Attachment Integrity 5.7.4.1
XF 2.3 Attachment Integrity 5.7.4.1
Titre du sujet Titre du sujet Attachment Integrity 5.7.4.1
Réponses Réponses 4
Affichages Affichages 78
Attachment Integrity for XenForo 2.3
Attachment Integrity is a powerful attachment auditing, repair and storage analysis addon for XenForo.
Built for both small forums and large communities with millions of attachments, including support for external storage providers such as Cloudflare R2 and S3-compatible systems.
Main features
  • Attachment integrity scanning
  • Missing attachment detection
  • Advanced thumbnail verification
  • Duplicate attachment detection
  • Safe duplicate cleanup workflow
  • Attachment repair queue system
  • Background low-priority scalable scans
  • Cloudflare R2 / external storage awareness
  • Storage analytics and reporting
  • Attachment age reports
  • Per-user attachment statistics
  • Export tools (CSV / JSON / TSV / HTML)
  • Scheduled scan support
  • Critical issue email alerts
  • Repair audit logging
  • Archived scan history
  • Enhanced filtering/search tools
  • ACP dashboard panels and widgets
  • CLI support for large forums
Designed for large forums
The scalable scan engine supports chunked low-priority background processing to avoid ACP timeouts and reduce load on large forums.
Supports:
  • local filesystem storage
  • XenForo filesystem abstraction
  • Cloudflare R2
  • S3-compatible storage
Remote-aware scans avoid downloading full attachment objects where possible.
Duplicate cleanup uses a dry-run first workflow and intentionally avoids deleting referenced attachments automatically.
Only duplicate attachment data rows with zero active attachment references are considered safe for automated deletion.
Current status
This addon is currently considered an early access / beta release while additional large-scale testing and edge-case hardening continues.
Recommended before production deployment:
  • full database backup
  • filesystem backup
  • testing on a staging environment first
Télécharger V2.5.0 :
This update focuses heavily on stability, scalability and real-world forum support after a large amount of backend work and testing.
New in 5.2.1
  • Low-priority scalable background scans
  • Cloudflare R2 / external storage aware scanning
  • Chunked scan processing for very large forums
  • Resumable scan state system
  • Safe duplicate attachment cleanup workflow
  • Duplicate cleanup dry-run mode
  • Duplicate cleanup audit logging
  • Improved repair queue handling
  • Better ACP scan management
  • Enhanced attachment verification checks
  • Improved button/action wiring validation
  • Storage probe and adapter detection
  • Additional reporting and analytics improvements
Duplicate cleanup safety
Duplicate cleanup has been intentionally designed to avoid dangerous automatic deletions.
The addon now:
  • detects duplicate attachment data
  • builds a cleanup queue
  • performs dry-run validation first
  • only deletes duplicate data rows with zero active attachment references
Referenced attachments are automatically held for manual review rather than being blindly deleted.
Large forum improvements
The scalable scan engine is designed for forums with very large attachment libraries and external object storage.
Supports:
  • Cloudflare R2
Additional notes
This release also includes:
  • template cleanup
  • controller/action verification
  • PHP lint validation
  • XML validation
  • improved internal wiring checks
As always:
  • please back up your forum before running repair/cleanup tools
  • staging/testing is recommended before production deployment on very large forums
Small maintenance/stability update.
Changes in 5.2.2
  • Improved export handling
  • Added explicit CSV export support/validation
  • Improved admin permission handling
  • Additional ACP button/action validation
  • Additional service/job wiring checks
  • Additional XML validation cleanup
  • Internal release-readiness checks and cleanup
  • General backend stability improvements
This update was mainly focused on tightening things up and improving overall reliability before wider public use.
Attachment Integrity 5.4.5 Released
This update focuses mainly on stability, scan accuracy and improving support for larger forums using external storage providers such as S3 and Cloudflare R2.
Updated in 5.4.5:
  • Added proper "hashes.json" support for XenForo file health checks
  • Fixed scalable/background scan failures on stricter MySQL setups
  • Improved remote storage detection for S3/R2 environments
  • Removed misleading local disk free-space reporting on external storage
  • Duplicate attachment analytics now only show confirmed scan results
  • Missing thumbnail analytics now only show confirmed scan results
  • Disabled unsupported local thumbnail sampling/benchmark checks for remote storage
  • Improved ACP navigation phrase handling
  • Additional backend stability improvements and cleanup across scan handling and analytics
Thanks to everyone testing this on larger production forums and reporting edge cases — it’s helped massively with tightening up the addon for real-world usage.
I’ve pushed another update that clears the compiled phrase row and refreshes the ACP nav phrase on upgrade
Updated in 5.4.6 :
Done a fair bit of work on this update after some proper testing on larger forums and external storage setups.
Main fixes in this version:
  • Fixed S3/R2 scans incorrectly flagging attachments as missing
  • Files are now only marked missing if the addon can actually verify they’re gone
  • Improved external storage handling and remote object checks
  • Standard scans now use the storage adapter properly instead of local-only checks
  • Fixed ACP navigation phrase issues
  • Added proper hashes.json support for XenForo file health checks
  • General cleanup and stability improvements across the scan system
Also spent time going through the package properly before uploading:
  • XML validation
  • PHP syntax checks
  • ACP route/button checks
  • permission checks
  • hashes verification
  • scalable/background scan checks
Appreciate everyone that’s been testing this and posting issues/feedback. It’s helped a lot with catching edge cases that you just don’t see on a basic local install.
