin options to enable/disable certain features
- Bot notifications for new threads, new posts, new users, new Resource Manager resources, new Media Gallery albums/media/comments
- Bot responses that can be trigger by predefined keywords
- Bot messages that are posted automatically at set time/date
- Display notices in rotation (can be edited via the built in rich text editor)
- Display ads in rotation
- Set chat rules page
- Rooms widget
- Top chatters widget
- Active users widget
- Display "Who is typing" in both rooms and conversations
Room options
- Name
- Description
- Room users (optional with user permission) - Allow room access to certain users.
- Password (optional with user permission)
- User groups - Allows you to enable room access based on user group (admin option)
- User language - Allows you to display room based on the user's account language setting (admin option)
- Read only - Allows you to make room read-only (admin option)
- Locked - Allows you to lock the room until a certain date (admin option)
- Can leave room - Allows you to control if the user can leave or not the room once joined (admin option)
- Minimum time between messages - Users will have to wait this many seconds between posting messages. (admin option)
- Auto-prune messages every x hours (admin option)
- Thread ID - If you set a thread ID, messages posted in the room will also be posted in the thread (admin option) In ACP there is an option that allows you to set the minimum length required for a message in order to be posted in a thread. (admin option)
- Enable thread reply - Thread replies will get posted in the room. (admin option)
- Repost in selected rooms - Allows you to automatically repost the messages you post in this room in other rooms (admin option)
- Simple Like/Unlike or Reactions
- Quote
- Link
- Report
- Edit
- Delete
- Quote
- Report
- Edit
- Delete
