Approval Queue Plus 3.6.4
XF 2.1 / 2.2 / 2.3 Approval Queue Plus 3.6.4
Titre du sujet Titre du sujet Approval Queue Plus 3.6.4
Réponses Réponses 9
Affichages Affichages 817
This XenForo 2.1 addon adds extra info to the entries in the Approval Queue to help make approval decisions easier.
The approval queue was redesigned for XF2.1 - this addon adds back some additional information.
Before :
After :
Specifically, the following information is shown :
  • Username
  • Email
  • Date joined
  • Date of last activity
  • Registration IP
  • Location
  • Time Zone
  • User Agent
As per the core product, there are some moderator permissions required to see certain values :
  • Email requires "Bypass user privacy"
  • IP address requires "View IP addresses"
  • User Agent requires the custom "View User Agents" permission added by this addon
There is also an admin option to reverse the default sort order of the Approval Queue.
... finally User Agent data can be automatically pruned for approved users after a specified number of days.
Télécharger V3.3.1 :
Version 3.4.0 bugfixes and XF 2.3 compatibility : Changes in this release :
  • update permission phrase to make it clear where the permission comes from
  • rename user agent table from xf_user_agent to xf_aqp_user_agent to comply with resource standards
  • bugfix - gracefully handle case where user agent doesn't exist for user
  • fix approval_item_user template modification for compatibility with XF 2.3
Télécharger V3.4.0 :
Version 3.5.0 with Cloudflare location support :
This version adds support for showing Cloudflare geo-location data for sites running Cloudflare. To enable the display of Cloudflare location data, you must turn on Managed Transforms in your Cloudflare admin console. Go to Rules > Transform Rules > Managed Transforms and enable Add visitor location headers.
Télécharger V3.5.0 :
Version 3.5.1 bugfix for faulty upgrade :
- Fixes a critical upgrade bug (doesn't apply to new installs), where certain columns didn't get created.
Télécharger V3.5.1 :
Version 3.5.2 bugfix - missing admin permissions :
- Minor bugfix to explicitly enforce admin permissions on admincp tools.
Télécharger V3.5.2 :
3.5.3 (2025-12-11)​
- run enqueuePostUpgradeCleanUp during upgrades if we're running XF2.3+
3.6.0 (2026-09-20)​
  • now requires XenForo 2.2.0 or later
  • fixed: Cloudflare continent information was never recorded, because the CF-IPContinent header was misspelled internally — it is now recorded, and shown on the Cloudflare location test page under Tools > Checks and Tests
  • fixed: the user agent clean up option's on/off setting is now honoured — switching it off did not previously stop the scheduled clean up from running
  • the viewUserAgents permission is now hampelAqpViewUserAgents, so that it cannot clash with a permission of the same name from another add-on — existing permission settings are migrated automatically during the upgrade
3.6.1 (2026-09-22)​
the Cloudflare location in the Approval Queue now ends with the continent — for example Sydney, NSW, Australia (Oceania) — for users who registered on 3.6.0 or later, which is when continent began to be recorded
Version 3.6.2 (2026-10-04)​
  • fixed: registration failed for any client that sent no User-Agent header — browsers always send one, so ordinary sign-ups were unaffected, but a scripted or API registration was refused
  • fixed: clearing the Delete User Agent data after box no longer deletes every approved user's recorded data on the next scheduled clean up
Télécharger V3.6.2 :
Version 3.6.3 (2026-10-10)​
  • now requires PHP 7.4 or later — above the PHP 7.0 that XenForo 2.2 itself requires, and needed by the new command line checks below. XenForo 2.3 already requires PHP 7.2, so this affects only a XenForo 2.2 forum still running PHP 7.3 or older
  • new: two command line checks. approval-queue-plus:config prints what the Approval Queue is set up to show and what has been recorded; approval-queue-plus:validate checks that it all works — that the queue's template modifications still apply, that the Cloudflare header map still produces a location, that the View User Agents permission is present, and that the scheduled clean up will run when it says it will. Neither command writes, deletes or sends anything, so both are safe to run on a live forum
  • approval-queue-plus:validate exits 1 when a check failed and 0 otherwise, and --strict exits 2 for warnings alone, so a monitoring script can watch a forum's configuration
  • approval-queue-plus:validate reports a clean up that can never run: switching it on while leaving Delete User Agent data after empty makes the scheduled prune decline every time, which is safe but silent
  • the add-on now tells the Admin API add-on that none of its settings are credentials, so they can be reported rather than withheld
Télécharger V3.6.3 :
Version 3.6.4 (2026-10-12)​
  • fixed: the scheduled clean up could exhaust PHP's memory and delete nothing, on a forum holding a large backlog of recorded registration data. It now deletes in batches, and asks the database only for the user ids it needs rather than loading whole rows, so how much one run can get through no longer depends on how much has accumulated
  • a backlog builds up on any forum that has the clean up switched off, or that has had Delete User Agent data after left empty — the clean up declines to run in either case, which is safe but silent. Switching it on, or filling that box in, is what sends the first run at the whole backlog, so this fix matters most on a forum where nothing has been pruned for a long time. approval-queue-plus:config reports how many rows are eligible now
Télécharger V3.6.4 :