Updated in 5.4.7 :
Attachment Integrity v5.5.0 Update
  • Scheduled automatic integrity scans
  • Email notifications for critical issues
  • Storage usage analytics
  • Attachment age reporting
  • CLI scan and repair commands for large forums
  • Improved repair automation (one-click repair, guided maintenance)
  • Additional export formats (CSV, JSON, TSV, HTML)
  • Storage benchmarking
  • ACP dashboard widget
  • Enhanced filtering and search (per-forum scans, severity filtering)
5.5.2 What's new :
  • Bulk delete attachments by filename pattern with dry-run preview before committing
  • Background scans now start properly instead of silently completing with no results
  • Stale scans stuck running for 2+ hours are automatically marked as failed
  • Email alerts for critical issues now report the correct issue count
  • Fixed file health check showing false "missing" results due to incorrect hash format
  • All XML data files updated to XF 2.3 format for clean installs on any site
What's fixed in v5.5.3:
  1. New "Bulk actions" sectionadded to the ACP page with:
    • Filename pattern search field (searches ALL attachments, not just scan results)
    • Dry run checkbox (on by default) — previews what would be deleted
    • Confirmation checkbox required for live deletion
    • "Search and process" button
  2. Clarifying note added to the Results filter: "Filters below search scan results only. Run a scan first to populate this table. To search all attachments by filename, use the Bulk actions section."
Version 5.5.4 :
- Turns out the bulk action form wasn’t actually submitting correctly in certain situations, which is why nothing appeared to happen when pressing “Search and process”.
- I’ve corrected it properly for v5.5.4 and reworked the form handling through XenForo’s normal framework flow rather than relying on the previous implementation.
Télécharger V5.5.4 :
What was fixed in v5.5.5:
  • Root cause: The "Search and process" button in Bulk Actions did nothing because actionBulkDeleteByFilename() redirected back to actionIndex(), discarding all search results
  • Fix: Bulk filename search now runs inline inside actionIndex() on POST - results render on the same page load without any redirect
  • Template: Form uses ajax="false" for a clean full-page POST; result message shows below the button
Quick update to sort out an issue affecting fresh installs.
## What's Fixed
v5.6.2 and earlier had a bug where several database columns were only created during the upgrade path, not on a clean install. If you installed the addon fresh (rather than upgrading from an older version), the scan tables would be missing columns and you'd get errors when running scans.
This affected three tables:
  • Scan table was missing mode, priority, and remote-aware columns
  • Repair queue was missing strategy, risk level, and verification columns
  • Results table was missing state tracking columns
v5.6.3 fixes all of it. Every column is now properly defined in the initial table creation, so fresh installs and upgrades both work the same way.
## What's New (if you're coming from an older version)
### Search Attachments (added in v5.6.0)
Dedicated search page in the ACP. Search by filename, display name, aliases, extension, uploader, content type, file size, or date range. Filter for orphaned attachments. Paginated at 50 per page.
### Rename Attachments (added in v5.6.0)
Set a custom display name for any attachment from the search results. Original filename stays intact. Useful when uploads have auto-generated names.
### Aliases (added in v5.6.0)
Tag attachments with comma-separated alternative names. Fully searchable, so you can find files without remembering exact filenames.
### Bulk Rename (added in v5.6.0)
Match by filename pattern and apply a display name across all matches. Dry run on by default.
## Bug Fixes
  • Fixed 18 missing columns across 3 tables on fresh installs
  • Fixed upgrade path to properly handle all column additions for existing installs
  • Consolidated all table column definitions into single methods to prevent this happening again
## Requirements
  • XenForo 2.3+
  • PHP 8.0+
## Installation
Upload the package via the ACP under Add-ons > Install/upgrade from archive.
V 5.7.4 What's new:
Bookmark attachments -- You can now bookmark any attachment across the forum. Little bookmark icon sits on every attachment in posts. Click it, done. All your bookmarked attachments show up in a personal gallery under your account so you can find them again without digging through old threads.
User aliases -- Once you've bookmarked something, you can give it your own name. Call it whatever makes sense to you. Search by alias from your gallery page. Handy if you've got dozens of saved images and can't remember which thread they came from.
Proper entity framework -- Rebuilt the internals properly. Six full XenForo entities now handle all the data instead of raw SQL. Repository layer for bookmarks and aliases. Everything goes through the framework the way it should.
ACP navigation sorted -- Attachment Integrity now sits under Tools with a paperclip icon. Dashboard and Search Attachments are both clickable links underneath. No more dead section headers.
Bulk delete actually works -- Search Attachments in the ACP lets you search by filename across everything, preview what it finds with dry run, then delete if you want to. Was broken before, now it isn't.
Rename attachments -- Admins can rename attachment display names and add aliases from the ACP search page.
Upgrade is straightforward -- upload and install through the admin panel as usual. New database tables for bookmarks and aliases get created automatically.
Let me know if anything plays up.
Télécharger V5.7.4 :
Version 5.7.4.1 What it fixes :
- MutationObserver in the bookmark JS was calling processAttachments() which mutated the DOM, retriggering the observer in an infinite loop -- causing Chrome to freeze for logged-in users. Fix disconnects the observer before processing and reconnects after.
Télécharger V5.7.4.1 :
    44.5 KB · Affichages: 13
    64.1 KB · Affichages: 6
    65.8 KB · Affichages: 7
    70 KB · Affichages: 7
    46.1 KB · Affichages: 7
    27.6 KB · Affichages: 9
    30 KB · Affichages: 6
